samsung LN-S4051D diagnal lines
Re: samsung LN-S4051D diagnal lines
http://assets.shopjimmy.com/media/ca...bn4400134a.jpg ds805 read .058 in both directions, ds804 read .344, I think they are suppose to be .4 to .7?Last edited by nomoresonys; 01-01-2015, 08:17 AM.Comment
http://assets.shopjimmy.com/media/ca...bn4400134a.jpg ds805 read .058 in both directions, ds804 read .344, I think they are suppose to be .4 to .7?Never stop learning
It is not mega pixel, it is the lights and the MACRO, and tripod or very steady hands, I use my over 10 years old SONY with good MACRO mode and <2M pixel.
https://www.badcaps.net/forum/showth...ight=dell+2007Last edited by budm; 01-01-2015, 06:17 PM.Never stop learning
Well that DS805 (1N4937) is the snubber Diode for the Relay REL801, it is connected in parallel with the relay coil (Omron G5RL 5vdc COIL, about 62 Ohm DCR) that is why it show conduction in both direction, that is why I ask you to take the RESISTANCE reading of the Diode, not in the Diode mode, I get some idea what the resistance is.
When you check semiconductor for shorts, leakage resistance, you use Ohm mode because when semiconductor shorted out it will no longer act as semiconductor.
you can use 1N 4007 in its place. You can verify by check the resistance of the two copper pads where the diode's legs are connected to and see what resistance you get.
BTW, if the power supply is bad it will affect not just the pictures but also other circuits as well.Last edited by budm; 01-01-2015, 07:22 PM.Never stop learning
BTW, if the power supply is bad it will affect not just the pictures but also other circuits as well.Last edited by nomoresonys; 01-01-2015, 09:13 PM.Comment
You can use any rectifier diode with 500~1000V rating in that location.
"I thought all diodes were one way" Yes they are but when they shorted out it will show resistance both way, but that is not the problem with your diode, it is connected in parallel with relay coil that has resistance of around 62 Ohms so it shows up as bad when you check it.Never stop learning
So does your main board has this cap on the bottom side?
https://www.badcaps.net/forum/attach...2&d=1420085798Never stop learning
OK, try soldering another cap in parallel with that cap, anything between 47~100uF 10VDC, the white bar on that cap is POSITIVE so make sure the positive of the added cap goes to that bar side. See if it changes the symptom on the screen.Never stop learning
sorry you dont have the electronic skills to repair this tv
My advice is to give up and save your moneyComment
ok, back at it, just had to add a troll to ignore list, God bless the lonely trolls, with no social skills, not even online, hohoho.Last edited by nomoresonys; 01-02-2015, 12:22 AM.Comment
"I thought all diodes were one way" Yes they are but when they shorted out it will show resistance both way, but that is not the problem with your diode, it is connected in parallel with relay coil that has resistance of around 62 Ohms so it shows up as bad when you check it.Comment
1n4000 series Diode, look up the spec sheet, the 1n4007 has PEAK reverse voltage rating of 1000V (700V RMS).
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... - Loading...
