samsung LN-S4051D diagnal lines
    • 12192
    • U.S.
    have diagonal lines, have solid red standby, comes on makes the little samsung noise, tried a different tcon, gave exact same screen image, can't get a menu, using a samsung remote from a different tv, not sure if that matters, wonder if it's the a board?, Thanks.
    • 12192
    • U.S.
    Re: samsung LN-S4051D diagnal lines
    tried mute 182 power for reset, not sure if that's correct, same results.
    • sordids999
      • May 2013
      • 2152
      try in standby info/menu/mute then power on tv to access service menu
        • 12192
        • U.S.
        tried a manual from electrotanya but couldn't open the file.
          • 12192
          • U.S.
          ok, tried info menu mute power, same screen, can't get a menu, thanks sordids999, do you think it might be the a board?
            • 12192
            • U.S.
            would like to diagnose the a board but not sure how to check it.
              • 12192
              • U.S.
              when I try to open the electotanya manual, I get "windows needs to know what program created it" I still don't know how to sort that error out.
              • sordids999
                • May 2013
                • 2152
                try downloading adobe reader
                  • 12192
                  • U.S.
                  got adobe, same result, not sure whats wrong.
                    • 12192
                    • U.S.
                    I did notice on the a board the 2 caps, one on each side of IC401 are curious, I can see the x but they don't look broken.
                      • 12192
                      • U.S.
                      anyone know if those are easy to replace or is it more of a challenge than replacing caps on g board, Thanks.
                        • 12192
                        • U.S.
                        wondering if this IC401 has anything to do with video.
                          • 12192
                          • U.S.
                          he two caps appear to be plug in type, there's no legs through the back, wonder if I can just pull them off?, Thanks.
                            • 12192
                            • U.S.
                            numbers on cap: 81425, 470, 16t, they appear to be snap in, having trouble locating a data sheet, thanks.
                              • 12192
                              • U.S.
                              just wondering which part on digikey is the correct one?, Thanks.
                                • 12192
                                • U.S.
                                I think these are close, not sure.http://www.digikey.com/product-searc...6T%20smd%20cap
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Those are not "snap in" caps they are surface mount and they are probably ok and not your problem. Try heating the main board with a hair dryer and see if anything changes.
                                    • 12192
                                    • U.S.
                                    oops already removed them, ordered 2 from digikey $6.31, i think I got took, waiting on them, thanks for reply.
                                      • 12192
                                      • U.S.
                                      heated main board, no change, replaced those 2 caps from main, same condition, they mustve been good, x was showing thru, figured they would need replaced sooner or later.
                                        • 12192
                                        • U.S.
                                        anyone know what those diagonal lines could mean, cant get a menu either, thanks.
                                          09-07-2024, 05:50 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
                                          09-06-2024, 11:40 PM
