New tool, Aoyue 8800! Desoldering just got easy!
  • lookimback
    • Aug 2013
    • 1489
    This thing is absolutely amazing! Well worth the $179. I'm supposed to be saving up for an oscilloscope but I decided I could use this more. I've been doing a lot of rework on sustain boards and I'm just sick of struggling with desoldering braid and vacuum pens. So far, I've tested it on a TNPA3557 SC board I'm working on. MOSFETs just drop right out of the board. Takes about 3-5 seconds to melt the solder. No problems even on multi-layer boards. I was going to buy one of those cheap S-993A guns but I found this thread which made me change my mind. I think those S-993A things have been modified to work on 110v. I find it odd that the 110v and 220v versions have the exact same model number. My guess is that they've just changed the cord, so you're supplying 110v to a 220v element and only getting half the power, so 50w instead of 100w. Just speculation, but the people who've used the 220v version seem satisfied with the way they work. The specs on this 8800 are a bit misleading. The power supply is rated for 150w, so it's advertised as a 150w desoldering pump. In actuality, the gun only draws 100 watts. It's got a temp range of 200°C -480°C / 392°F - 896°F. One think I really love is the all metal holder.
    ------------signature starts here------------
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: New tool, Aoyue 8800! Desoldering just got easy!
    Isn't that 250W at 125V?
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Nice I use a Duratool Zd915 desoldering station it as well as yours isnt any hakko but has great thermal capacity and sucks up the solder like a champ, mine only cost £67 but has been one of the most useful tools I could have brought and makes my life alot easier
      • lookimback
        • Aug 2013
        • 1489
        100w at 110v.
        • lookimback
          • Aug 2013
          • 1489
          This is going to make troubleshooting sustain boards so much faster. It comes with a nice storage case, but I think it will never see the inside of it again. I looked at the Hakko FR-300. This was about $80 less, and already $80 more than I intended to spend. My finger was literally hovering above the buy it now button for one of those S-993a guns, then I decided to look for some reviews on the 110v version. Glad I did.
          • mockingbird
            • Dec 2008
            • 5488
            Congratulations, nice bit of kit.
            I've seen a short review of the FR-300, this definitely looks to be a much better deal.
            The question is, will you be able to get parts for it in 20 years like you can with Hakko.
            There are methods of removing sustain boards without a desoldering vacuum, but it involves breaking the pins.
            • lookimback
              • Aug 2013
              • 1489
              I hope so!
              Generally, when I'm troubleshooting, I try to reuse parts which aren't bad. Especially considering that most parts have to be ordered from China.
              • sugar_ray
                • Dec 2012
                • 121
                Nice toy!! Old saying goes, " you get what you pay for" I've been there done that with cheap irons. Frustrated as hell, not being able to get them hot enough etc....repair enough of them, it will pay for itself!! As for an ossiliscope, not sure how keen you are on used?? I did find mine at a local thrift shop for $35. Guess I got lucky?? Been working perfectly 2+ years
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by lookimback
                  100w at 110v.
                  The label says 2A. :/
                  Arc A770 16 GB
                  • lookimback
                    • Aug 2013
                    • 1489
                    Also, on a single layer board this thing melts the solder instantly. I just swapped out a transformer and fixed a power supply in under a minute. Score 1 for the 8800!
                    • lookimback
                      • Aug 2013
                      • 1489
                      I was originally going for a used one. Now, I've decided on a new Rigol DS1054Z, 4ch 50mhz hackable to 100mhz. $399 at tequipment.net, and they offer a discount to EEVblog forum members. I was going to get it a few weeks ago but had some unexpected bills pop up. They're out of stock right now, I'm planning on getting one when they get their next shipment in.
                        You won't regret the 1054Z, it's great scope... I have a 1074Z.. I kinda regret not waiting a few months for the 1054Z to come out, what a bargain at that price, but anyway
                        I've never been a good fan of Aoyue stuff when my Aoyue 968 station encountered all sorts of problems. In the 12 months that I owned it, the hot air heating element failed twice, the soldering iron once, and the display kept going blank or showing crazy temperatures that I knew were wrong. I hope the 8800 is better for you.
                        • lookimback
                          • Aug 2013
                          • 1489
                          If this thing lasts a year, I'll be happy. It will pay for itself within that time, and then I can get a Hakko.
                          • capkid
                            • Oct 2010
                            • 1339
                            I've had an Aoyue 852A++ hot air station for a few years. Not bad, but I'd probably buy something different if I had it to do over. Hopefully, the desoldering gun works out. I've had a Hakko 808 for a while, and I never use an iron to desolder through-hole components anymore.
                            LG Plasma Mal-Discharge Correction Service
                            • lookimback
                              • Aug 2013
                              • 1489
                              I have a Kendal 852D++ which is probably just a rebranded Aoyue. Had it since Sept, 2013 and never had a problem with it. Probably have a few hundred hours on it. When I upgrade from that, I'll probably get a Hakko with the hot air, vacuum desolder, and soldering iron, all in 1 unit.
                                I bought that model last month, use it about 4 times so far.
                                I took it apart when I received it to verify that the Line, Neutral, and GND, and the rest of the unit are put it together.
                                The first thing I notice is that the nylon standoff that hold the PCBA on the rear panel were all broken so the board was just sitting inside.
                                I notified them but did not get the response.
                                I replaced the standoff with better version.
                                The units works well for me, and the heater assembly also looks good.
                                Here are the pictures:
                                http://s807.photobucket.com/user/bud...?sort=3&page=1
                                • capkid
                                  • Oct 2010
                                  • 1339
                                  Yeah, I had some issues with the airflow level not rising above "3" on the 1-5 scale. I tightened a couple screws and did a couple other things (been awhile - can't quite remember), and the air gets up to a little above "4" now. It's not a bad unit.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Removed another IPM from an LG sustain board last night with the trusty paint remover. Jesus would one of these come in handy. Just about turned the board into charcoal in the process, will have to look into the proper tool for the job.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Fair enough, I couldn't do half the repairs I preform with out it especially on things like motherboards ect.
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        Yes, a desoldering gun makes removing IPMs MUCH easier. One thing I like to do when removing IPMs is to add a little solder to each pin before using the gun so that it flows better and the holes are cleaner. Also, I use a heat gun on a low setting to heat four to five pins at a time so the solder melts easier.
                                        • rex98
                                          HP DMI Tool
                                          by rex98
                                          HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                          DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                          The DMI Tool given here are for personal use only.
                                          DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                          You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                          from it, and that you please credit the author...
                                          07-02-2025, 05:51 AM
                                        • salim5566
                                          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                          by salim5566
                                          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                          06-26-2025, 03:25 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • shamsudeen
                                          Epson M3170 Monochrome inkjet printer adjustment program tool
                                          by shamsudeen
                                          Epson M3170 Monochrome inkjet printer adjustment program tool.
                                          Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                          anyone having it, please share
                                          Thank you
                                          07-08-2025, 06:42 AM
                                        • tony359
                                          Best tool to place electrolytic SMD caps on a board
                                          by tony359
                                          HI all,
                                          I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                          When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                          The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                          01-28-2024, 06:23 AM
