Samsung ln46c630 no back light
  • jason123
    • Oct 2015
    • 1154
    Re: Samsung ln46c630 no back light
    Thank you R_J
    • ck reddy
      • Sep 2020
      As every body says - One more TV saved. (LN46C630K1FXZA)
      TV was sitting in the corner from 2015. Did some search those days but did not come across this website.
      Perfect Audio, No Video, Flash Light shows Video, So no Back Light (no BL what so ever)
      Red Light flashes 5 times then blank.
      As per this website, when looked at CI818 could not see the problem, removed the cap there it is a small pimple on the side. When tested. Cap is dead. Ordered from element14.
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
        09-07-2024, 05:50 AM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
      • marcinq
        Samsung UE60KS7000 No Standby Light
        by marcinq
        I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
        I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
        05-26-2025, 11:36 AM
        09-06-2024, 11:40 PM
