Sony KDL-55EX640 (630) DEAD SET
  • junkmale172
    • Nov 2012
    • 41
    • usa
    #61
    Re: Sony KDL-55EX640 (630) DEAD SET
    thanks again, i will try to find a main board (fingers crossed) and see what happens
    • pay
      • May 2015
      • 4
      • US
      #62
      Hi there anyone knows about Sony KDL-55EX640 power supply, I have a problem finding ZD904 Valu it shows on the Zener Diode NZ 13B is that mean 13V ?, Thanks to you Guys i was also looking for the Value of IC901, I have Ordered ICE2QR0665Z, Any help will be appreciated, Thanks
      • t4796
        • Feb 2015
        • 79
        13v zener i think. as for ic901 number, should be same as my ic901 ice2qr0665z, was it too damaged to read the numbers off the chip?
        • t4796
          • Feb 2015
          • 79
          i got my hands on another power supply dps-195ap-1.
          surprise, there actually WERE two zener diodes in parallel in the original damaged location on my board.
          i'll desolder them soon and see what values they are.
          • pay
            • May 2015
            • 4
            • US
            #65
            I got the IC 901 and replaced it and the Zener diod as well, But still don't have any volts on IC 901 what's the Value of IC 902, All I see on it is S101 / 1145, What is the Value of the IC please I have been researching online for days still couldn't find anything.
            • pay
              • May 2015
              • 4
              • US
              #66
              I got the IC 901 and replaced it and the Zener diod as well, But still don't have any volts on IC 901 what's the Value of IC 902, All I see on it is S101 / 1145, What is the Value of the IC please I have been researching online for days still couldn't find anything. what's the value of the IC 901, Any help will be appreciated.
              • t4796
                • Feb 2015
                • 79
                S101 in1m101-t6g st9s101-t6g.
                • pay
                  • May 2015
                  • 4
                  • US
                  #68
                  Thanks t4796 for the Replay i checked the Volts ou but i dont get any outputs 0Volts no 3.3v, i had open pin of t901 before i fixed it, now i have 14v on IC 901 but no Output any Idea what it might be causing no 3.3V, I have no standby light or any thing in panal nothing blinking, whats the Main volt should i look for 12 or 24 ? in which output ? THanks
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #69
                    I have a DPS-195AP with damaged parts.
                    I need help with identifying IC601, R606, R605 and R618 please.
                    • t4796
                      • Feb 2015
                      • 79
                      Hi Mate,
                      Best I can do tonight.
                      IC601 = ICE2QS03G - Infineon
                      R605 = 69Y 5.11 ohm
                      R606 = 51D? 332k ohm?
                      R618 = 30B 2k ohm
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #71
                        That gives me a better idea.
                        R606 looks like 01S 10 ohm
                        R605 69Y 5 ohm
                        R618 30B 3K
                        It is a bit odd that other 10 ohm resistors are marked 01X like R601.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #72
                          R605 69Y 5 ohm
                          R618 30B 3K
                          My mistake, R618 30B would be 2K.
                          R606 still bothers me. 10 ohms seems right for the Gate drive circuit. The puzzle is that other 10 ohm resistors are marked 01X
                          instead of 01S.
                          Extra: Maybe R606 should read 510 which would mean 51 ohms. This would make sense also because it is the ON drive current that usually becomes much higher that OFF drive current and needs to be scaled back. The Gate current tends to become asymmetrical when the the drive voltage is more that double the Gate plateau voltage.
                          • t4796
                            • Feb 2015
                            • 79
                            I'm pretty sure of the values in my initial post apart from r606. I'll measure across those two parallel resistors/diode. The parallel figure of those two should confirm if it's 51D or 510.
                            • t4796
                              • Feb 2015
                              • 79
                              It's 510 = 51 ohms.
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #75
                                Ok, thanks for confirming that. Ill order some bits now.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #76
                                  It's 510 = 51 ohms.
                                  Thanks again for your help. It all worked out well.
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #77
                                    Has anyone been able to find this part for a reasonable cost?
                                    One Alibaba seller has responded saying that it is out of stock.
                                    • vikivng
                                      • Feb 2019
                                      • 228
                                      #78
                                      Hi guys,
                                      can anyone tell me about this component circled.?
                                      I just managed to fix one these boards that had power surge but theres a hum when tv is on.
                                      This component is short and need to replace it but there are no markings..thnx alot.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #79
                                        Originally posted by vikivng
                                        Hi guys,
                                        The part marked is a ferrite bead it will read short circuit
                                        • vikivng
                                          • Feb 2019
                                          • 228
                                          #80
                                          Yes thank you.
                                          My further research alerted me to this.
                                          The buzzing seems to be only audible when very close to the tv and the back is open.
                                          So is it a fact that this buzzing is normal.?
                                          Very happy with this one.
                                          Awesome forum guys.
                                            MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                            This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • Junkrepair
                                            Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                            by Junkrepair
                                            I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                            I found this nice little description of the conversion:
                                            Calculating capacitor ESR from Tan(delta)
                                            https://forum.digikey.com/t/calculat...-from-tan/2633
                                            It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                            06-12-2023, 02:45 PM
