This Time.. It's Personal.. Samsung UN60ES7500 Constant reboots
  • Michale32086
    • Nov 2011
    • 1453
    I came across a Samsung UN60ES7500.. 60" LED Smart TV 3D...
    I talked my wife into trading our own Vizio 60" LED Smart TV sans 3D for it..
    I ran it at my shop for 18 hours straight... Never a hiccup... I ran a small blurb of a 3D MP4, just to check out if the 3D was passive or active.. Not a problem at all..
    Brought it home and we did the trade...
    That night, with our HTPC hooked to the new acquisition we watched MIKE AND MOLLY plus I played a few videos.. Everything was fine..
    Fri night was the big night. I borrowed a couple pairs of Samsung Active 3D glasses from our son.. Put on NOAH in 3D...
    TV said it needed to update.. OK.. Let it do that..
    Disaster strikes.. It appeared to reboot in the middle of the update... Now it won't run for more than a few minutes before the screen scrambles with all sorts of pretty colors and geometric shapes.. Reboots over and over again..
    Unplug it... Let it sit over night... Next day.. Same thing...
    Wife has murder in her eyes...
    OK, so I get back from work tonight figuring a firmware update will fix it.. Try an update from ONLINE and USB.. TV doesn't last long enough to do the update before it reboots... I unplug everything but power.. Retry the update.. Still reboots...
    Wife says "I know where you sleep"... I'm scared...
    Am I looking at a replacement board?? Any master reset possibilities??
    Any help would be appreciated...
    EDIT: One thing I forgot to mention. There is a new icon I never saw before. This appeared to appear after the initial failed update in the lower left corner.. Not sure what it means..
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: This Time.. It's Personal.. Samsung UN60ES7500 Constant reboots
    don't know if this will work on the smart tvs or not and first off even if it was a failure of software or hardware that caused it. this worked on the newer sammys before the 3d came out
    1 ensure the usb is not inserted in slot, and probally disconnect from the internet so it cant try from there, unplug for 30 seconds.
    plug the usb drive in the slot with software loaded
    2 plug set into outlet while youpress and hold the power button for two or three seconds before releasing it.
    3 it should have found and start inserting the update.
    if not I would say a new mainboard is in order. there use to be a way to force an update but I don't think it works anymore. special software thru a usb link to a pc. a sop near here used to do them when they was Samsung warranty center now they deal in visio and Phillips I think.
    • Michale32086
      • Nov 2011
      • 1453
      Thanx for the info, Awyatt2. I'll give that a try..
      EDIT: No luck. It just powers up normally.
      • Michale32086
        • Nov 2011
        • 1453
        Any idea what that Icon is??? It appears now everytime the TV is powered up..
        • selldoor
          Slow Learner
          • 7870
          It means the wife is going to give you hell for some time or RTFM
          P28
          http://www.manualslib.com/manual/416...page=28#manual
            Could be related to the issue I am having on a 46" ES8000?
            https://www.badcaps.net/forum/showth...ght=ue46es8000
            https://www.youtube.com/watch?v=TEac...e&noredirect=1
            • Michale32086
              • Nov 2011
              • 1453
              P28
              Awww crap, now the wife is going to REALLY give me hell. She said it looked like some sort of voice control icon..
              Thanx for the link SD.. I did a search for "Chat Icon" but came up empty..
              • Michale32086
                • Nov 2011
                • 1453
                Originally posted by tom66
                That's EXACTLY what mine does, Tom..
                I plan on pulling mine off the wall tomorrow and pulling the back cover.. I'll check the connector from that PDF...
                Thanx for the info..
                • selldoor
                  Slow Learner
                  • 7870
                  Anyway when you have stopped shouting the the tv maybe something here might help
                  http://www.avsforum.com/forum/166-lc...nfo-how-s.html
                  http://www.avsforum.com/forum/166-lc...0-15-mins.html
                  QUOTE - Not me!!
                  I had the same problem where it turned off and on every seven minutes.
