I have the notorious Toshiba/Vestel LED Tv with what I suspect is a blown LED, two actually, compared to the rest these two have a crack appearing across the middle, one worse than the other, I presume this means they are blown? there's no blackening that I can see, thanks.
How do I spot a blown LED?
Re: How do I spot a blown LED?
Hi mate do you have a pair of pliers on hand ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/ -
Strange question but you can use them to test the strips, and what size is the tv 40" ?Last edited by ReeceyBurger123; 07-15-2015, 04:59 AM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
you will need to remove the clear white dome, and a visual inspection can be done. then you can use your multimeter set in diode mode to test each led.
When you touch the probes to the led its should light up a little bit.Comment
Link up 3 x 9 volt batteries in series to the + and - marked at the start of the led strips.
Once you've found out what strip/s are not lighting up, before you crack off the plastic domes check the leads for corrosion bad contacts etc.
If they all look fine you'll need to remove the plastic domes from each LED and use the diode test.Comment
No ! Turn the tv on go to the top strips of led find the negative terminal on the strip use the pliers to bridge that NEGATIVE terminal to the chassis that will fire on the booster for the top row and they should light if not then the top row is out. Next if the top row lights turn the tv off remove the top row of strips then the next row of leds and put them in the top position and repeat the same method if they turn on then they are good if they don't then they are bad. This saves doing all the other time wasting nonsense.Last edited by ReeceyBurger123; 07-15-2015, 05:58 AM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Dang my method saves aload of time I will make a youtube video eventually I have repaired 8 of these tvs alone using that method just because the optic is cracked does not mean that the bulb underneath has failed.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
OK, seems this back light is in series, will your method still work?Comment
Yes just simply put the one end of the pliers on the negative strip of the bulbs and then to the chassis you must do this on the top strips as that's where the voltage flows to first. Let me know how it goes.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
You have to be real careful doing that if the circuit was not well designed and does not detect the Vf total change of theLED string to keep the current constant, you can damage the good LED sting, and if it does not use one BIG long string of LED but individual string with its own driver for each string you can damage the booster circuit if it does not shut down fast enough.
When you ground that negative terminal which is connected to the Drain pin of the PWM Controlled MOSFET (current sink), the Source pin is connected to the LED current sensing resistor, the other end of the resistor is then connected to the LED drive Voltage return ground, you will bypass all those parts when you directly connect the Negative pin of the LED string to GND.
You have to be real careful as how the circuits are implemented. See PDF for example.Last edited by budm; 07-15-2015, 12:51 PM.Never stop learning
Thats true Budm but on these vestels it will not affect the bulbs if you bridge the negative terminal, all it will do it let the current from the psu flow through the strips and not from the booster as it wont be using enough current to activate it and it will only light the one strip as it requires all the strips to connected to start it where as if ones short non will light. Where as if you bridge the positive terminal to ground that will draw enough current to trigger the booster and will short the strips out. As you say it depends on how they are connected in these sets the top led strip is the first one to receive voltage then it goes down to the rest as they are wired in series so it the top strip goes out the circuit wont be complete and non will light thats why when you bridge the negative to chassis it completes the circuit for the top row and they will light.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
But the ANODE of the first string is connected to the Boosted output circuit isn't it (same as the example of the SAMSUNG diagrams), and the negative of the last string is sinked by the MOSFET? I did lot look at the board lay out yet.
All I am saying is to find out how the circuits are implemented first.Never stop learning
Thats not the case with these and no the boost converter will only fire if all the strips light if not it will bypass and just send the 24v output from the psu wiring leds like this is a complete and utter design error and meant to fail like christmas lights one out all out. Im guessing that this is a 40" toshiba with a Samsung panel lta400hm23 most common one to fail but all these vestel led tvs fail in the same way.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Trust me it doesn't not turn the booster on when you do that on others like good lgs and samsungs it may but not on these.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I am sure the boost will turn on, but since it is current-driven boost it will likely hit over-voltage threshold then shut off.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by cmlewis89Hi folks,
I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...12 Photos -
by drscootHP Modelnumber: 14-dh0061nb​
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by swergHey everyone,
I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components... -
by MrzPdlchHey everyone,
I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
Find some pictures of the actual GPU together with a picture of how it should look like.
I also wonder whther it might be a problem that there...3 Photos -
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... - Loading...
