Re: New tool, Aoyue 8800! Desoldering just got easy!
I read this in Aoyue 474A+ manual (very strange they forgot to write it in 8800 manual, too).
I hope Aoyue will replace your unit for free. In this case, thumbs up for Aoyue.
That's more than I would have expected. I hope they sort it out.Leave a comment:
I didn't think you were supposed to wet it. I'd tried it once and it seemed to kill the vacuum. Of course, this also has the cracked pump, so it probably didn't have much vacuum to begin with.
I emailed Aoyue about it. They sent me an email the next day asking for more information. They want the serial number, pictures, and name of the vendor I purchased it from. I'll get all of that for them this weekend. It would be great if I could get them to send it for free. I'm definitely going to let them know I've already had to replace the heating element twice.Leave a comment:
TIP:
Before starting a desoldering job, ALWAYS wet the yellow filter pad with water, in order to allows efficient air passage and filter action (filter pad must become "soft").
You should repeat this often, if your desoldering session takes too long.
>>If you don't do this, you risk to strain the motor, damaging it<<Leave a comment:
No wait!
Contact Aoyue support via skype:
http://www.aoyue.com/en/contact/
they have ALL replacements for this unit (not only what you can see on their website!)Leave a comment:
I'll do a teardown this weekend and post pics.Leave a comment:
can you post a foto?
btw if this the the clone type with a pump in the base, i'v seen spare pumps sold cheap.Leave a comment:
I tried using silicone adhesive. It might work. Too bad I don't have a 3D printer. The thing that really pisses me off about this is that the typical repair parts which a person might need are not available. I'm still going to buy the Hakko one, but right now I have other obligations. I'll coat the entire thing in silicone if I have to.Leave a comment:
patch the housing with rubber compound - you have nothing to lose trying.Leave a comment:
I got it heating again, but no vacuum. I forgot about the cracked pump housing. Can't find a replacement. Might have to modify it and add an external pump.Leave a comment:
Maybe there is no sensor circuitry at all. (like in the fake phones, the software is there though, to show changing numbers)Leave a comment:
Mine is still working...Leave a comment:
Decided to fix this one more time. I'm going to turn the temp down to 350°C and see if it will last. It's obviously a terrible design if you can turn it up so high that the element will burn out. I'm wondering if they screwed up on the sensor circuit and it's not reading right. I should probably get a tip temp tester and then, if it isn't reading accurately, I could probably modify it.Leave a comment:
It was set that high when I got it, I never really thought about it. I keep my iron set to about 365, I don't know why I never thought to turn it down.Leave a comment:
It works fine; no complaint to date.
I set the temperature to 350C.
Maybe is 480C too high temperature?
Why did you use this high temp? (in my opinion, 350C is good for both single and double layer pcbs)Last edited by alex987; 06-14-2015, 05:14 PM.Leave a comment:
I would use 360-400C for hot air. Maybe that'll make it last a little longer.Leave a comment:
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
Channel: BIOS Requests ONLY!
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you -
by tony359HI all,
I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because... - Loading...
