Hi all, I have a ln46c630 Samsung with no back light. I have read all the posts on similar models and have replaced caps on power supply, Have tried unplugging mainboard which should turn on back lights and have snipped the jumper for flickering issues. All the posts have all gone as far as I have but nobody replied to what actually fixed it. I like to fix on component level and I believe its the power supply as I cant even hear any hum from the transformers. All voltages seem ok. I dont have a camera presently but the other posts have pictures of the same. Any help would be appreciated. I dont know if the other tv's on other posts got repaired or if they scrapped them. Thanks
Samsung ln46c630 no back light
Re: Samsung ln46c630 no back light
Well--IF all the voltages are OK--Its Unlikely to be the PSU...
A picture of the BL Board and PSU could help....TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM! -
Hi, check fuse fs802s, if that fuse is good then it is most likely capacitor right above the fuse ci818. I have had to replace many of these capacitors on samsung power supplies. Hope this helps.Comment
Is this the power supply/inverter board used in your TV?
http://www.shopjimmy.com/catalogsear...msung+ln46c630Never stop learning
Thanks for the responses. I will ck that cap nicholas1110 and thanks for the tip.
I have fixed probably 50 flat screen lcd's and plasma's and have gotten a lot of great info from this forum, so thanks again, I will report my findings, GaryComment
So what exactly blew apart, the fuse, CP820 or CI18?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Can't always tell by looking, need a meter capable of testing capacitance to know for sure. If you used same type fuse, seems like short/over voltage issue. Is there a schematic for the power board? or trace out from the fuse testing everything along the way.Last edited by nomoresonys; 05-19-2018, 04:44 PM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
So the parts in the PFC Voltage booster blew up and you replaced the blown parts, but are you now getting 380 ~ 400 VDC between the two legs of the main filter cap when the TV is turned on?
Power supply/inverter board: BN44-00341B.
This board is know for having low PFC Voltage and causes the backlights to flicker, the problem is caused by bad resistor network int he PFC Voltage feedback, but some people fix it the wrong by by cutting jumper J852 which defeat the LOW PFC Voltage shutdown protection circuit.
CI818 also goes bad and will have low capacitance and some time you can see it bulging on its side.
https://www.badcaps.net/forum/showth...ht=BN44-00341BLast edited by budm; 05-19-2018, 09:07 PM.Never stop learning
I will check and get back to you.And i don't think im getting that 380-400vdc.Comment
If your voltage isn't getting the 380-400 or so, try replacing those four resistors that nelic6 did, with same value ones he used, it's post #22 of the link budm gives in post #14, looks like that fixed it.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Yes bud checked voltage lamps come on for a sec voltage goes from 165vdc to 159vdc ,then back to 163vdc.voltage taken at cp803 with negative on bridge-.power supply never goes to full voltage.Last edited by sputnikoff; 05-20-2018, 01:20 PM.Comment
i guess i will remove power supply and bench test to see if its being loaded down.Comment
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Kaar3lTV: Samsung QLED QE65Q7FNAT
PSU: BN4400940A
MB: BN94-12832K
I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r... -
by marcinqHello,
I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....4 Photos -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
