How not to Damage an Oscilloscope
  • Tarot Superstars
    • Aug 2023
    • 60
    Hello.
    I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
    I want to learn how not to damage it, and I found instructions on the internet obscure.
    They talk about ground, earth, floating ground, this, that....
    But they don't actually say anything anything useful so far.
    I want to know:
    Don't connect exactly this to exactly there or it blows up.
    For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
    I want to know what not to connect it to. The instructions on the internet have no precise instructions and they were too general.
    I have read things on the difference between negative, ground, and so on, and I still don't understand it.
    Could someone just spell it out for me.
    How not to blow up the oscilloscope.
    I figured, just measure the voltage with a multimeter and check the maximum voltage and current rating for the oscilloscope before using the oscilloscope, but then the internet says something about ground that makes this idea seem useless.
    Background on me:
    I completed a short video course (~25h) on electronic repair. I have a physics BSc. I have dabbled in electronics since I can't remember, I have read a few electronics and radio books, but never took a proper certified course. I wouldn't say that I understand even 1/20th as much that a good electronic engineer does.
    • 31267
    Re: How not to Damage an Oscilloscope
    dont connect the scope probe ground clip to anything other than ground on what you test.
    thats the main thing - be carfull with psu's that the output ground really is ground.
    someone can post a like to the eevblog video i hope
    and always keep your probe(s) set to x10
    • harp
      • Jun 2022
      • 645
      • Planet Earth
      There is eevblog video about this
      https://www.youtube.com/watch?v=xaELqAo4kkQ
      but I am very sure that you see it already
      Yes, the problem is with ground, and to help save your equpment in lab is using some isolation transformer 1:1 ratio. But, if you measure two chanel simultaneously, the ground must be the same, not different potencial.
      Be avare of hot and cold ground also, it is different.
      Before you put ground clip on whatsoever, you may measure voltage between to be sure that is the same potential.
      Also, if you living from repair, it is also handy to have battery scope near by.
      https://www.youtube.com/watch?v=-A21ORLuVVc
      • Tarot Superstars
        • Aug 2023
        • 60
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8344
          Or a differential probe.
          • Prott
            PS5 - long screw damage, via to ground layer short?
            by Prott
            Hello dear Badcappers,
            I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
            Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
            07-27-2024, 08:54 AM
          • M1ch4L
            Lenovo Ideapad S145-15IWL Model 81MV Water damage.
            by M1ch4L
            Hello.
            First, I would like to extend my wishes for a Happy New Year to everyone.
            ... so I got this notebook for repair. The ntb is not turning on. A small amount of water was spilled on the keyboard and I found only 2 dried spots, patches on the motherboard. One around Mosfet PQ5302 but is not damaged and the second on JEDP1 connector.
            I measured:
            Mosfets:
            PQ5301 PIN:4 25,35V
            PQ5908 PIN:5 GT_PH shorted to the ground
            PQ5902 PINs 1-4 shorted to the ground
            Coils:
            PL5901 shorted to the ground
            PL5902 shorted...
            01-05-2025, 01:43 PM
          • DJbapt59
            Asus Vivobook x421a
            by DJbapt59
            I recently picked up a laptop that was about to be thrown away to try to repair it. I've tested quite a few things, but I don't know where to look anymore. Could you please help me?
            Brand: Asus Vivobook
            Motherboard reference: x421da, Rev 2
            Context:
            The person who gave it to me mentioned it might have been exposed to water, but they weren't sure. After opening it up, I couldn't find any signs of water damage or oxidation on the motherboard.
            The first thing I did was to connect the PC to a power supply: 19V stable and...
            01-24-2025, 05:34 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • av4x
            Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
            by av4x
            Good morning, everyone!
            I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
            First up is a Fujitsu Lifebook U7511.
            It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
            Model: Fujitsu Lifebook U7511
            CPU: Intel Core i5-1135G7
            GPU: Intel Iris Xe Graphics
            RAM: 16GB DDR4 - 3,200 MHz
            PCB manufacturer: ASKPCB?
            PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
            Damage: Liquid damage
            The liquid probably...
            11-01-2025, 03:09 AM
