Panasonic TX-PR65VT60 plasma flickering pixels on black
  • Stasonio
    • May 2020
    • Russia
    Hello!
    On my Panasonic TX-PR65VT60 plasma, flickering pixels (or subpixels) run uniformly on completely black areas of the image or on a completely black screen (for example, an image with completely black areas, black fill, or hdmi, AV input without a signal). This can be clearly seen in complete darkness at close range, and is very similar to how it is shown in these videos:
    https://youtu.be/IgcqC12Wc2U
    https://youtu.be/Bfzaw4D2Byg
    I repeat that this happens only in completely black areas, otherwise there are no complaints about the image and the operation of the TV, the image is perfect!
    Please tell me what could be the matter?
    I'm even ready to buy and exchange any board for an original new one in order to avoid problems with replacing components, but I would like to know exactly which board (s) have a problem, because the price is quite high.
    P.S.
    The composition of the TV Panasonic TX-PR65VT60:
    P(MAIN)-Board: MPF6915
    P(SUB)-Board: MPF6916
    A-Board: TNPH1044 (YG TXN/A1ULUR I)
    SU-Board: TNPA5734
    SD-Board: TNPA5735
    SC-Board: TNPA5795
    SS-Board: TNPA5796
    SS2-Board: TNPA5798
  • Nirrain
    Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
    by Nirrain
    I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
    I've tried to change VSUS to high but it made the issue even worse so changed it back.
    However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
    When turned on the green LED flashes 6 times and then stays on continously....
    07-09-2021, 02:38 AM
  • survivalbloke
    HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
    by survivalbloke
    SN: 8CG0213H8W
    ProdID 3C311UA
    This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
    05-08-2025, 12:21 PM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • stecos
    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
    by stecos
    Hi everyone!
    I happened several times, in the search for help from the web, to consult this very interesting forum.
    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
    Having said that I come to the gist of my post on the forum as the title suggests.
    For my passion for technology I'm now collecting several...
    11-28-2022, 11:39 AM
  • canadaboy25
    Panasonic TH-50PX60U Plasma Black Bars
    by canadaboy25
    Hey guys, I have a Panasonic plasma here with two black rectangles in the display. As you can see from the picture, they affect the menus as well. Both black rectangles extend to exactly the center of the screen. I'm not super familiar with the workings of the display driver layout. Would this indicate a bad ribbon connection on the top and bottom boards? The TV has ribbons along the entire top and bottom of the display.
    Any ideas are appreciated....
    12-15-2020, 12:35 PM
