diah…I’m really sorry but I can’t remember. What I can say you it s before all your help, the tv was no image but no black black because there were lights from the back light, in some point more than other. When I put the jumper with the right side off and the left side on, there were no big changes always dark but with light on and in some point more light. When I unplug the left side and plug the right side, I saw a perfect image on the right side, and I remember very clearly that the other part now were more uniform, I don’t remember if white or black, but I remember it was all the same not with spots with more lights
tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
So I have to disconnect the dark flat and with the jumper on I check the image….guys I wrong….i didn’t think the pad could take off, tomorrow I ll try before to mask again the flat and see if I have changes maybe I change the size of the tape, if I don’t have changes I try to solder again a jumper on the sock of the ribbon flat…Broke for broke I try..and after we ll see at least I can buy a new tcon board…
Hi guys I tried to mask the right ribbon, also with different size of tape but nothing it s no picture. So I make some measure on the tcon and buffer board I give u the pictures with the valor. I did with the ribbon plugged in and with the ribbon of the right side unplugged. Do u suggest to try to make again the jumper and this time I have to make on the socket of the ribbon because I broke the pad….what you suggest? I tracked the fbbew that is still ok and it s the first pin the nearest on the socket. Do you think I have to connect this with the first pin the nearest near the brocken pad on the other side? Because that I can’t track because I break but I think it s the first pin near the Brocken pad. Thanks for your helpComment
diah sorry i broke everything haha some tin went on the socket and put all in short i tried to clean the mess but...im sorry i make all of your lose your time. but i dont give up, i buy a new tcon and when it comes we start again hope i learn the lesson. can i buy atcon with the same code or must be from the same tv?Comment
hi guys I’m back, I know like a nightmare. I bought from china the tcon, because it were cheap like 25 dollars, so I didn’t give up…so if u still let me you an help I ll be really really thankful.
now I made the jumper again, this time I used a nice really small wire, so I didn’t make a disaster. After make the jumper, with the right ribbon plug off and the left plug in I don’t have nothing in the screen. If I unplug the left sid and plug in the right side, for the first 20 30 seconds I don’t have pictures, but the screen changes. Now it’s black on the right side and white with grey orizontal lineon the left side. After 20 30 seconds I have audio and picture on the right side and in the left I have white with grey orizontal line. The orizontal line goes also on the right side where we have the picture, but it s not so bad.
so I put the photo so you can see all, and if u have any idea how to go forward I will listen you. So please help me thanks to all
Hi guys, so I put the tape on the buffer flat, and I have picture, it s not so nice picture because I have all light on the bottom of the display but I think I can't make better, or do u think I can do something for make it better? Thanks for all the support you are all great. If someone have some idea how to have a better image I'm hereComment
so you mean it s a back light problem too….it s really trash hahaha…thanks iotas for your help, u and diah helps me a lot. I think I don’t try to change the back light because the panel it s no frame…so I think the panel is on with tape? I never take of a panel without frame I think it s a little too much for my ability haha
i think it will be in the trash...a little sad because the tv was 900 euro of tv....but change backlight in that type of dispaly without frame, it s a really harrd job and then maybe also the diffuser is gone...it stay in this way still a little until i buy a new tv thanks for allComment
Hi All,
Need help.
I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard.... -
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by iglitareHi,
Or is it always a bad/shorted... -
by koby058Hi people!!
The owner said it showed bad picture once in a while (attached)
I see that there is back light but no picture.
I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
Also attached schematic and BDV
LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590... -
by slimsoulHi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power... - Loading...
