New tool, Aoyue 8800! Desoldering just got easy!
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    #81
    Re: New tool, Aoyue 8800! Desoldering just got easy!
    ZD-917 has desoldering + iron. You can also get the ZD-915 which is desoldering only, but then you get a shitty Chinese SMPS too.
    Yeah, just get the Hakko...
    -David VanHorn
    • lookimback
      • Aug 2013
      • 1489
      This puts my plans for an oscilloscope out the window, but I get way more use out of the desoldering gun.
      ------------signature starts here------------
      • retiredcaps
        • Apr 2010
        • 9271
        #83
        Originally posted by lookimback
        Well, I have a $180 paperweight again. This time the heating element burned out. Haven't used it more than 6 times.
        According to SRA, you are likely not covered (you should point them to this thread to see if they will help?)
        http://sra-solder.com/about-us/
        WARRANTY
        All products carry a 1 year warranty unless stated on the page. Wear items are not included in the warranty like soldering tip, heating element and IR bulbs. Customer will be responsible for return shipping to our service center. We cover the return shipping back to you.
        --- begin sig file ---
        --- end sig file ---
        • lookimback
          • Aug 2013
          • 1489
          I can't even find a replacement element for it. I'll have to open it back up and see if it has a part number on it.
          • retiredcaps
            • Apr 2010
            • 9271
            #85
            You are likely to find a replacement part. I can't see these generic clones using something specialized?
            • lookimback
              • Aug 2013
              • 1489
              It could be this one. It looks similar. Right number of wires.
              http://www.ebay.com/itm/AOYUE-C005A-...item1e9372c017
              • retiredcaps
                • Apr 2010
                • 9271
                #87
                Your instruction manual for the 8800 might list the part? I found another Aoyue manual that specified C004, but I can't find an online manual for the 8800.
                The Aoyue lists the following spares?
                http://www.aoyue.com/en/products/?bID=153&sort_id=157
                • lookimback
                  • Aug 2013
                  • 1489
                  Nothing in the manual. Not even tip replacement info.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #89
                    The 474 is where I found the C004 reference (page 1).
                    Since the 474 is a desoldering station, it might share some same internals as the 8800? Funny, the manual says C004, but the ebay auction states C005A is compatible with the 474.
                    At $24 USD + free shipping, it might be worth the gamble if you can't find the correct part number for the 8800? Seller claims item is in Hong Kong. If true, shipping from Hong Kong to USA should be around 2 weeks.
                    Alternatively, maybe SRA sells this heating element for roughly the same price?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #90
                      BTW, the same ebay seller has their own website and it is cheaper.
                      http://toolboom.com/en/Soldering-Equ...oldering-AOYUE
                      $13 USD + shipping (roughly $5.75 to NYC) = 18.75 USD.
                      • lookimback
                        • Aug 2013
                        • 1489
                        The tips look just like the ones used in the 474/474A, and others. I know for certain it has 4 wires. I just emailed Aoyue asking for a part number. Hopefully I'll get a response. I'll do a teardown tomorrow and get some good pics of the internals.
                          • 30979
                          be carefull, the ones with a base usually use 24v elements and the handheld ones are often mains powered.
                          • lookimback
                            • Aug 2013
                            • 1489
                            Yes, I noted that when I took it apart. The element gets 120 volts. And if I recall correct, it was AC. The motor is 24vdc.
                              Yea..... this is why I stay away from Aoyue.
                              You fix the element, something else will go wrong.
                              Not built to last.
                              Did you pay by card? Maybe your card provider offers a warranty, or buy-back protection...
                              • lookimback
                                • Aug 2013
                                • 1489
                                Not built to be used. Just for looks. Paid with PayPal.
                                  Doesn't PayPal give you 45 days to file a claim? (In the UK, it's 180 days.) I don't know how US law works specifically but I thought you had a minimum of 90 days warranty on goods.
                                    • 30979
                                    Aoyue actually has a pretty good reputation.
                                    that said, i dont know why you got that unit when a model with a base containing a digital temp display costs $150
                                    personally if i was to buy another vac desoldering unit, it would be the xytronics model.
                                    although i would only buy the handpiece because i have a weller base that can pull a 1bar vac on the gauge - and that's pretty serious!
                                    (yes, the weller DS80 even has a vac gauge)
                                    unfortunatly the weller handpiece doesnt last and costs stupid money!
                                    • capkid
                                      • Oct 2010
                                      • 1339
                                      I'd still contact SRA and request a refund. I'd then buy a Hakko
                                      LG Plasma Mal-Discharge Correction Service
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        Aoyue emailed me back. The part number for the element is C088. Doesn't look like anybody has it though. I'm going to email them back and ask if they have it available, because it isn't listed in their store. I didn't know they had one with a base for $150. I probably would have bought that if I'd known.
                                        • newtothis
                                          • Mar 2013
                                          • 1556
                                          • england
                                          #100
                                          The Sale of Goods Act says that your item must be fit for purpose.
                                          Even when your warranty has expired if the item has not done its job correctly or lasted a reasonable amount of time you can still claim via this.
                                          http://www.which.co.uk/consumer-righ...e-of-goods-act
                                          Don't let them fob you off!
                                          If the unit had been used 100's of hours before the element failed then it may not apply as its had reasonable use. But after being used 6 times this certainly does apply.
                                          Can't argue with laws
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
