Re: samsung LN-S4051D diagnal lines
How is THIS even possible, I don't get it?
only pins showing continuity on the ic itself is pin 4 to 5.Leave a comment:
mosfet QI802 which was shorted gate to source and replaced, shows continuity/short from source to pin 4 and 5 of ICI804 above. gate to pin 5 also shows continuity/short.Leave a comment:
can I test this IC in circuit using ohm mode or diode mode? https://datasheetspdf.com/pdf/560565...ctor/FAN7382/1Leave a comment:
also no continuity to ground on very small caps on underside CI811, CI835.Leave a comment:
very small cap on underside CI839, shows no continuity to ground.Leave a comment:
ts801 shows 3.1 ohms from one of the corner pins to the one next to it, too high?Leave a comment:
so checking the optos, most give a reading on one side, meter in diode mode, like if say pin one and 2 where the legs are side by side, get a reading with probes on each, swicth probes no reading, other end the same but there's one right beside another that gives no reading on one end probes reversed or not, so tested another boards optos and some do the same thing. opto in question is pcm802, pcm801 right beside it gives reading one way on both ends as do the other 3 on the board.Leave a comment:
have 3 resistors in parallel, 2.2 ohm, 22 ohm and 10k ohm, 2.2 and 22 are right on, the 10k is only 40 ohms, is that ok??Leave a comment:
will AR S1 80 diode replace 1n4005? they are same size physically, can not seem to find info on ar s1 80.Leave a comment:
took out ds805, testing the thru holes I only get 59 ohms, is that too low?Leave a comment:
CNI804 does have 12 volts as indicated at the connector.Leave a comment:
yes, I was getting the bad cap clicking syndrome, changed those 8 electros out and it worked fine for several months then the connector from powerboard to main burnt out, think it was just from old age, replaced that and touched up the joints worked fine for a few more months. Started clicking again, could get it to stop and the backlights would be on for 15 minutes or so by heating the area of ICS801, then was messing around testing the three 8 pin ics on top side of board while powered while testing one of them tv went on and off, then tested main cap and saw I lost the boosted pfc, found QI802 shorted from gate to source, switched it out with K4087 https://www.alldatasheet.com/view.js...K4087&sField=1, which I think is close but not sure. Now still have no boosted pfc and heating that area of ICS801 doesn't get the backlights to come on anymore.Last edited by nomoresonys; 06-09-2022, 05:02 AM.Leave a comment:
well this one crapped out again, getting the clicking of the relay every 5 seconds, fixed it once with electro caps replacement and reflow of solder joints, lasted a few months now its back same thing, clicks every 5 seconds. When powerboard is unhooked from mainboard clicking stops but backlights don't come on, when heating area of ics801 for a minute or two tv comes on for 15 minutes or so no clicking, replaced or checked all caps and resistors in that area, anyone know if heating ics801 is making it work for that 15 minutes or should heating it have no effect on the ic as in letting the tv work for that 15 minutes??: sj pic of powerboard: https://www.shopjimmy.com/samsung-bn...ight-inverter/Leave a comment:
the samsung I'm using in place of this one is a un model edge lit tv and it pales in comparison no matter how much calibration is done, much lighter and sleeker looking and no mercury BUT worse picture quality.Leave a comment:
Lol, that would point to insanity wouldn't it? no, I fixed it with a mainboard in early 215 then it just started acting up again lately, its old as dirt but these early samsungs have a very good picture, otherwise I wouldnt bother with it, kind of heavy and clunky compared to newer stuff. I like the puzzle aspect of it but so far its getting the better of me.Last edited by nomoresonys; 06-09-2022, 03:58 AM.Leave a comment:
Wow Nomoresonys you surely have perseverance. You started this thread in 2014 and you are still at it. I know nobody out there that would do that. Cudos to you.Leave a comment:
ok, now have the clicking twice every 5 seconds back, gonna call that progress.Leave a comment:
can it be just a weak faulty bridge? all the diodes check good in it.Leave a comment:
can anyone answer the question, why the dc voltage on the bridge rectifier, thats + and - the 2 outside legs is 106, it was 106 when the backlight was staying on for 15 minutes, the ac coming in on the bridge rec. is 120 as it should be, is this normal or does it point to a problem???Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by jeyoung12Hi all
I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
So....i don't know what end of the C ribbon to work with... -
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
