What frequency limit I should plan for when choosing oscilloscope for TV repair?
  • Uniballer
    • Jul 2013
    • 334
    Re: What frequency limit I should plan for when choosing oscilloscope for TV repair?
    As the others said, you can do a lot with a 100MHz scope. I think that is a good place to start.
    Originally posted by lookimback
    So, if I found something that was 500mhz, it would work for any signal 0 to 500mhz right?
    Not exactly. A 500MHz scope can display a 500MHz sine wave. You will need a lot more bandwidth to display a nice 500MHz square wave. A square wave is made up of the primary frequency plus its odd harmonics. You will start seeing something square-ish when the bandwidth is about 5 times the signal frequency. 10 times would be better.
    Also, beware that many early digital storage scopes have low sample rates. For example, many early TEK and HP storage scopes have 100MS/s rates with higher bandwidth front ends. A scope like this needs to sample a periodic waveform repeatedly to show anything useful near the scopes bandwidth, so it is only useful for non-repeating signals at much lower frequencies. You generally need to sample at 4 to 10 times the frequency of your signal for non-repetitive signals.
    Don't forget that the probes you use have a lot to do with what you see. The cheap 100MHz probes from ebay are fine for general purpose troubleshooting and seeing low speed signals, but to make good use of a 500MHz scope you will need serious probes, and they are not cheap. Even real TEK or HP 500MHz passive probes often may not show you what you want to see because of probe capacitance, etc.
    • Uniballer
      • Jul 2013
      • 334
      Originally posted by keeney123
      What does everyone think about the Tektronix MDO3000 6 in 1 scope.
      Haven't used one myself, but the word on the street is that certain other products have more bang for the buck (did that phrase originally refer to guns, or hookers?).
      EEVblog #587 – Tektronix MDO3000 Mixed Domain Oscilloscope Teardown
      Dave Jones on MDO3000 #thumbsdown
      • lookimback
        • Aug 2013
        • 1489
        Thank you all for the help on this. I definitely didn't have a clue before, and now I got a good idea of what to look for.
        ------------signature starts here------------
        • lookimback
          • Aug 2013
          • 1489
          I think I'm going to get a Rigol DS1052E since it can be easily software hacked to be 100mhz. I'm thankful for everyone's input on this. If not for the advice, I would probably have gotten a 500mhz scope (thinking I needed more bandwidth), and probably would have ended up spending more on probes than on the scope. I did also have my eye on a Tektronix TDS1012. It's a nice compact scope, and the one I was watching came with original Tektronix probes. However, the deal breaker there was memory constraints. I may have gone with it if there were some hardware hack to increase memory, but there seems to be no such thing. In any event, the Rigol is less expensive and brand new, not to mention way more memory and features.
          • capkid
            • Oct 2010
            • 1339
            I've had the Rigol DS1052E for a couple years. For the limited use I get out of it, it works well. I applied the hack to boost it up to 100 MHz - made a big difference.
            LG Plasma Mal-Discharge Correction Service
            • lookimback
              • Aug 2013
              • 1489
              I wish I could get the DS2202, but that's about 4 times the price. I think for what I need, it will work. Scopes seem to retain value too, so maybe I'll learn on this and then upgrade in 6 months or a year, and sell this back on eBay.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Just think 30 years ago a 75 MHz tektronix scope cost $12,000. One could get a Hitachi for $3,000 that would do the same thing. $100 or $200 for a 100 MHZ scope what a deal.
                  Why would you get a 1052E when $70 more gets you a 1054Z which is MUCH more powerful...?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Because you can get a used 1052e for $225-250 where you'd likely have to purchase the 1054z new.
                    • lookimback
                      • Aug 2013
                      • 1489
                      Yes, and I don't think you can hack the 1054Z.
                      • lookimback
                        • Aug 2013
                        • 1489
                        OK, I see you can hack the 1054Z. I may just get that one instead then. I was already looking at new 1052Es anyway. Price isn't that much different.
                          Yes, you can fully upgrade the 1054Z hence why it is so popular. I have the 1074Z, it has been upgraded to 24Mpt memory, serial bus analysis, 100MHz B/W, play/record segmented memory, etc.
                          • lookimback
                            • Aug 2013
                            • 1489
                            It is a bit of a jump in price. I could get the 1052E now, the 1054Z I'll definitely have to wait a couple more weeks, maybe a month. But, my plan was to be patient and make this a well thought out decision.
