50 inch Panasonic plasma vertical Black line
  • SamIOW
    • 7
    Just wanted some help or advice if possible.
    I have a 50 inch Panasonic plasma model TX-P50G30B which has had a few hours viewing in the evening, age around 2.5 years.
    We were watching it on Friday when a 3 inch black vertical line appeared roughly about 2-3 inches from the left side of the screen.
    Is this repairable or scrap??
    Thanks for and help given.
    Regards,
    Sam
  • freakaftr8
    • Oct 2012
    • 3743
    Re: 50 inch Panasonic plasma vertical Black line
    It could be a few things. Worst case scenario is the address buffer ic on the panel went bad. But could also be a bad connection on the clamp connector where that ribbon enters the panel on that particular area. Also could be a bad address board on that side. Located across the bottom of the screen.
    First question is there still a warranty on the tv?
    If you open it up be careful there is alot of dangerous voltages in there. if you are going to attempt to find the cable associated with that spot always make sure that the TV is unplugged when you do any touching of anything in there especially those there's voltage running through so don't try to mess with it With the tv plugged in
    • SamIOW
      • 7
      Thanks for your fast reply, No it has no warranty but I don't really expect it to fail after a few months either after paying over a grand for it.
      I was hoping it might be a simple plug worked loose after reading through some of the threads.
      • SamIOW
        • 7
          Are there NO other pixels lit up in the bar, it is completely black?
          • SamIOW
            • 7
            Update. there is all different colours speckles going down the inside of the black line.
            Just checked.
            • Shinju
              • Mar 2014
              • 1239
              I had a 85u like this and it ended up being a bad panel, reseat/clean the ribbon cable and connector on the buffer board and see if anything changes.
              Also see what happens when you unplug the affected ribbon and turn the panel on. One thing I have noticed with Panasonic is if the panel is like this and when you unplug the bad cable it will not change, but if you unplug and turn on a panel that is fine the line will show an array of rainbow sparkles.
              Make sure to reseat the cables good and firm before powering on the unit!
                Just checked.
                Ugh... Sorry, but that's bad news. Most likely, it means the panel has failed. More specifically, the chips bonded to the bottom of it. Essentially, new TV time, unless you can somehow find a new panel... and they aren't normally cheap.
                • SamIOW
                  • 7
                  AAhhh, Thanks anyway . looks like a new TV, might go back to a Sony what your thoughts about the 60 inch one which they have on offer??
                    Well, Panasonic -are- quite reliable. This is just bad luck to be honest.
                    In my opinion a Sony is just an overpriced Samsung (with the associated LCD panel issues.) So, avoid it. Avoid Samsung too.
                    If you have to buy an LED-backlit LCD TV, try getting an LG, Sharp (>55" only) or Panasonic. Those are pretty much the only three brands I can have any hope in... and in my opinion they aren't great anyway... but they're the best of a rather mediocre bunch.
                    • Shinju
                      • Mar 2014
                      • 1239
                      Spend the bread and get the Samsung PN64F8500 or the PN51F8500 will do well too Best PDP on the market right now... well the only PDP really that's worth it outside of going legacy Kuro or Panasonic but then you are getting into used territory.
                        Definitely try getting an F8500 Samsung plasma if you can... Samsung's LCDs are terrible, but their plasmas (in the high end) are pretty decent.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Panasonic plasmas are still the best hands down. You just had bad luck and sorry to hear that.
                          • SamIOW
                            • 7
                            Thanks for that.... To be honest I have always stayed away from LG as I thought ( not knowing why) gut feeling as they used to have a terrible reputation. So it is either a Panasonic or LG Budget is around £900 not much for todays market but xmas etc. any suggestions? was hoping for 50 - 55 inch and seeing that you have made me doubt the sony I am unsure.
                            • StevenG
                              • Jan 2015
                              • 3
                              • Scotland
                              Hi folks - first posting on this forum, so I need to hijack a thread with a similar problem. I have an LG 50PK590 which has developed a broad vertical black line initially about 3" wide but has now grown to 9" wide right in the center of the screen - arggh! I have spent a fair bit of time reading previous responses and tom66 refers to a C-Board as being a potential problem. I have the back off and would be grateful for advice.
                                This would be a bad panel since there are stuck pixels in the line. Bad TCP. Sorry.
                                • StevenG
                                  • Jan 2015
                                  • 3
                                  • Scotland
                                  Thanks for the quick response tom66. Anything I should double check before I strip it for parts?
                                    If you like, try reseating the connector for that part of the panel on the C-board, though I'd be surprised if that made any difference.
                                    • StevenG
                                      • Jan 2015
                                      • 3
                                      • Scotland
                                      I assume that the c-board is a pcb or pcbs along the bottom edge of the back of the panel with ribbon connectors trapped into them. Apologies for demonstration of ignorance!
                                        Yes, that's the board.
                                        • evanroheff21
                                          Panasonic TC-P65ST50 plasma vertical black section repairable?
                                          by evanroheff21
                                          I've acquired a 65" Panasonic TC-P65ST50 for free from someone while purchasing another TV for repair from them. I've repaired ~10 LCD TVs over the years with decent success, and I enjoy doing it. However this is my first attempt at a plasma, and I'm treading carefully.
                                          The TV when I got it would power up, however the left ~5 inches of the display was entirely black, basically like a letterbox image would appear. I disassembled, looked up some info, and determined that it was likely either dirty/loose connectors between the panel and the C buffer boards...
                                          03-10-2020, 10:15 PM
                                        • Raulnn
                                          Hisense LTDN40D36EU thin black vertical line
                                          by Raulnn
                                          good evening!!! I have this tv with a line that occupies 1 or 2 pixels in width. it has a solution? Can you do a test to find out if it's a panel or something else? Having the tcon integrated into the panel makes everything difficult. I have pushed on the flex attached to the panel, on both sides and there are no changes. I don't know what else I can do... the integrated ones that go on the flex get hot, but without burning yourself if you put your finger on it. to see if someone can help me. I attached a detail photo of the line. Thanks in advance...
                                          12-30-2022, 05:45 PM
                                        • Stasonio
                                          Panasonic TX-PR65VT60 plasma flickering pixels on black
                                          by Stasonio
                                          Hello!
                                          On my Panasonic TX-PR65VT60 plasma, flickering pixels (or subpixels) run uniformly on completely black areas of the image or on a completely black screen (for example, an image with completely black areas, black fill, or hdmi, AV input without a signal). This can be clearly seen in complete darkness at close range, and is very similar to how it is shown in these videos:
                                          https://youtu.be/IgcqC12Wc2U
                                          https://youtu.be/Bfzaw4D2Byg
                                          I repeat that this happens only in completely black areas, otherwise there are no complaints about the image and the operation...
                                          05-14-2020, 08:20 AM
                                        • Nirrain
                                          Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
                                          by Nirrain
                                          I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
                                          I've tried to change VSUS to high but it made the issue even worse so changed it back.
                                          However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
                                          When turned on the green LED flashes 6 times and then stays on continously....
                                          07-09-2021, 02:38 AM
                                        • TrueSword88
                                          Kogan - KALED65XU9220STB - Blue Vertical Line
                                          by TrueSword88
                                          Hi all.
                                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                          Hoping to fix...
                                          05-05-2023, 04:28 PM
