samsung LN-S4051D diagnal lines
    • 12206
    • U.S.
    #41
    Re: samsung LN-S4051D diagnal lines
    Originally posted by budm
    its the lower one, bn94-01091b.
    Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
      • 12206
      • U.S.
      #42
      i ll try to get a good pic of power supply.
        • 12206
        • U.S.
        #43
        http://assets.shopjimmy.com/media/ca...bn4400134a.jpg ds805 read .058 in both directions, ds804 read .344, I think they are suppose to be .4 to .7?
          • 12206
          • U.S.
          #44
          Originally posted by splitcrete
          That model tv is known for bad panels. I would change the caps,and diodes to see if any thing changes.
          Thanks splitcrete, I wonder if another power diode about that same size, off an old pc power supply would work?
            Can you provide the bottom side pictures, and one especially around DS805?
              • 12206
              • U.S.
              #46
              I'll do my best with this 5pm camera.
                It is not mega pixel, it is the lights and the MACRO, and tripod or very steady hands, I use my over 10 years old SONY with good MACRO mode and <2M pixel.
                https://www.badcaps.net/forum/showth...ight=dell+2007
                  • 12206
                  • U.S.
                  #48
                  ok, will try to get some better ones outside in the daylight.
                    Well that DS805 (1N4937) is the snubber Diode for the Relay REL801, it is connected in parallel with the relay coil (Omron G5RL 5vdc COIL, about 62 Ohm DCR) that is why it show conduction in both direction, that is why I ask you to take the RESISTANCE reading of the Diode, not in the Diode mode, I get some idea what the resistance is.
                    When you check semiconductor for shorts, leakage resistance, you use Ohm mode because when semiconductor shorted out it will no longer act as semiconductor.
                    you can use 1N 4007 in its place. You can verify by check the resistance of the two copper pads where the diode's legs are connected to and see what resistance you get.
                    BTW, if the power supply is bad it will affect not just the pictures but also other circuits as well.
                      • 12206
                      • U.S.
                      #50
                      Thanks Budm, I thought all diodes were one way, now in my ignorance I took off and broke a good part, I'll try to find a replacement.
                        You can use any rectifier diode with 500~1000V rating in that location.
                        "I thought all diodes were one way" Yes they are but when they shorted out it will show resistance both way, but that is not the problem with your diode, it is connected in parallel with relay coil that has resistance of around 62 Ohms so it shows up as bad when you check it.
                          So does your main board has this cap on the bottom side?
                          https://www.badcaps.net/forum/attach...2&d=1420085798
                            • 12206
                            • U.S.
                            #53
                            yes, c1701.
                              • 12206
                              • U.S.
                              #54
                              this ones a little better, the light is bad.
                                OK, try soldering another cap in parallel with that cap, anything between 47~100uF 10VDC, the white bar on that cap is POSITIVE so make sure the positive of the added cap goes to that bar side. See if it changes the symptom on the screen.
                                • chrismurphy
                                  • May 2014
                                  • 251
                                  • australia
                                  #56
                                  sorry you dont have the electronic skills to repair this tv
                                  My advice is to give up and save your money
                                    • 12206
                                    • U.S.
                                    #57
                                    ok, back at it, just had to add a troll to ignore list, God bless the lonely trolls, with no social skills, not even online, hohoho.
                                      • 12206
                                      • U.S.
                                      #58
                                      Thanks budm, sorry to be so thick, when you say 500~1000v, do you mean voltage-forward, voltage-dc reverse or current-reverse leakage, I'm guessing 500~1000 means from 500 up to 1000.
                                        1n4000 series Diode, look up the spec sheet, the 1n4007 has PEAK reverse voltage rating of 1000V (700V RMS).
                                          • 12206
                                          • U.S.
                                          #60
                                          ok, Thanks Budm.
                                            09-07-2024, 05:50 AM
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Rubenlily
                                            Samsung QE50Q67TAU - horizontal lines
                                            by Rubenlily
                                            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                            I'm no expert but I've done the tape...
                                            08-16-2023, 01:12 PM
                                          • jeyoung12
                                            Samsung QN50Q60t lines on screen
                                            by jeyoung12
                                            Hi all
                                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                            So....i don't know what end of the C ribbon to work with...
                                            02-26-2024, 10:38 AM
