Dead Vizio VL 420M
  • CapLeaker
    Leaking Member
    • 8142
    Re: Dead Vizio VL 420M
    So you got a main board issue.
      One thing I do not know on this unit is the ACD signal (AC Detect), I do not know if it is normally HIGH or normally LOW.
      • Tayninh55
        • Sep 2011
        • 153
        Thanks to all of you for your instructions! Now, where do I go from here? I wonder why the set came on temporarily the way it did, and with a perfect picture (No Signal) on the screen? I turned it on and off several times, and it remained perfect each time, until it went off for the last time. Also, the yellow logo to white logo (when on button is pressed) still seems to be working, which it wasn't before at all, even though the screen doesn't lite up. This all happened instantly when I had the black lead on chassis ground, and then touched the red lead to (my number 5 pin on the smaller connector) the ON_OFF INVERTER. I did nothing else, and as the set is resting on the top of my pool table, nothing could have even moved as I was doing this. Another question, since all of this happened at the same time, why did the logo light not stop working again as it was in the beginning? Really appreciate your help!
        • Tayninh55
          • Sep 2011
          • 153
          Budm & Capleaker,,,,,,,,Since I have received no more replies to my thread, I guess I certainly was wrong when the picture came on and I thought I was getting lucky! Do you think I will be able to change a component on this board and fix it? Do you think I will have to get a replacement DPS-260JP A main power board to take care of the problem? Do you think the replacement board will solve my problem? Thanks!
          • CapLeaker
            Leaking Member
            • 8142
            On a second thought: look at the backside of the power supply and look for cold solder joints, also look at the pin connectors. Once you got squared away, leave the main board disconnected and force the power supply and the backlight on.
            • Tayninh55
              • Sep 2011
              • 153
              Cap,,,,,I know how to look for cold solder joints, but how do I "force the backlight on? What you mean is to disconnect the 6 pin and 12 pin connectors going to the 2nd board, and then turn the power on? The logo light shouldn't come on then because the on/off switch will be disconnected? Once I plug the 120V back on,,,,,how do I force the back light on? Guess I'm really a big dummy!
              • CapLeaker
                Leaking Member
                • 8142
                Well... sounds like something is intermittent. But what? Anyway... here we go:
                Unplug the ribbon cables going from the power supply to the main board. The only thing on the power supply that stays plugged in are the back lights. Now take a 1k ohm resistor from PSon to 5V Standby and another 1k ohm resistor from BLon (I think it is inverter on in your case) to 5V Standby. Plug the baby in and all the voltage rails should be up on the power supply and the backlight should be on as well. Now you can test nicely the output rails, let her rip and give her a few cycles as you wish. Hopefully the power supply never misses a beat. We are totally isolating PS and mainboard, "forcing" the PS manually on. As usual: Really watch what you are doing around the primary.
                • Tayninh55
                  • Sep 2011
                  • 153
                  I guess it doesn't matter which of the three standby pins I use? Ok,,,,,I'll give it a try and see what happens! Might be awhile before I get back to you on this, and thanks again!
                  • Tayninh55
                    • Sep 2011
                    • 153
                    • Tayninh55
                      • Sep 2011
                      • 153
                      I'm getting ready to solder in the resisters, but before I do, I have another question. Probably doesn't have anything to do with my problem, but do these look like they've been "hot", or do most just look like this?
                        I cannot tell from the picture if the inverter transformers were over heated or not.
                        What you can do for now is to force on the power supply first, no need for BL-ON force on yet, to see if the PFC Voltage is working or not first.
                        The Voltage on the main filter cap should go up to >360VDC, if it does, then you can do force the bl-on to see if the backlights will come on.
                        • Tayninh55
                          • Sep 2011
                          • 153
                          Cap, it didn't "blow up"! budm,,,,,too late, I already did the BL-ON force! The BL came on,,,,,,,should I still check the main cap for voltage, while the resisters are in place? What should I do next?
                          • CapLeaker
                            Leaking Member
                            • 8142
                            Did you check all the voltages? Try this setup a few times. No need to check the filter cap. PFC is working, otherwise you wouldn't have back light.
                            • Tayninh55
                              • Sep 2011
                              • 153
                              Well, I've left it on steady for about an hour and a half and the back lights are still going strong!
                              • Tayninh55
                                • Sep 2011
                                • 153
                                Cap, Do you mean "check all the pins again", while the resistors are hooked up?
                                • Tayninh55
                                  • Sep 2011
                                  • 153
                                  Ok, I presumed you did want me to check voltages on the pins so here is what I got. I really couldn't get a reading on any of them. On the twenty vdc range, with blk lead on chassis gnd, and red lead on the pin, none would hold a steady voltage, they all jumped from .01, .02, .03, .04, and then back to zero, then started over again. The only one that was any different was the DIM pin. When I touched this pin with the red lead,,,,,,,,,,,,,the back lights would blink off.
                                  • CapLeaker
                                    Leaking Member
                                    • 8142
                                    Like post 18. Lets see that all voltages that are there are good. Let her run some more, turn it off and on as you please. Anyway... I still think the problem is the main board.
                                    • Tayninh55
                                      • Sep 2011
                                      • 153
                                      When you say "Main Board", you are talking about "this board" aren't you, the one where the power cord plugs into? OK, I'll type it out for you!
                                      • CapLeaker
                                        Leaking Member
                                        • 8142
                                        no. that is the power supply. the main board is the other one with the HDMI, RCA jacks etc. (post #3). I just want to make sure that the power supply is good.
                                        • newtothis
                                          • Mar 2013
                                          • 1556
                                          • england
                                          #40
                                          Main is one with inputs like RF and HDMI etc
                                          EDIT ***Got there before me Cap ***
                                          • Iain P
                                            Vizio E65-F0 really dead
                                            by Iain P
                                            Hi everybody!
                                            I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                                            So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                                            I decided to check the voltages coming off the power supply they are as follows:
                                            connector CN201
                                            pin 1 (18vsb1)...
                                            02-23-2023, 11:32 AM
                                          • catnapped
                                            Dead Vizio D40u-D1
                                            by catnapped
                                            Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
                                            04-02-2024, 08:55 AM
                                          • fharris1977
                                            Vizio D50u-D1 Dead: PSU or Main Board?
                                            by fharris1977
                                            Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                            03-12-2024, 12:22 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
