samsung LN-S4051D diagnal lines
  • nomoresonys
    • 12274
    • U.S.
    #141
    Re: samsung LN-S4051D diagnal lines
    have 3 resistors in parallel, 2.2 ohm, 22 ohm and 10k ohm, 2.2 and 22 are right on, the 10k is only 40 ohms, is that ok??
    • nomoresonys
      • 12274
      • U.S.
      #142
      so checking the optos, most give a reading on one side, meter in diode mode, like if say pin one and 2 where the legs are side by side, get a reading with probes on each, swicth probes no reading, other end the same but there's one right beside another that gives no reading on one end probes reversed or not, so tested another boards optos and some do the same thing. opto in question is pcm802, pcm801 right beside it gives reading one way on both ends as do the other 3 on the board.
      • nomoresonys
        • 12274
        • U.S.
        #143
        ts801 shows 3.1 ohms from one of the corner pins to the one next to it, too high?
        • nomoresonys
          • 12274
          • U.S.
          #144
          very small cap on underside CI839, shows no continuity to ground.
          • nomoresonys
            • 12274
            • U.S.
            #145
            also no continuity to ground on very small caps on underside CI811, CI835.
            • nomoresonys
              • 12274
              • U.S.
              #146
              can I test this IC in circuit using ohm mode or diode mode? https://datasheetspdf.com/pdf/560565...ctor/FAN7382/1
              • nomoresonys
                • 12274
                • U.S.
                #147
                mosfet QI802 which was shorted gate to source and replaced, shows continuity/short from source to pin 4 and 5 of ICI804 above. gate to pin 5 also shows continuity/short.
                • nomoresonys
                  • 12274
                  • U.S.
                  #148
                  only pins showing continuity on the ic itself is pin 4 to 5.
                  • nomoresonys
                    • 12274
                    • U.S.
                    #149
                    How is THIS even possible, I don't get it?
                      09-07-2024, 05:50 AM
                    • Robby-Gr
                      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                      by Robby-Gr
                      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                      Additional issues:...
                      09-27-2025, 12:02 AM
                    • Falki
                      Colorful LCD Vertical Lines on Samsung ue55es8090
                      by Falki
                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                      Sadly it has vertical lines at the left and one line in the middle-right.
                      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                      I have factory resetted the TV as well but also with no luck.
                      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                      A similar issue has been posted as well but also with no actual response ...
                      08-12-2025, 04:19 AM
                      LCD LED TV Service Menu Codes
                      TCL LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      10-31-2024, 03:58 AM
                    • Rubenlily
                      Samsung QE50Q67TAU - horizontal lines
                      by Rubenlily
                      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                      I'm no expert but I've done the tape...
                      08-16-2023, 01:12 PM
