Need help with Vizio E3D470VX
  • joeshannallie
    • Dec 2013
    • 103
    • usa
    Picked up a Vizio E3D470VX and the guy said he heard a pop and that was it. Well when I push the power button the Vizio logo will come up and go right back off. Can still turn it off and on with power button. Took the back off and this is what I found. The mosfet is popped open and apart. Could this be the problem? The number on the mosfet is NDF05N50ZG. I looked the part number up and this is what I found that it is a MOSFET NFET T0220FP 500V 5A 1.5R. Can someone search on radioshack.com for mosfet 500v and see if what they have will work. Please reply soon.
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Need help with Vizio E3D470VX
    Digikey has the exact part you need. http://www.digikey.com/product-searc...GOS-ND&stock=1
    .94$ for one.
      You need to find out if the Gate drive circuit is direct drive to those two MOSFETs, if it is, then you will need to replace the driver IC and the Gate drive components.
      You need to check them out real well otherwise you will blow up your new parts.
      • joeshannallie
        • Dec 2013
        • 103
        • usa
        Would you care to give some advice on how to do what you are saying? It would be much appreciated.
        • CapLeaker
          Leaking Member
          • 8150
          post a pic of the back side of your board.
            Good clear straight shot pictures of the whole board, both sides.
            • joeshannallie
              • Dec 2013
              • 103
              • usa
              Here is the pic, best I could do. No burnt marks or anything on the back side of the board.
              • joeshannallie
                • Dec 2013
                • 103
                • usa
                Lets try again.
                  My post #6 "Good clear straight shot pictures of the whole board, both sides."
                  I need to be able to see the traces so I can trace the connections from point A to point B,
                  I do not have the board in front of me to see.
                  What can be done when good clear pictures are provided:
                  https://www.badcaps.net/forum/showpo...5&postcount=35
                  https://www.badcaps.net/forum/showpo...9&postcount=12
                  • joeshannallie
                    • Dec 2013
                    • 103
                    • usa
                    I will upload some better ones in a few minutes.
                    • joeshannallie
                      • Dec 2013
                      • 103
                      • usa
                      This the best I can get, I really appreciate you Bud
                        OK, it is transformer coupling for driving the MOSFETs, on the GATE pin, there are 3 components (2 resistors, 1 diode)connected to it, check them out.
                        Look up the spec of the MOSFET to get the pinout.
                        BTW, there are FOUR MOSFETs,
                        Too bad they install a jumper wire in place of the fuse F400 which feeds B+ to that inverter circuit.
                        • joeshannallie
                          • Dec 2013
                          • 103
                          • usa
                          Replaced the mosfet and it still has the same problem. When you first turn it on the Vizio logo will appear and then it is gone. But the screen seems to not light all the way up. Then a few seconds later the screen will light back up and then go right back off. You can turn it off and on with the remote. Does anyone have any ideas. Could it be the main board or a tab bond issue. If it was a tab issue would the screen stay lit and on?
                          • CapLeaker
                            Leaking Member
                            • 8150
                            the LCD and the backlight are 2 different circuits. Hook up your meter to the brown big 450V cap, turn the TV on and see what it does. It should have 170V then ramp up to 380V. That indicates the PFC is working.
                              So what happen to the MOSFETs and the Gate components testing?
                              • joeshannallie
                                • Dec 2013
                                • 103
                                • usa
                                Sorry Bud but I dont really understand how to test what you are telling me to test.
                                • CapLeaker
                                  Leaking Member
                                  • 8150
                                  That mosfet you changed out, download the data sheet and see on which pin the "gate" is. Look that up on your board. There are components inline. Resistors, diode etc that go back the driver IC. If a gate circuit component is bad, the mosfet simply won't work. Verify the resistor values, what's printed on it, to what it actually measures. So usually resistors either go open or get higher resistor value, that's bad. Diode usually shorts or gets leaky, that's bad too.
                                  Budm told you already what to check, read post #12 again. You may have to "lift" one leg to get good measurement out of circuit.
                                  • Jane
                                    How do you test MOSFET in laptops ?
                                    by Jane
                                    I tried to use this method:
                                    Testing an N-channel MOSFET:
                                    Step 1: Discharge the Gate (turn off the MOSFET)
                                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                    Step 2: Charge the Gate (turn on the MOSFET)
                                    Now, place the red probe on the Gate (G) and the black probe on the
                                    09-27-2024, 03:31 AM
                                  • Nooy
                                    VGA MOSfet permanently shorted and loss of MOSfet pad
                                    by Nooy
                                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                    02-14-2024, 02:26 AM
                                  • SS454
                                    vizio e650i-a2 backlight flashes then turns off
                                    by SS454
                                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                    panel: au optronics T650HVN05.4
                                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                    08-20-2020, 03:57 PM
                                  • AppleLover123
                                    Asus X712EA 3 volts after the first mosfet
                                    by AppleLover123
                                    Hey guys,
                                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                    Now i thought something...
                                    12-15-2024, 07:49 AM
