New tool, Aoyue 8800! Desoldering just got easy!
  • alex987
    • May 2015
    • 11
    • italy
    #121
    Re: New tool, Aoyue 8800! Desoldering just got easy!
    Thanks mate for the suggestion.
    • tibimakai
      • Jan 2012
      • 3680
      Guys, get the real stuff, these copies or look a likes, are not the same!
      I have purchased these in the beginning and I have realized, that I'm just struggling with these tools and then, I had to buy the real stuff and at the end, I ended spending more. It's a joy working with the real stuff.
      I have got the Hakko tool, which is not much more expensive, if you buy it at the right time(when the price is lower) and it works as expected, or even better then expected.
      • alex987
        • May 2015
        • 11
        • italy
        #123
        @ lookimback:
        You can buy the heating element here:
        http://www.sra-solder.com/c088-heati...esoldering-gun
        It costs $15
        I suppose this is the 110V version; 220V version should be different part number.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5095
          • New Zealand
          #124
          But is it worth it for something that was already broken twice in rapid succession?
          Maybe - if you used it to 'repair' the 8800, flog it off on eBay ASAP, then use the funds towards a Hakko...
          -David VanHorn
          • alex987
            • May 2015
            • 11
            • italy
            #125
            About the Hakko FR-300 here there are a lot of people having heating element issue.
            http://www.amazon.com/Hakko-FR300-05...ct_top?ie=UTF8
            Ah, about the pump motor, try to read this review:
            http://www.amazon.com/review/RB7LNF2...28013&store=hi
            It seems it isn't a good design...
            So, better to spend less (for an 8800) hoping it longer last, or spend more than double for an FR300, which seems to have some issues?
            • Agent24
              I see dead caps
              • Oct 2007
              • 5095
              • New Zealand
              #126
              Hakko 808 is a better idea
              -David VanHorn
              • lookimback
                • Aug 2013
                • 1489
                Fixed. It was around $21.50 with shipping. It works good, but has a real flimsy feel to it. I know it won't last a year of regular use. I considered selling it on eBay Agent24, but I wouldn't risk tarnishing my reputation. I'll use it until it breaks again, I have to get some use out of it to minimize my losses, but once it breaks again I'll toss it and get a Hakko.
                ------------signature starts here------------
                • saddle_au
                  Waste Warrior
                  • 121
                  I had both the Hakko desoldering station and hand held units and after 10 years of solid use, my Hakko handheld self-destructed. It had three screws through springs holding the barrel on and two of them gave way suddenly and it went 'bang' in my hand. The desk unit (soldering and sucking station) died about half a year later, again releasing piles of electronic smoke.
                  In all, quality lasts but there comes a point where replacement makes sense no-matter who makes it.
                  • lookimback
                    • Aug 2013
                    • 1489
                    I have a paperweight again. I used this last night for about 2 hours straight. I had 5 power supplies to rebuild, each with 9 components to remove. Towards the end, the pump started seizing up, it had no suction, and one of the screws which hold the tip assembly in melted out. Now, I just turned it on and the element is burned out again. These things are very poorly designed and are definitely not intended to be used. I won't waste my money fixing it again.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5095
                      • New Zealand
                      #130
                      Wow, that is astoundingly bad quality, even for a Chinese junker.
                      -David VanHorn
                      • lookimback
                        • Aug 2013
                        • 1489
                        And prior to last night, I'd only used it for a few minutes on a couple occasions. I had the temp on 480°C, I wonder if It's over powering the element?
                          • 31290
                          i wonder if it's not a 24/36v element!!
                          • lookimback
                            • Aug 2013
                            • 1489
                            I think it's 120v
                              • 31290
                              it *should* be, but that's not what i meant!
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5095
                                • New Zealand
                                #135
                                Maybe the temperature control is shorted and driving it full tilt all the time.
                                All the reviews on Amazon give it 5 stars. Admittedly, there are only 4 of them, though.
                                -David VanHorn
                                • dj_ricoh
                                  • 2073
                                  • uk
                                  #136
                                  i got this.
                                  it was the cheapest one because i use to much wick on power supply to learn how to fix them
                                  the only prob is the internal vent its making a noise after 2 weeks but i know why. moisture in basement.
                                  the max temp i use it its 380c. it does the job flawless
                                    • 31290
                                    those are from Ningbo Zhongdi Industry & Trade Co., Ltd.
                                    http://www.china-zhongdi.com/index.asp
                                      480C is way too hot anyway... on my old 968 it would make the element glow bright orange.
                                      I would use 360-400C for hot air. Maybe that'll make it last a little longer.
                                      • alex987
                                        • May 2015
                                        • 11
                                        • italy
                                        #139
                                        I took the risk and I bought one (220V version).
                                        It works fine; no complaint to date.
                                        I set the temperature to 350C.
                                        Maybe is 480C too high temperature?
                                        Why did you use this high temp? (in my opinion, 350C is good for both single and double layer pcbs)
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          It was set that high when I got it, I never really thought about it. I keep my iron set to about 365, I don't know why I never thought to turn it down.
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
