Picked up a Vizio E3D470VX and the guy said he heard a pop and that was it. Well when I push the power button the Vizio logo will come up and go right back off. Can still turn it off and on with power button. Took the back off and this is what I found. The mosfet is popped open and apart. Could this be the problem? The number on the mosfet is NDF05N50ZG. I looked the part number up and this is what I found that it is a MOSFET NFET T0220FP 500V 5A 1.5R. Can someone search on radioshack.com for mosfet 500v and see if what they have will work. Please reply soon.
Need help with Vizio E3D470VX
Tags: None
Re: Need help with Vizio E3D470VX
Digikey has the exact part you need. http://www.digikey.com/product-searc...GOS-ND&stock=1
.94$ for one. -
You need to find out if the Gate drive circuit is direct drive to those two MOSFETs, if it is, then you will need to replace the driver IC and the Gate drive components.
You need to check them out real well otherwise you will blow up your new parts.Never stop learning
Would you care to give some advice on how to do what you are saying? It would be much appreciated.Comment
Good clear straight shot pictures of the whole board, both sides.Never stop learning
Here is the pic, best I could do. No burnt marks or anything on the back side of the board.Comment
Lets try again.Attached Filesif you find these attachements useful please consider making a small donation to the site
My post #6 "Good clear straight shot pictures of the whole board, both sides."
I need to be able to see the traces so I can trace the connections from point A to point B,
I do not have the board in front of me to see.
What can be done when good clear pictures are provided:
https://www.badcaps.net/forum/showpo...5&postcount=35
https://www.badcaps.net/forum/showpo...9&postcount=12Never stop learning
OK, it is transformer coupling for driving the MOSFETs, on the GATE pin, there are 3 components (2 resistors, 1 diode)connected to it, check them out.
Look up the spec of the MOSFET to get the pinout.
BTW, there are FOUR MOSFETs,
Too bad they install a jumper wire in place of the fuse F400 which feeds B+ to that inverter circuit.Last edited by budm; 02-16-2015, 10:05 PM.Never stop learning
Replaced the mosfet and it still has the same problem. When you first turn it on the Vizio logo will appear and then it is gone. But the screen seems to not light all the way up. Then a few seconds later the screen will light back up and then go right back off. You can turn it off and on with the remote. Does anyone have any ideas. Could it be the main board or a tab bond issue. If it was a tab issue would the screen stay lit and on?Comment
the LCD and the backlight are 2 different circuits. Hook up your meter to the brown big 450V cap, turn the TV on and see what it does. It should have 170V then ramp up to 380V. That indicates the PFC is working.Comment
Too bad they install a jumper wire in place of the fuse F400 which feeds B+ to that inverter circuit.So what happen to the MOSFETs and the Gate components testing?Replaced the mosfet and it still has the same problem. When you first turn it on the Vizio logo will appear and then it is gone. But the screen seems to not light all the way up. Then a few seconds later the screen will light back up and then go right back off. You can turn it off and on with the remote. Does anyone have any ideas. Could it be the main board or a tab bond issue. If it was a tab issue would the screen stay lit and on?Last edited by budm; 03-02-2015, 11:25 AM.Never stop learning
Sorry Bud but I dont really understand how to test what you are telling me to test.Comment
That mosfet you changed out, download the data sheet and see on which pin the "gate" is. Look that up on your board. There are components inline. Resistors, diode etc that go back the driver IC. If a gate circuit component is bad, the mosfet simply won't work. Verify the resistor values, what's printed on it, to what it actually measures. So usually resistors either go open or get higher resistor value, that's bad. Diode usually shorts or gets leaky, that's bad too.
Budm told you already what to check, read post #12 again. You may have to "lift" one leg to get good measurement out of circuit.Comment
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
Assuming...7 Photos -
by NooyHello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet... -
by TomyleeHello,
I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
by redbaron1007I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...1 Photo - Loading...
