Vizio e470va No Picture
  • at1105
    • Feb 2015
    • 27
    Re: Vizio e470va No Picture
    which fuse on what board? Just trying to keep things straight. To test the fuse, put the negative lead to chassis ground and the positive lead on each side of the fuse. DMM in DC setting.
    The fuse on the inverter board. Sorry I was checking it incorrectly. I assumed you could check it across the fuse at each end but I was wrong. Yes, it has 24v.
    • at1105
      • Feb 2015
      • 27
      RECAP of Measurements:
      Power Board
      Out to Inverter: 24v=Yes, On/Off=Yes
      Out to Main Board: 24v=Yes, 12v=Yes, 5v=Yes, PS-ON= Yes
      Large Filter Caps= ~Good~ reading was >360Vdc
      Inverter Board
      Backlight On: Yes
      Fuse: ~Good~ measured 24v
      In from Power Board: 24v=Yes, On/Off=Yes
      Main Board
      In from Power Board: 24v=Yes, 12v=Yes, 5v=Yes, PS-ON= Yes
      Out to T-Con: 5v=yes
      Volt Regs Outputs:
      U103 - (G9084) = 5.02v,
      U608 - (17809 0501) = 5.07v,
      U704 - (M171 1117-18) = 3.28v,
      U706 -(M189 1117-33) = 1.77v
      T-CON
      In from Main Board: 5v = yes
      Fuse: Good 5v on each side.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        O.k. So power supply and the inverter board are good.
        What are the voltages on all 3 pins on U103, U608, U704 and U706 on the main board?
        Then there could be a bad eeprom or some other wired fault that requires replacing the main board.
        • at1105
          • Feb 2015
          • 27
          These are the reading I got...
          U103
          Pin 1 = 5.08v
          Pin 2 = 5.08v
          Pin 3 = 4.68v
          U608
          Pin 1 = 4.68v
          Pin 2 = 0v
          Pin 3 = 5.08v
          U704
          Pin 1 = 5.08v
          Pin 2 = 3.29v
          Pin 3 = 1.77v
          U706
          Pin 1 = 5.08v
          Pin 2 = 1.77v
          Pin 4 = 0v
            U103
            Pin 1 = 5.08v
            Pin 2 = 5.08v
            Pin 3 = 4.68v
            U608
            Pin 1 = 4.68v
            Pin 2 = 0v
            Pin 3 = 5.08v
            U704
            Pin 1 = 5.08v
            Pin 2 = 3.29v
            Pin 3 = 1.77v
            U706
            Pin 1 = 5.08v
            Pin 2 = 1.77v
            Pin 4 = 0v
            Also from post 42
            The readings are invalid.
            • at1105
              • Feb 2015
              • 27
              Originally posted by budm
              Also from post 42
              I must be grounding my lead wrong. What is the proper ground point for the neg lead when reading the volt regs?
              • at1105
                • Feb 2015
                • 27
                Also from post 42
                I was grounding at the wrong location. Sorry for being an idiot. I'm still learning. Here's what I got...
                U103
                Output tab = 0v
                Pin 1 = 0v
                Pin 2 = 0v
                Pin 3 = 0v
                U608
                Output tab = 0v
                Pin 1 = 0v
                Pin 2 = 0v
                Pin 3 = 0v
                U704
                Output tab = 1.80v
                Pin 1 = 0v
                Pin 2 = 1.8v
                Pin 3 = 3.32v
                U706
                Output tab = 3.32v
                Pin 1 = 0v
                Pin 2 = 3.32v
                Pin 4 = 5.12v
                • at1105
                  • Feb 2015
                  • 27
                  What would cause U103 and U608 to not have any voltage?
                  • jeffer76
                    • Sep 2011
                    • 76
                    • US
                    #49
                    Check for open fuse on main board. (F701)5amp
                    • PNI E.
                      tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                      by PNI E.
                      hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                      02-20-2025, 08:36 AM
                    • koby058
                      vostro comes up with back light but no picture
                      by koby058
                      Hi people!!
                      The owner said it showed bad picture once in a while (attached)
                      I see that there is back light but no picture.
                      I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                      Also attached schematic and BDV
                      LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                      07-13-2025, 01:03 PM
                    • nsab6464
                      Vizio P502ui-B1E power light turns on, but no picture
                      by nsab6464
                      Hey guys,
                      I have a Vizio P502ui-B1E with no display activity at all with the power light on. It broke in a very specific way, and now exhibits strange behavior when turned on (slow response to power off command, restarts every 90 sec, more below), so I'm hoping that someone with experience working on this TV can point me in the right direction.
                      I already tried the 2 most common fixes with no luck:
                      - Replacing the T-Con board.
                      - Re-flashing the firmware on the U202 chip (from here: https://www.badcaps.net/forum/showthread.php?p=840012)
                      Here's exactly...
                      06-21-2019, 12:25 AM
                    • gavric
                      Vizio M70-C3 Half picture is bad, main board on its last leg?
                      by gavric
                      Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                      When tv powers on vizio V logo shows nice on whole screen. picture 1
                      When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                      When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                      When i click video to start playing picture goes black(like when you change...
                      09-02-2021, 08:55 PM
                    • kca
                      Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                      by kca
                      Hello all ~
                      I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                      This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                      No picture. No sound.
                      I tested all the voltages coming out of the power supply...
                      10-12-2023, 05:23 PM
