samsung LN-S4051D diagnal lines
    • 12145
    • U.S.
    Re: samsung LN-S4051D diagnal lines
    quick question: could there be a bad IC on power supply, yet still get all the proper voltages at the connectors on power supply, thanks.
      • 12145
      • U.S.
      3-11
      3-5 Servicing Information
      3-5-1 USB Download Method
      1. Downloading boot code
      (1) Change the boot code's file name into "boot.bin".
      (2) Copy the "boot.bin" into the path "/bordeaux/us" in USB flash driver.
      (3) Turn off LCD TV.
      (4) Insert the USB flash driver into the service 1 jack of LCD TV.
      (5) Turn on LCD TV.
      (6) The banner osd "Updating SW..." is displayed.
      (7) The banner osd "Completed..." is displayed when the updating is completed.
      (8) Turn off and remove the USB flash driver from LCD TV
      (9) Check the program version.
      2. Downloading application code
      (1) Change the application code's file name into "appl.rom".
      (2) Copy the "appl.rom" into the path "/bordeaux/us" in USB flash driver.
      (5) Turn on LCD TV.
        • 12145
        • U.S.
        3-11
        (5) Turn on LCD TV.
        (5) Turn on LCD TV.
        wonder if this might fix it, but don't know where to get file or files, Thanks.
          • 12145
          • U.S.
          think I forgot a few steps, with mainboard unplugged from ps, tested I think its called the rail, on power supply, have 6.3 on stndby, board says 6.5, the rest the 12's 5's and 13v are 0, thats not good, unless the mainboard needs plugged in to get those volts, and seems like 1 diode in that area reads ol in both directions, Thanks.
            • 12145
            • U.S.
            got bad reading from diode ds805 read in board .058 in both directions, tried to take it out to read it but broke it, no solder skillz at all lol, also diode ds804 read .344 is that too low?, hard to read numbers on tiny diode , looks like GP v8180 n493 or n498?, does that sound like a familiar diode, I messed up label a bit getting it out, Thanks.
              • 12145
              • U.S.
              #26
              http://www.cnet.com/news/samsung-pow...-suit-follows/
                • 12145
                • U.S.
                #27
                does anyone know which capacitor the cnet article refers to?
                  • 12145
                  • U.S.
                  #28
                  looking to scavenge a diode or two from other old electronics boards, wonder what ones will work?
                    • 12145
                    • U.S.
                    #29
                    can not figure out which diode to order, appears to be a gp, n493, dont see it anywhere.
                      What do get using Ohm mode to check the Diode?
                      Location of that Diode?"
                        They were talking about the caps on the power supply board.
                        I never seen this symptom like this before.
                        Last edited by budm; 12-31-2014, 03:42 PM. Reason: Coreection on the lines on the screen
                          • 12145
                          • U.S.
                          #32
                          its this diode, wanted to check it out of circ. but I broke it taking it out, its tiny, I believe its a power/rectifier diode, thanks for reply budm.
                          • splitcrete
                            • Dec 2012
                            • 387
                            • usa
                            #33
                            Check caps cm 807,808,809,811,812,817,cs806
                            Check diodes ds801,802,803
                            You just may find a couple of them bad.
                              • 12145
                              • U.S.
                              #34
                              hi splitcrete, I dont have an esr meter to check caps, checked diodes,801,2,3, checked ok in cir., 804 was .344, 805 was .058 in both directions, tried to take it out to measure out of cir. but it broke, or is there a way to measure caps with the mm.
                                • 12145
                                • U.S.
                                #35
                                theres numbers on the tiny diode, I couldnt match them up on digikey, pretty sure its a power/rectifier diode, black with the grey band, numbers on it are v8180, n493, gp, Thanks for helping, not getting too far with this one.
                                  • 12145
                                  • U.S.
                                  #36
                                  woah, just looked at those pics. again, theyre terrible, gotta get a better camera.
                                    • 12145
                                    • U.S.
                                    #37
                                    do you think a bad diode would make that snowy horizontal like picture?
                                      • 12145
                                      • U.S.
                                      #38
                                      trying to locate a training manual, no luck yet.
                                      • splitcrete
                                        • Dec 2012
                                        • 387
                                        • usa
                                        #39
                                        That model tv is known for bad panels. I would change the caps,and diodes to see if any thing changes.
                                          Which one of these is you board?
                                          http://www.shopjimmy.com/samsung-bn9...ain-board.htm#
                                          http://www.shopjimmy.com/samsung-bn9...main-board.htm
                                          Does your board have this cap?
                                            09-07-2024, 05:50 AM
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Rubenlily
                                            Samsung QE50Q67TAU - horizontal lines
                                            by Rubenlily
                                            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                            I'm no expert but I've done the tape...
                                            08-16-2023, 01:12 PM
                                          • jeyoung12
                                            Samsung QN50Q60t lines on screen
                                            by jeyoung12
                                            Hi all
                                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                            So....i don't know what end of the C ribbon to work with...
                                            02-26-2024, 10:38 AM
                                            09-06-2024, 11:40 PM
