LG 47LE5300 Turns on but no picture, no sound
  • bkamali
    • 5
    My LG 47LE5300 Turns on but no picture, no sound.
    I am looking for PSU (YP47LPBD) schematic diagram as I think high voltage Mosfets are not working.
    They are ice cold which tells me they are not working. Maybe the problem is the High-voltage resonant controller is not functioning.
    Thanks in advance
  • CapLeaker
    Leaking Member
    • 8218
    Re: LG 47LE5300 Turns on but no picture, no sound
    We need to see pics. You need to invest into a DMM and measure some voltages. BTW, I'd leave my fingers off the primary side (to measure temperature) as that could end up deadly.
      That heatsink is for the LED backlights and other power supplies is not going to do anything until you find out if the standby power supply is working not, if the PFC Voltage booster is working or not, etc. Do you have PS-ON, BL-ON, etc?
      So show us the pictures of the whole back side of the TV so we can see what we are dealing with.
      What DCV do you get at the black connector on the power supply board that goes back to the main board, there are labels for each one of the pin of that connector.
      List the pin number with the name of the pin with the DCV readings when TV is plugged in but power switch is not activated, then with the power switch is activated.
      • bkamali
        • 5
        Thanks a lot for reply.
        Here are the pictures of TV and black connector pin voltages.
        When you say: "PS-ON, BL-ON" what does it mean?
        PS-ON=Power Supply On?
        BL-ON=?
          PS-ON = Power supply on, it is the command signal from the main board to turn on the rest of the power supply.
          BL-ON (or Inverter ON) = Backlights ON for turning on the backlights circuits, the command signal is also from the main board.
          You should read my BASIC LCD TV troubleshooting guide, your TV uses LEDs in stead of CCFL.
          • bkamali
            • 5
            I checked the voltages.
            The only voltage that I have is 3.3 V Standby. I do not have other voltages like 12 and 20 VDC.
            Seems no command is coming from processor to start the system.
            Any suggestions?
            • andie
              • May 2015
              • 3
              • Indonesia
              Dear All
              I have problem my 47LE5300 has screened as below. Any solutions to check?
              I'm new in repairing...LED TV
              • andie
                • May 2015
                • 3
                • Indonesia
                Sorry...
                this is the picture... my mistake convert to pdf.
                again...
                my LED problems is the screen is showing as this picture..
                could you help me what can I do?
                I'm newbie
                TV Type : 47LE5300
                Tx
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Looks like bad BGA symptoms.
                  I would say the mainboard is shot. Wait for others opinions too
                  • andie
                    • May 2015
                    • 3
                    • Indonesia
                    it means i have to change main board? Micom?
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
                    • kca
                      Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                      by kca
                      Hello all ~
                      I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                      This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                      No picture. No sound.
                      I tested all the voltages coming out of the power supply...
                      10-12-2023, 05:23 PM
