Vizio vt420m - Powers up/down and logo on screen but no picture/sound from inputs
  • Cyklopz
    • Mar 2015
    • 17
    • Usa
    Hello folks,
    I've been reading through threads on the Vizio vt420m TV and general troubleshooting and would like some input on what I've found so far. In checking the voltage regulators on the main board I think I've found two that are not putting out correctly. One VR does appear to be correct. Should I just try replacing the two that seem bad or should I check other components given the current level of functionality that the set has (read below)?
    I can power on the set either from the remote or from the side controls. It will power up and show the Vizio logo on the screen so back-light is definitely on. I can also power off the set either from the remote or from the side controls. I've tried several of the reset procedures; holding buttons, powering on/off and unplugging (even overnight). None of those changes the current behavior.
    I've looked online for replacement main boards but it would seem that for this model they are all gone. I did find one place that was mentioned in a YouTube video that will let you send in your board and they will either repair it or send you a used replacement and I might try that route if I can't find and fix the issue myself.
    Please let me know if any further information would be helpful or other pictures/angles are needed. The pictures attached are not great but do show U701, U702 and U103 on the main board and I think U702 and U103 might be bad.
    EDIT: FYI, looking at the boards does not seem to show any blown caps or obvious brown/black marks that might indicate further issues.
    EDIT2: I did try cooling the VRs with compress air to see if the TV would fully turn on but no joy at U701 or U702. Did not try U103.
    U701 - Not sure
    0
    9.03
    11.89
    U702 - Bad?
    0
    1.88
    3.28
    U103 - Bad?
    0
    4.01
    4.98
    Thanks folks!
    Chris
  • CapLeaker
    Leaking Member
    • 8070
    Re: Vizio vt420m - Powers up/down and logo on screen but no picture/sound from inputs
    These measurements have not much meaning, if we don't know the pin out with it. Also maybe you are able to identify the numbers marked on the regulators. The board pics, aren't that great, make head on shots from the top straight down. If you can't see details on the pic, we can't either.
    • Cyklopz
      • Mar 2015
      • 17
      • Usa
      Here are some close-ups of the three VRs on the main board that I have tested with their readings.
      Please see attached pics.
      Thanks.
      EDIT: I did test the voltages coming out of the power board and all rails checked out OK. (5v, 12v, 24v x 2)
      Chris
        U701: 78xx series, this one is 9V regulator so it is OK.
        U702: You need to zoom out a little bit so I can what are connected to pin 1 and pin 2.
        U103 5V 5A LDO does mot look right, the input is too low, it should be at least = 5V + 1.5V= 7.5V at the input pin.
        • CapLeaker
          Leaking Member
          • 8070
          U103 is not right. U102 I think is a 3.3v regulator, so it sounds about right and u101 is fine.
          • Cyklopz
            • Mar 2015
            • 17
            • Usa
            Here is that half of the main board showing U702.
            See attached.
            Chris
              See attached.
              Chris
              "U702 - Bad?
              0
              1.88
              3.28"
              So the reading you have shown as 1.8v on the center pin (big tab)? and the left pin is 0V, then it is 1.8V regulator.
              But the picture shows as:1.88, ??, 3.28.
              https://www.badcaps.net/forum/attach...1&d=1426450230
              • Cyklopz
                • Mar 2015
                • 17
                • Usa
                The close-up pic in post #3 shows the pin readings for all three VRs. The text in my post is just incorrect formatting, sorry.
                Chris
                • CapLeaker
                  Leaking Member
                  • 8070
                  what was your GND reference point?
                  since there is a voltage difference of 1.5V on U702 between in and out, it is ok. I think I had the 3.3V stuck in my head from the pdf.
                  • Cyklopz
                    • Mar 2015
                    • 17
                    • Usa
                    I tested against the big tab at the back.
                    Chris
                    • Cyklopz
                      • Mar 2015
                      • 17
                      • Usa
                      So u103 might be the only bad VR?
                      Chris
                        "I tested against the big tab at the back. "
                        you use the big tab of the IC U103 for GND? You shpuld use the chassis as the GND ref for your meter.
                        Please read post 4 again.
                        • Cyklopz
                          • Mar 2015
                          • 17
                          • Usa
                          I'll test again to double check the readings.
                          Chris
                          • CapLeaker
                            Leaking Member
                            • 8070
                            Chris
                            That's what I thought, since the voltages measured were kind of on the wrong pin on some.
                            • Bob1394
                              Vizio M65-C1 | Logo appears for 10 seconds then off
                              by Bob1394
                              I have used the search, and am stumped.
                              My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                              I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                              https://www.badcaps.net/forum/showthread.php?t=81088
                              https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                              Observations
                              1) [Interaction] Power turned on via TV button (or remote)...
                              02-08-2023, 01:03 PM
                            • Super360
                              Vizio E701i-A3 Vizio logo flashing then turns off
                              by Super360
                              Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                              07-25-2024, 07:06 PM
                            • x_orange90_x
                              Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                              by x_orange90_x
                              I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                              12-28-2023, 06:26 AM
                            • JaquesPratt
                              Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                              by JaquesPratt
                              I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                              This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                              07-16-2024, 01:04 AM