                  I fixed this by resetting smart hub to its defaults, and resetting the TV to its defaults, done by opening the menu and navigating to the right location. The smarthub reset was probably unnecessary, but I had nothing to lose.
                  After the reset of the TV, my TV has worked fine.
                  Hope this helps.
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Awesome!! This just might save my life!!
                    I don't have to worry about my marriage. It's strong..
                    But my wife murdering me in my sleep?? That could become an issue.
                    Thanx!
                    • Michale32086
                      • Nov 2011
                      • 1453
                      WOW.. Reading thru those threads, it looks like these Samsungs do not have a sterling rep...
                      Strange.. I have always thought of Samsung TVs as top of the line, quality wise...
                        My opinion of Samsung is that they are overpriced, yet built right down to a cost. So you pay for premium quality but they cut too many corners. Panels failing, main board faults, etc. Their LCDs have good pictures for LCDs, and their plasmas (while they still made them!) were only second to Panasonic -- but again, due to the corner-cutting, it's hard to give them a positive recommendation.
                        • Michale32086
                          • Nov 2011
                          • 1453
                          I guess the fact that I see so many Samsungs come thru my shop for repairs is a testament to what you are saying...
                          • selldoor
                            Slow Learner
                            • 7870
                            Something else to try
                            https://www.youtube.com/watch?x-yt-c...-ts=1421914688
                            • Michale32086
                              • Nov 2011
                              • 1453
                              That looks promising as well... Thanx SD...
                              • drussell
                                • Nov 2014
                                • 144
                                I agree with tom66, the picture quality tends to be pretty good but the build quality?
                                • Kilroys
                                  • Feb 2014
                                  • 70
                                  • Sweden
                                  I guess it all started after you made an update. The software allowed the motion control to be enabled, so turn it off.
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    I'll give that a shot as well...
                                    Thanx
                                      • 31071
                                      the matrix has you!
                                      i'l be damned if i ever own a samsung product with an internet connection!
                                      you(or some other person/government) can access the camera or mic remotely - probably even in standby.
                                      atleast you can when it works.
                                      given samsung fucked it, why not mail them?
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Originally posted by stj
                                        the matrix has you!
                                        As long as it pays my mortgage, I'm good with that..
                                        • Alper99
                                          Samsung QN75QN800AF doing constant reboots, and click sound from Connect One device.
                                          by Alper99
                                          So here is the thing. Someone from a rich neighborhood posted a sale on a broken Samsung. It was doing re-boot all the time.
                                          A web search revealed a very quick fix, so I bought it TV for $100.
                                          First move was to get a new used Samsung Connect Box​ but there was no change on error.
                                          I opened up the device, and what I saw was way different on what was on YouTube videos, in terms of complexity.
                                          Now, I can replace all 3 board onboard, and give it a go, but that may also be a waste of money. I can get all components for $150
                                          Below is the video of what...
                                          10-04-2024, 08:00 AM
                                          09-07-2024, 05:50 AM
                                        • x_orange90_x
                                          Samsung UN50KU6300F constant reboot, bad backlights?
                                          by x_orange90_x
                                          This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
                                          02-09-2024, 08:41 PM
                                        • Grunder
                                          Samsung UA55NU7100 2 blinks then reboots
                                          by Grunder
                                          Hi please some assistance with my Samsung UA55NU7100 that is stuck in reboot.
                                          I've read the post by Itelite on a Samsung UA65NU6900 with the same problem but this main board is different and doesn't have the 25v VGH voltage which was the problem that he had.
                                          There is no legend indicating voltages on the socket/ cable going to the main board just a link marked 11.80 volts. This voltage reads 12.71v. Pins 3 to 9 also 12.71v. Pins 2,6,8,10,11 & 12 all 0.0v. Pin 1 fluctuates 3.01 to 0.0 volts and pin 4 fluctuates 3.25 to 0.0 volts.
                                          The cpu gets very hot after 10...
                                          01-26-2024, 07:43 AM
                                          Samsung ATIV NP915S3G Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung ATIV NP915S3G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP915S3G boardview and NP915S3G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung...
                                          09-06-2024, 05:27 AM
