No power on from standby. Same with two PSUs. (No brand TV)
  • goop
    • May 2014
    • 45
    • state
    I have two units of the same TV. One does not power up from standby (standby light is on), the other does. I switched the PSUs between them and the problem stayed on the same TV, so the PSU is okay (Megmeet MP116A rev 1.0. Photos on this thread).
    I guess that means the problem is the logic board, which is a Cultraview CV181H-X-41C (a brief spec for the CV181H-X-40C here, the 41C is similar):
    full size
    Should I assume it's capacitors to blame?
    The bunch of capacitors and inductors to the left are around TI TPA3110LD2 audio amp, so maybe unrelated.
    The two near the middle are next to a panel voltage select jumper, two voltage regulators, and flash.
    The two to the right are near the power input and two regulators.
    The one near the VGA connector is next to an SG Micro SGM330A analog video switch.
    What should I try?
  • steviewonder
    • Dec 2013
    • 183
    • england
    Re: No power on from standby. Same with two PSUs. (No brand TV)
    I would,with almost certainty,say it's the flash eeprom ic.
    steve
    • goop
      • May 2014
      • 45
      • state
      Why do you say that?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        As its a umc chassis, the most common fault on these is the flash ic with the epprom on it going corrupt with age. Check the model of the tv and see if you can find a new flash chip thats been precoded.
        • goop
          • May 2014
          • 45
          • state
          What's UMC?
            • 30979
            a tv make
            http://www.umc-uk.co.uk/firmware.php
            • goop
              • May 2014
              • 45
              • state
              I see. It's not branded UMC, and actually the two TVs are each branded slightly differently, but if they all use the same Cultraview logic board their faults might be similar.
              Is it possible to ascertain somehow that it's the flash?
              Should it be possible to read and write the chip in-circuit?
              Why would flash get corrupted so easily?
              • gravesent
                • Oct 2015
                • 11
                Are any of you able to give me the values of D13 / D15 located against the heatsink closest to the connectors on the edge, also Q15 and Q16? Any help is greatly appreciated!
                • gravesent
                  • Oct 2015
                  • 11
                    @gravesent: Which board and brand and model of what you are working on?
                    You are asking the same question on the MAGMEET power supply.
                    https://www.badcaps.net/forum/showth...331#post595331
                    https://www.badcaps.net/forum/showth...330#post595330
                    You should start a new thread and make sure to put make and model number on the thread.
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • SkishyIshy
                      Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                      by SkishyIshy
                      Hey All,
                      I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                      I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                      I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                      03-17-2021, 11:44 AM
                    • AleMonti
                      LG 55EG910V - no power and no standby light
                      by AleMonti
                      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                      After checking the basics I did the following:
                      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                      11-04-2024, 05:02 PM
                    • noinimod
                      Sony 55X900E no standby light, no power. Replaced mainboard already
                      by noinimod
                      No standby red light, nothing
                      This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                      Disconnected JK3 power board from main board, checked voltages on all the pin outs
                      At a few pins I can see the power supply providing 19.5V to the main board
                      Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                      LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                      12-22-2021, 12:58 AM
