LG 42LD550 Won't turn on
  • selldoor
    Slow Learner
    • 7870
    #41
    Re: LG 42LD550 Won't turn on
    Just wondering if you have tried pressing the green button - think it is a reset switch.
    As you are talking replacement then maybe worth trying.
    • capndirk
      • Apr 2017
      I have the exact same TV with the same problem as the OP. My TV was a refurb originally, and when the problem developed (8 years later), I opened it up and found all the board screws quite loose, as in 2-3 turns. The main board has arcing and sparking evidence on the solder patches on the underside at the mounting holes meant to make contact with the metal shroud. There is no other evidence of faults, and securing the boards didn't fix it. So, I'm thinking the intermittent ground scrambled the on/off circuit processor. The green button, incidentally, is a manual on/off switch, not a reset.
      The on/off circuit works to a point; that is it turns off the "ready" LED momentarily, then flashes red, which must mean error, since on is a steady blue. The connector for the blue LED doesn't read power in the on mode. The switches or remote will turn the TV off to "ready" mode, again.
      All the tests done by the OP are the same on this one, except I didn't try jumping the "inv on" terminal.
      Any tricks to bring the thing back?
      • doug6644
        • Dec 2017
        Anymore info gathered, or did this get dropped?
          Are you having the same exact problem (no BL-ON) as the OP or something else?
          • JDMugenBB1
            • Jan 2017
            • 20
            following... my father in law was given the same TV and no picture no sound... just red blinking stand-by light.
            • julianmustofa
              Asus x453ma only turn on when plugged in (battery was fine)
              by julianmustofa
              Hi all
              Iv'e been working on asus x453ma that only turn on when the ac adapter connected
              The battery itself was fine
              So this is what happen
              -plugged ac adapter
              -trigger power button
              -laptop turning on
              -unplug the ac adapter
              Laptop still on with battery
              -without ac adapter
              And nothing happens
              Have no idea what is going on
              Charging sistem still works when laptop is turning on
              And also when battery reach 100% the charging indicator still red. It should turn white/green...
              10-18-2023, 01:48 PM
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
            • robante15
              Acer Aspire 4520 won't turn on after reboot
              by robante15
              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
              If I remove the...
              04-06-2024, 06:50 PM
            • masoksian
              Dell latitude e7470 not turn on .power buton on off and Run Power problem
              by masoksian
              I am dealing with the problem of turning on and off my Dell e7470 notebook.
              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
              The system does not turn on, there is no post.
              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
              The problem continues in the same way.
              I tried to turn on the Fn key, nothing came to the screen....
              02-15-2025, 12:08 PM
