Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
  • Nirrain
    • Jul 2021
    • Denmark
    I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
    I've tried to change VSUS to high but it made the issue even worse so changed it back.
    However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
    When turned on the green LED flashes 6 times and then stays on continously. My understanding of the service manual (link) is that it should flash X times and then pause for 3 sec before flashing again, or is the key point simply how many flashes initially? I have attached a slow motion video of the flashes
    So I would appreciate help with the following:
    1. Should the LED flashing be interpreted as 6 blinking times making the issue the "Driver SOS1", "SC Energy recovery circuit", "A-SC FPC DET"?
    2. If what can I do to more specifically identify what needs to be changed?
    3. Would that be related to the issue with pink flashing spots or can I expect that even if I fix the black screen I should expect to still have the other issue?
    Thank you!
  • Lintesir
    Panasonic P42S30 Plasma - Pink sparkles
    by Lintesir
    My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
    There is about a 5cm high region at the top without any sparkles,...
    07-26-2024, 03:16 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • stecos
    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
    by stecos
    Hi everyone!
    I happened several times, in the search for help from the web, to consult this very interesting forum.
    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
    Having said that I come to the gist of my post on the forum as the title suggests.
    For my passion for technology I'm now collecting several...
    11-28-2022, 11:39 AM
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • Alicat
    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
    by Alicat
    Stopped by this site trying to fix my parents Panasonic Plasma TV.
    Model number is TH-50PZ85U
    Power comes on and the red power light stays on solid.
    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
    I also hear a few clicks.
    I also think my parents said there was a thunderstorm and the TV failed after that.
    Section 6 in the service manual talks about power and no screen,...
    10-30-2024, 10:09 AM