                            http://www.ebay.com/itm/Rigol-DS1052...item2592d3e1a9
                            http://www.ebay.com/itm/RIGOL-DS1054...item2c8f81eb25
                            • lookimback
                              • Aug 2013
                              • 1489
                              Looking at completed listings though, I see that sometimes they go for $400.
                              http://www.ebay.com/itm/Rigol-DS1054...item4d2a089c51
                              • lookimback
                                • Aug 2013
                                • 1489
                                I see what it is. Everyone is out of stock, and there's like a 4 to 12 week lead time.
                                  Yep Rigol is struggling to keep up with the demand - it's an amazing instrument given the price. You might have to spend a little more and get a 70MHz version if you really want it. But IMHO, not worth getting 1052E now, given the specs of the 1054Z, you get far more:
                                  - 4 channel vs 2 channel
                                  - intensity graded display
                                  - fast waveform update
                                  - large widescreen display, 7" vs small 5.7" display, higher resolution too
                                  - 24Mpt vs 1Mpt memory
                                  I really like the segmented memory. You can set scope to record power rail and say BL on/off signal, see if the dip in the power rail corresponds with BL signal dipping, things like that - it will record over days if necessary. I have used this before on a plasma. Could see the Vscn dipping out then TV shut down (old Panasonic panel), but was only really intermittent, so hard to track down with a normal trigger. That was enough info to say SC was at fault vs D/A/P boards.
                                  • lookimback
                                    • Aug 2013
                                    • 1489
                                    I'm sold. The 2 extra channels and larger screen alone got me. But all the other added features, and I've seen teardowns of Rigol equipment on EEVBlog, they make some nice high quality stuff. One thing I've really learned from this is that, considering the cost of these new scopes, it's no longer even worth buying the old ones anymore. Considering what they sell for (they aren't going for $50 anymore, that's just about the average for shipping), and then you usually have to buy your probes separate, you could pay an extra $100 and have a Rigol with 100 times the functionality.
                                      Try and get a supplier that throws in four probes instead of just two -- I know some of them do.
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        I saw one that does that, but they have a 12 week lead time. I'm wondering if they'll still be including 4 when it's in stock.
                                        • Uniballer
                                          • Jul 2013
                                          • 334
                                          When enough people are paying attention and notice this it will drop the price of the older equipment, except maybe for collectors.
                                          • iulik17d
                                            Intel Arc A380 videocard power limit remove - BIOS needed
                                            by iulik17d
                                            Hello everyone!
                                            The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                                            The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                                            01-10-2025, 02:33 PM
                                          • Tarot Superstars
                                            How not to Damage an Oscilloscope
                                            by Tarot Superstars
                                            Hello.
                                            I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                                            I want to learn how not to damage it, and I found instructions on the internet obscure.
                                            They talk about ground, earth, floating ground, this, that....
                                            But they don't actually say anything anything useful so far.
                                            I want to know:
                                            Don't connect exactly this to exactly there or it blows up.
                                            For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                                            I want to know what not to connect...
                                            08-29-2023, 02:27 PM
                                          • Evets
                                            Dynamco analogue oscilloscope
                                            by Evets
                                            I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                                            08-30-2024, 06:54 AM
                                          • Bradbeat
                                            TPS51225CRUKR Voltage limit
                                            by Bradbeat
                                            I have a PGOOD pin down on this chip and I’m wondering if it could be because there is 5,2 v on VREG5 ( the high limit according to the datasheet is 5,1v ).
                                            if yes, why is it to high?
                                            the motherboard board is LA-G881P.
                                            thank you.
                                            here is some measurements :
                                            • VIN = 16,3 V
                                            • VREG3 = 3,299 V
                                            • VREG5 = 5,203 V
                                            • SW2 (repos) = 3,423 V, pikes at ~16,4 V
                                            • VBST2 = 8,592 V → VBST2 − SW2 = ≈ 5,17 V
                                            • VO1 = 5,28 V (stable)
                                            • EN1 = 3,08 V, EN2 = 3,04 V
                                            • VFB1/VFB2 ≈ 2,1 V
                                            09-18-2025, 05:07 AM
                                          • SolomonMan
                                            Vintage BK Precision 1403 Oscilloscope....
                                            by SolomonMan
                                            All,
                                            Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                            Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                            I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                            12-03-2023, 10:39 PM
