Samsung LN46C630 Thin Vertical Lines on entire screen
  • SergeyR
    • Feb 2015
    • 10
    Re: Samsung LN46C630 Thin Vertical Lines on entire screen
    My internet connection here is super slow, so the video will be uploaded in 3 hours, thus I'll post a link only tomorrow.
    But unfortunately I didn't understand what do you mean by "tab bonding". Please could you explain it using different words. I also wonder how could I fix it? I have only these tools: multimeter and soldering-iron.
      https://www.badcaps.net/forum/showpo...&postcount=113
      Just do the search in badcaps 'TAB BONDING'
      • nomoresonys
        • 12331
        • U.S.
        Originally posted by budm
        That looks like tab bonding issue.
        What happen if you try flexing the panel?
        did you try flexing the panel???
        • SergeyR
          • Feb 2015
          • 10
          Oh, I see now. Thank you!
          Ok, I'll try to disassemble my panel and check tabs.
          And finally here is my video which shows the problem. I didn't record this video from the very beginning, but when I turned ON my TV everything was fine, then the screen begin to flicker a bit and then you can see colored vertical lines. Please watch it to the very end and you will see that after a picture test turns off automatically you can still see that picture on the background and vertical colored lines on the foreground:
          http://youtu.be/Sz6KJ3nX1QE
          And I need to confess that when I watched movies I paused a movie, but didn't turn off TV, thus that paused movie frames were on the screen for the whole night. It happened about 5-6 times. Maybe that was the reason for the overheat.
          • SergeyR
            • Feb 2015
            • 10
            No, I haven't tried to flex the panel. I'll try.
            • SergeyR
              • Feb 2015
              • 10
              So I just turned on TV. It was OFF since last evening. And I suddenly saw the same problem. So this time it even didn't need to warm up. I decided to flex the panel. So I grabbed a top side of the panel and pulled it towards me. And then boom! The problem disappeared before I even started flexing it.
              I don't know how to explain this issue. I left TV on and will wait. Maybe this problem will come back later....
              • SergeyR
                • Feb 2015
                • 10
                Yup, the problem came back. I tried to flex TV, but it didn't help this time.
                • nomoresonys
                  • 12331
                  • U.S.
                  #28
                  try holding the frame/bezel with your palm, and tap on the back see if anything on display changes if not tap it a little harder, try it in different spots too, trying to see if its the panel.
                  • sordids999
                    • May 2013
                    • 2161
                    • uk
                    #29
                    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
                    • nomoresonys
                      • 12331
                      • U.S.
                      #30
                      I wouldnt recommend holding a static picture on any tv display overnight.
                      • Eastgateraja
                        • Aug 2015
                        LN46C630:
                        I have a spares for the above TV. If any one interested please contact me here..
                        • Jkorf41515
                          • Sep 2015
                          • United States of America
                          #32
                          I am definitely interested in one of your boards as I got this fine tv off CL for a cool $50, and all it needs is a board to fix my vertical lines.
                          • n1iwv
                            • Jun 2013
                            • 20
                            I have a Samsung LN46C630 with the same exact symptom of thin vertical lines (about 4 mm spacing) across the entire screen.
                            I have played around with it and found that if I flexed the LVDS cable at the connector on the main board, I could get the lines to disappear. The flexing exercise involves pulling the cable near the connector away from the main board.
                            I took a wooden stick about 1/8" in diameter and 2 inches long (about as wide as the cable) and wedged it between the cable and the main board. This provides upward pressure on the cable,
                            This has solved the problem temporarily.
                            I've order a new cable (BN96-12723D) and will report back when I've installed it
                            • n1iwv
                              • Jun 2013
                              • 20
                              Well I tried replacing the LVDS cable and that did not solve the problem.
                              I found that pressing on the IC chip (see RED IC on the Main board photo), I could get the vertical lines to disappear.
                              It would appear that the BGA is in need of a rework. Maybe re balling.
                              I am not set up to do this type of work.
                              Anyone out there know a good reputable service and an approximate cost to re-ball the red IC in the photo?
                              Thank
                              • Falki
                                Colorful LCD Vertical Lines on Samsung ue55es8090
                                by Falki
                                Hello there, ive recently found an older 55inch Samsung SmartTV.
                                Sadly it has vertical lines at the left and one line in the middle-right.
                                I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                I have factory resetted the TV as well but also with no luck.
                                I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                A similar issue has been posted as well but also with no actual response ...
                                08-12-2025, 04:19 AM
                              • Stanley1843
                                Screen Display Vertical Multicolor Lines
                                by Stanley1843
                                Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                06-29-2024, 11:54 AM
                              • pni
                                LG 49uf695v vertical coloured lines
                                by pni
                                Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                11-14-2025, 03:15 AM
                              • x_orange90_x
                                Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                by x_orange90_x
                                I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                09-04-2023, 12:09 PM
                              • polaro
                                Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                by polaro
                                Greetings,
                                I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                08-27-2022, 08:46 AM
