Vizio e470va No Picture
  • at1105
    • Feb 2015
    • 27
    Re: Vizio e470va No Picture
    Originally posted by budm
    OK, the standby power supply is working and the main board is sending out the ps_on a and the bl-on, so now you need to check the dcV on the main filter cap's legs to see if it has >360Vdc on its two legs, you need that for the power supply to produce 12V for the main board and 24V for the inverter board.
    Do not touch anything with your hands or body.
    Both large caps on the middle of the power board are reading 389v.
      Good, so check and see if you do have 24V feeding the inverter board and 12V feeeding the main board, if not, remove the cables to the inverter board and check again to see if the 12V/24V are present.
      • at1105
        • Feb 2015
        • 27
        23.9v at the connector on the inverter board and 12.10v/23.9v at the connector on the main board.
          OK, now we need good clear pictures of the inverter board without the metal shield, you need to check the fuses on the inverter board.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Original post says the backlights initially display but no image, voltage at lower end of LVDS cable yet no power at tcon fuse either side, Is the cable passing signal ok?
            • at1105
              • Feb 2015
              • 27
              ok, now we need good clear pictures of the inverter board without the metal shield, you need to check the fuses on the inverter board.
              • newtothis
                • Mar 2013
                • 1556
                • england
                #27
                F1
                • CapLeaker
                  Leaking Member
                  • 8146
                  How did we go from a main board LCD problem to a backlight problem? I thought the backlight is working fine?
                  • at1105
                    • Feb 2015
                    • 27
                    no voltage on the fuse
                      • 12156
                      • U.S.
                      #30
                      wonder if the mainboard is sending proper signal to tcon?
                        • 12156
                        • U.S.
                        #31
                        could be bad cap on inverter maybe?
                        • at1105
                          • Feb 2015
                          • 27
                          Yes. Backlight works perfect. Just not getting a display.
                          • CapLeaker
                            Leaking Member
                            • 8146
                            You got to figure out why the main board isn't properly turning on. I bet, if you would check the LVDS cable with an oscilloscope right now, there wouldn't be any signal either.
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #34
                              This is what I am thinking
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                #35
                                Are you using your meter correctly as when the backlights are on you WILL have voltage at that fuse
                                  That what I thought in the first in post 1 but some how I thought we lost the 24V and the 12V which nay be why one of the regulator on the main board shows <0.050V).
                                  Now we do not know if the meter is good or if it is being used correctly.
                                  The 24V should be at the fuse if he does have backlights, this is really frustrating and confusing when we do not get correct readings.
                                  • CapLeaker
                                    Leaking Member
                                    • 8146
                                    amen!
                                    • at1105
                                      • Feb 2015
                                      • 27
                                      Apparently my meter skills are lacking severly in this dept. I was checking it with the positive lead on one side and the neg on the other. I'm assuming that was incorrect as I put the negative lead on the ground wire coming in on the inverter board and the positive at the fuse and got 24v on both sides. is that correct?
                                      • at1105
                                        • Feb 2015
                                        • 27
                                        • CapLeaker
                                          Leaking Member
                                          • 8146
                                          which fuse on what board? Just trying to keep things straight. To test the fuse, put the negative lead to chassis ground and the positive lead on each side of the fuse. DMM in DC setting.
                                          • PNI E.
                                            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                            by PNI E.
                                            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                            02-20-2025, 08:36 AM
                                          • koby058
                                            vostro comes up with back light but no picture
                                            by koby058
                                            Hi people!!
                                            The owner said it showed bad picture once in a while (attached)
                                            I see that there is back light but no picture.
                                            I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                            Also attached schematic and BDV
                                            LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                            07-13-2025, 01:03 PM
                                          • nsab6464
                                            Vizio P502ui-B1E power light turns on, but no picture
                                            by nsab6464
                                            Hey guys,
                                            I have a Vizio P502ui-B1E with no display activity at all with the power light on. It broke in a very specific way, and now exhibits strange behavior when turned on (slow response to power off command, restarts every 90 sec, more below), so I'm hoping that someone with experience working on this TV can point me in the right direction.
                                            I already tried the 2 most common fixes with no luck:
                                            - Replacing the T-Con board.
                                            - Re-flashing the firmware on the U202 chip (from here: https://www.badcaps.net/forum/showthread.php?p=840012)
                                            Here's exactly...
                                            06-21-2019, 12:25 AM
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
                                          • kca
                                            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                            by kca
                                            Hello all ~
                                            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                            No picture. No sound.
                                            I tested all the voltages coming out of the power supply...
                                            10-12-2023, 05:23 PM
