Samsung QN75QN800AF doing constant reboots, and click sound from Connect One device.
  • Alper99
    • Oct 2024
    • 9
    So here is the thing. Someone from a rich neighborhood posted a sale on a broken Samsung. It was doing re-boot all the time.
    A web search revealed a very quick fix, so I bought it TV for $100.
    First move was to get a new used Samsung Connect Box​ but there was no change on error.
    I opened up the device, and what I saw was way different on what was on YouTube videos, in terms of complexity.
    Now, I can replace all 3 board onboard, and give it a go, but that may also be a waste of money. I can get all components for $150
    Below is the video of what is going on when It is powered.
    https://www.icloud.com/photos/#0bfUy...OYO5RnMMgmZWrg
    What should be my next step on fixing this.
    I plan on using it since this is a fancy one.
    Thanks in advance for your time and thoughts!
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    Rebooting generally means a panel fault. Which isnt fixable. But sometimes we can get lucky on these tvs. As a note, don't ever buy a rebooting Samsung again for $$ unless you need something on them specifically.
    On these qleds we can sometimes get lucky
    Take a picture of the buffer boards at the bottom of the TV with clear pictures. It's the long strips at the very bottom, post a picture of all of it which will be a few pictures.
    This will be a start.
    • Alper99
      • Oct 2024
      • 9
      Thanks a lot!, here they are;
      https://www.icloud.com/photos/#067F2...5R3tBEZ8p8ih5Q
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        Now there is a yellowish ribbon that connects those buffer boards one on the left side and one on the right side. Undo the far left side ribbon and take it off Don't leave any bits hanging and then plug the TV in and turn it on and see if you get 3/4 of a picture. If it's still rebooting unplug the TV plug that ribbon back in and then try the right side and unplug that ribbon and see if you get 3/4 of a picture when you plug it in then. Make sure you're not unplugging those ribbons while the TV is plugged in. It's the yellowish ribbons not the ones coming from the main board in the middle. Let us know if anything happens, sometimes this test doesn't work but let's see
        • Alper99
          • Oct 2024
          • 9
          Yes, removing far left got a 3/4 of a picture and stopped the reboot process.
          • Alper99
            • Oct 2024
            • 9
            ok tried to tape the ribbons to block the short,and must have done something wrong since screen is all colored lines at the moment. I am guessing I will be heading to recycling tomorrow.
            • EazyBone
              • Jun 2023
              • 1347
              • United states
              Sorry for late response.. yes if you got 3/4 then yes panel short. I would take the boards out and the one connect boxes and resell them on eBay. They fetch a pretty penny. Also that cable for ocb also.
              Try the 3/4 picture again see if lines are gone. Sorry to hear 🥺
                09-07-2024, 05:50 AM
              • KYBOSH
                Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                by KYBOSH
                I picked this one up today.
                Previous owner says no signs of life.
                TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                The TV model is QN65LS03BAFXZA - version: CB06
                The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                Will keep you all...
                04-05-2025, 08:32 PM
              • atkallu
                Samsung One Connect Box SOC1001N vs SOC1004N
                by atkallu
                I am asking have somebody information about Samsung one Connect boxes compatibility ?
                So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
                SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
                Boxes part numbers are the same: BN68-08730A-00.
                07-09-2025, 01:54 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
