have diagonal lines, have solid red standby, comes on makes the little samsung noise, tried a different tcon, gave exact same screen image, can't get a menu, using a samsung remote from a different tv, not sure if that matters, wonder if it's the a board?, Thanks.
samsung LN-S4051D diagnal lines
Tags: None
Re: samsung LN-S4051D diagnal lines
tried mute 182 power for reset, not sure if that's correct, same results. -
try in standby info/menu/mute then power on tv to access service menuComment
would like to diagnose the a board but not sure how to check it.Comment
when I try to open the electotanya manual, I get "windows needs to know what program created it" I still don't know how to sort that error out.Comment
I did notice on the a board the 2 caps, one on each side of IC401 are curious, I can see the x but they don't look broken.Comment
anyone know if those are easy to replace or is it more of a challenge than replacing caps on g board, Thanks.Comment
I think these are close, not sure.http://www.digikey.com/product-searc...6T%20smd%20capComment
oops already removed them, ordered 2 from digikey $6.31, i think I got took, waiting on them, thanks for reply.Comment
heated main board, no change, replaced those 2 caps from main, same condition, they mustve been good, x was showing thru, figured they would need replaced sooner or later.Comment
anyone know what those diagonal lines could mean, cant get a menu either, thanks.Last edited by nomoresonys; 12-26-2014, 10:25 PM.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... - Loading...
