Pilot 37" LCD : PIL37AV Stuck on standby
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Hey all,
    I found this TV on it's way to the trash..
    It had been opened and the speakers were missing.
    It got no power at all, so i found and replaced 4 bad caps:
    1X220u 25v-> totally open
    3X22u 50v-> high ESR
    I got standby voltage!
    But didn't manage to turn it on
    I don't have the remote but there is 3.8v on the power button.
    Got 315vdc on main filter cap.
    Power supply board:KAS300-5S241812HL
    All of the other caps looks pretty much fine
    3x1000u 35v were missing some of their capacitance
    almost 900 instead of 1000.
    i am going to replace those as well.
    Any other tips would help me out.
    im not sure if its the PS fault or the Logic board....
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Pilot 37" LCD : PIL37AV Stuck on standby
    Once you replace all parts that you think are faulty and you are getting 5Vdc Standby Voltage. If you can determine the appropriate pins, probably you could try to force the Pwr Sup On by using a 1k-10k resistor from Std-By to Pwr-On and another 1k-10k resistor from Std-By to BL-ON. The connector from the Pwr Bd to the Main Bd must be disconnected from the Main Bd before attemting this operation.
    • s_henya
      • Jan 2011
      • 483
      • Israel
      I tried force power it by jumpering
      pin 1 ON CNR4 connector its ON/OFF with GND with mainboard and inverter disconnected.
      i can hear it's trying to start but i can hear some clicks as i have a short on something...
      i checked all of the small diodes, all seemed ok.
      the next thing is to check the transistors which is a pian,
      i hate to wick them out....
      any more ideas?
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        what voltage are you getting on the 2 middle pins of the bridge rectifier?,the voltage on the main filter cap seems to low
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        • s_henya
          • Jan 2011
          • 483
          • Israel
          testing this board with ac on, is a pain... there is some residue on the back side,
          and in order to test anything, i need to press real hard with the probs,
          haha im afraid to slip....
          just to clarify one pin on the middle pin of the bridge and the other on hot side gnd?
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            Originally posted by s_henya
            testing this board with ac on, is a pain... the is some residue on the back side,
            and in order to test anything i need to press real hard with the probs,
            no just the 2 middle pins AC volts marked ~~
            • s_henya
              • Jan 2011
              • 483
              • Israel
              i added some fresh solder, now the contact is better,
              i get 222vac between the middle brigde legs.
              never had the chance to thank you multimeter :-)
              what next?
              • selldoor
                Slow Learner
                • 7870
                Surely if he has 315vdc on the big cap the bridge must be ok?
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  to confirm line voltage,it still seems low to me.....
                  • s_henya
                    • Jan 2011
                    • 483
                    • Israel
                    Could it be that the jumper i connected wasn't right, that caused the clicks?
                    Because without it (mainboard and inverter connected) there isn't any sound...
                    CN4, CN6 goes to the mainboard,
                    CN2,CN3 goes to the inverter.
                    • CapLeaker
                      Leaking Member
                      • 8352
                      maybe the main board isn't returning the on signal for the power supply.
                      • selldoor
                        Slow Learner
                        • 7870
                        What is the part number of that 8 legged IC in the middle of the board just above the BIG cap in your picture
                        • multimeter
                          • Jan 2011
                          • 739
                          • united kingdom
                          could possibly be main board,but that filter cap voltage is bugging me ...,test all output voltage on pins to GND on the PSU connectors,a shorted rail could also cause the problem,you want to see very high KOHM to infinate
                          • selldoor
                            Slow Learner
                            • 7870
                            Sorry I missed the bit where you said it seemed low - but in Israel they only work on 220vac not 230 -240 so 315vdc is ok. But only as the board is not fully functioning - I suspect it has pfc so if it was all working it would be nearer 380vdc
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              absolutly PFC is there,what i expected was around 380VDC ?! a short could load down primary side,do any of the output voltages pulse?could indicate a faulty start up cap ,or shorted secondary diode,have you tested to ground the 5v,12v,24v etc?
                              • s_henya
                                • Jan 2011
                                • 483
                                • Israel
                                IC is: 2A180Z
                                • s_henya
                                  • Jan 2011
                                  • 483
                                  • Israel
                                  multimeter, for you question about testing resistance between outputs to gnd, no i didn't.
                                  give me a quick brief, and i will do it right now.
                                  • multimeter
                                    • Jan 2011
                                    • 739
                                    • united kingdom
                                    on the connectors that go from the psu to mainboard,measure the +rails with respect to cold ground chassis,and measure the resistance readings,with psu disconnected and post them up here
                                    • s_henya
                                      • Jan 2011
                                      • 483
                                      • Israel
                                      could i use the GND in the connector itself as cold ground?
                                      i have just thought of something,
                                      this pcb uses multilayer, is it possible that the upper side didn't get contact with the part it was soldered to. i am saying that because i just noticed a cold jont on the upper side of a resistor i took out in order to test out of circuit.
                                      • multimeter
                                        • Jan 2011
                                        • 739
                                        • united kingdom
                                        yes
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • toty79
                                          Hisense LTDN50K220WSEU stuck in standby
                                          by toty79
                                          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                          As per Hisense tv title LTDN50K220WSEU stuck in standby
                                          PSU rsag.820.5687 HLL 4855WF
                                          Main rsag 7.820.5842
                                          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                          05-01-2022, 04:39 PM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
