Scope For Troubleshooting Voltages
  • Michale32086
    • Nov 2011
    • 1453
    I had asked about this, but it likely got buried in a current thread...
    I am thinking about taking the next step in repair and obtaining a scope to test LCDs and PLASMAs with...
    Functionality is obviously the first consideration, but a close second is affordability...
    With that in mind, I came across this:
    http://www.ebay.com/itm/221079073846...%3AMEBIDX%3AIT
    "Yes"??? "No"??? "ARE YOU SERIOUS!!!"???
    Thanx
  • popeye
    • May 2011
    • 155
    Re: Scope For Troubleshooting Voltages
    I would rather get a good seconhand one of a known brand Teckniks Rigole etc I think that looks like a toy plus never heard of them.
    • Michale32086
      • Nov 2011
      • 1453
      Thanx for the reply...
      Like this??
      http://www.ebay.com/itm/Tektronix-22...item35e2b625bd
        Avoid those little mini DSO things... they are pretty useless for all but basic work.
        The Tek scope is a good solid instrument.
        If you have a budget that can stretch to $400 consider a Rigol DS1054Z, as it is a full function digital oscilloscope with a vast array of powerful features. I have the bigger brother the DS1074Z and find it to be a fantastic oscilloscope very helpful for my diagnosis of plasmas and power supplies.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          If your budget is limited to $150 an used Tek, HP or Philips is your best bet.
          I used to have a Russian 100MHz single channel scope and sold that. Then i got a 2x 10MHz National (Panasonic) scope. That thing was probably good for CRT TVs but it's next to useless for SMPS work or tracing ground loops in audio as it's got a 10mV/div minimum sensitivity, which turns into 100mV/div with a x10 probe. You are going to use the X10 probe most of the time, as it can take higher voltages (up to 600v, most scopes only accept 60v or so). Also the X10 probe has better bandwidth.
          About 1 year later IIRC, i got lucky and found a Philips PM 3215 2x 50MHz. I got it for ~$85 shipped from another city here in Romania. Apart from some minor cracks in the front panel bakelite, it only needed a few caps replaced (it worked, but trace was a bit noisy) and some minor calibration. Extremely detailed service manual too. It has a 2mV/div minimum sensitivity (20mV/div with X10 probe), which is great. It can also do differential measurements, trigger hold-off and a few more nice functions.
          Oh and it needs the graticule backlight bulbs replaced, but i never bothered with that, i can live without it. I swapped the blown bulb with a red LED but it is not bright enough compared to the right side where the bulb still works. White wouldn't work, it would have to be yellow or red to make the graticule stand out from the trace. It's no match for a Tek, but for the price i cannot complain. I kept the National scope as well, but it hardly sees any use now.
          So yeah... if that's your budget, i would go for that Tek.
          A working TV? How boring!
          • Michale32086
            • Nov 2011
            • 1453
            http://www.ebay.com/itm/Rigol-DS1054...item4d2a089c51
            That IS a pretty sweet one...
            If I have a good weekend in my shop, I might be able to spring for this..
            • Michale32086
              • Nov 2011
              • 1453
              Thanx for the info...
              Anyone who "Works For Beer" is OK in my book!!!
                You can get a 6% discount if you buy it through EEVBlog. Also try and get the scope with four probes (some vendors only include two)
                http://www.eevblog.com/forum/chat/sp...vblog-members/
                • mmartell
                  • Oct 2013
                  • 3189
                  Not sure how the Rigol 1052E stacks up but I got one used for about $230 usd.
                    That's not too bad. But you should avoid buying a new one. The 1052E new is about $329, for an extra $70 you get a helluva lot more. Four channels, deep memory (12/24Mpt), intensity graded display, bigger high-res screen...
                    I used to have a DS1052E and it's a very solid instrument, but in my opinion the DS1054Z has completely changed the marketplace of budget scopes.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have the DS1052 and with a firmware update you can turn it into a 100Mhz scope. Check eevblog for this hack(or Youtube).
                        I don't think you can do that on the newer 1052E scopes. You can upgrade the 1054Z and increase memory length, bandwidth, etc
                        • Michale32086
                          • Nov 2011
                          • 1453
                          I am going to check with a guy who wants me to repair TVs for him... If he wants to go in halves on the project, I'll get the DS1054Z thru EEVBLOG...
                          If not, then I'll go with the used Tektronix 2215 and (hopefully) work my way up..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Tom, can you recommend a good vendor that will include 4 probes instead of 2??
                              Ask them. I only have experience with a UK vendor who included four probes, I pushed them because their competitors had four probes, so got a price match + four probes + free 3 yr warranty. Since I got the 70MHz scope, before the 50MHz was available (at the amazing $400 price point), it cost me about £425 all in (about $650), including shipping.
                              Get vendors to compete against each other for the best prices.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Well, looks like I'm ordering the Rigol DS1054Z!!
                                I had to promise the guy a buttload of fixed TVs, but a small price to pay..
                                WOOT!! Now I am pumped!!
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8340
                                  Good choice!
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Well, looks like the DS1054Z is on back order and likely won't see it for a month..
                                    So, I opted for the DS1074Z which should go out immediately...
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      And it DOES include 4 probes!!!
                                      "hu hu uh..huh.. hu.. He said 'probe'.."
                                      -Beavis & Butthead
                                      • rddube
                                        Advanced help for troubleshooting CPU voltages on a Lenovo L490
                                        by rddube
                                        This is the same laptop that SMDflea helped me diagnose a problem with the memory 1.2v power supply. Turns out the laptop now boots and everything works fine except 2 things. The CPU is either undervolted because it throttles @ 390mhz. Aida 64 reports it as overheating detected so throttling which makes it go very, very slow....... Another problem is their doesn't seem to be any sound chip or the laptop doesn't detect it but the chip is there.
                                        Not sure if the 2 problems are related, but anyhow the most important problem I need to pin down is the CPU voltage....
                                        07-25-2025, 06:18 AM
                                      • Capacitorial
                                        Powersupply has all the voltages - Monitor still no power
                                        by Capacitorial
                                        Hello guys,
                                        I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                        The weird thing is, that the Power LED is powered over the TCON board.
                                        On The TCON...
                                        12-28-2024, 02:12 PM
                                      • repair-it
                                        Need advice testing a samsung power supply board with scope
                                        by repair-it
                                        I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                        07-12-2025, 11:00 AM
                                      • duwane
                                        MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                        by duwane
                                        Hi All.
                                        I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                        Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                        After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                        Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                        10-17-2023, 07:48 PM
                                      • blues_spirit
                                        practical courses for troubleshooting pc motherboards
                                        by blues_spirit
                                        Hello from France,
                                        mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                        Do you think this is feasible for me? I...
                                        12-18-2022, 12:56 PM
