Proscan Plded3996a-c2
  • _N_
    • Nov 2010
    • 52
    Man there's nothing in these Tvs these days wow tiny little boards compared to the Sammy. This one ill keep to turn it into a led monitor for the pc :P
    Symptoms Are :
    Tv red power led turns on when plugged in, Once power for the remote is pressed led becomes Blue and remains. No back-light Leds come on at all, not even a flicker.
    Ive checked the through hole components in the pics they have dots, all seem to register on the little trans tester as what they are, none burnt.
    In the pics ive tried to take readings, I can already see
    "Bud, typing inverter/Pwm circuit , here we go again" what are the voltages."
    Not sure sure if its CAP Ground leg or chassis .
    To take those readings for the inverter IC ,Youll ask and ill measure.
    http://www.datasheetlib.com/datashee...conductor.html
    http://www.scribd.com/doc/255967649/...Control#scribd
    tried to do all the homework so you guys don't waste time
    Re: Proscan Plded3996a-c2
    Since this unit only have one big yellow power transformer and you are getting indicator LED to come on then the main power supply is functioning so no need to check that power MOSFET in the primary side which drives that power transformer.
    It is more likly to something in the LED backlights driver circuit or the LED or it the driver is not getting BL-ON signal.
    Can we see the whole back side of the TV? I cannot see where the LED BACKLIGTS wires are at, it looks like the connector with the red and black wires.
    • _N_
      • Nov 2010
      • 52
      Those red and black wires disappear into a little slit in the caseing under the psu/inverter. the whole tv must weigh like 15 lbs max lol.
      I think there just connected to the led strips inside, I didnt want to dismantle the complete thing in case a break the screen,limited work space.
      BUT if its required, NP. needed?
      • _N_
        • Nov 2010
        • 52
        See. In the 3rd pic I took, where you see the voltages of the backside of the board in red ,
        Under the N channel Fet
        theres 2 tiny little 3 pin SOT-23 ( i think) Smds .
        1 is 3pin NpN and checks good the others a 3 pin Diode and
        Theres 1 tiny Zdiode (gives voltage both ways)
        these are by the inverter ob3350
        • jetadm123
          • 2169
          Did you check the 15N10 FET on the bottom for shorts?
          • _N_
            • Nov 2010
            • 52
            None of the 3 contact points beep on my meter, I tried in every combination.
              OK, the Voltage on the 100uF 100Vdc cap whcih is the filter cap for the LED driver Voltage boost converter circuit (the TOROID Inductor, the SMD Power MOSFET on the bottom of the board, the two rectifier diodes stacking on top of each other next to the TOROID). The 20.8BDC reading on that 100uF 100Vdc is too low. Was the Voltage reading taken without the LED connector in place?
              So beside check the MOSFET for shorts, you need to check the diodes also.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4944
                • New Zealand
                Do you mean when testing in diode test mode with your meter? What is the voltage measured? Maybe it's shorted.
                -David VanHorn
                • _N_
                  • Nov 2010
                  • 52
                  Just retested same reading at the cap legs of the 100uf 100v 20+v
                  the diodes tested good i pulled them off board to test.
                    Without the LED connector attached?
                    • _N_
                      • Nov 2010
                      • 52
                      im pretty sure its a Z-diode cause the tiny number can be read and goggled what it was.
                      4.4 1 way and 4.8 the other
                      • _N_
                        • Nov 2010
                        • 52
                        no no before, when i was testing them off board. None were shorted and all showed up with there diode symbol.
                          I am talking about the DCV reading on that 100uF 100V that you are getting only about 20VDC instead of something >50VDC.
                          • _N_
                            • Nov 2010
                            • 52
                            the 2 stacked diodes theres browning on the pcb from the heat, I did also pull those earlier and checked them to see if they were fried and they measured off the board like diodes.
                              I know, but I need to know what DCV do you get on that 100uF 100V when the LED connector is attached.
                              • _N_
                                • Nov 2010
                                • 52
                                At that 100V 100uf cap it gives me 20.8v dc, with probes placed directly pn the 2 legs of the 100uf 100v and meter set to DC AND thats with Every cable to the main board currently connect.
                                If you need a voltage test on something, id be happy to.
                                  I want the reading on the cap WITHOUT the LED connector plugged into the board to verify that there is no shorts in the wiring to the LED assembly.
                                  • _N_
                                    • Nov 2010
                                    • 52
                                    Also Ive read on here so long that capxon zapxon and every thing that ens with Xon in it is so bad I pulled all the Elctros caps and all were within there UF rating, I have a separate Cap meter (the joys of Ebay :.}.. )
                                    • _N_
                                      • Nov 2010
                                      • 52
                                      I want the reading on the cap WITHOUT the LED connector plugged into the board.
                                      20.8vDC without led connector plug
                                        OK, that means the MOSFET is not switching on and off and it just passes the input Voltage right to the output without producing the boosted Voltage needed for the LED.
                                        So you need to find out what DCV you have on the VCC pin and the GND pin of that 8-pin SMD IC.
                                        Did you download the spec sheet for that IC? If you did, then you should upload it.
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
