Samsung UE46F6500SS bad panel after just 8 months
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    A neighbor asked me to take a look at his TV that he brought from Germany. He said that at first it would go dim and make some lines and colors over the screen, after the TV had been on a couple hours. This got worse and worse until it became permanent.
    The TV has less than 3 months of actual use before it developed the fault.
    I feared the worst, and confirmed it. We pulled the set out of its box, powered it up and it immediately started acting up. The patterns looked like a T-Con problem... until i noticed 3 thin lines on the right side of the panel. Having a hunch that this TV would have an upside down panel, i pressed on the bottom right corner of the screen. The flickering went away. Some more pressing on the LCD removed two of the lines. The 3rd one doesn't want to go away but it's at the very edge so it won't bother anyone.
    They asked me to leave it like that for now and they'll call me tomorrow if it's acting up again. I'm preparing the thermal pads already, it looks like the first two tabs will need some attention. Still, this is a shame. Less than 1 year old and the panel went bad. And hauling it back to Germany for warranty isn't an option.
    So... Friends don't let friends buy Samsung.
    A working TV? How boring!
    Re: Samsung UE46F6500SS bad panel after just 8 months
    Ugh, seems to be an epidemic. I thought that D-series panel failures were bad enough. Saw some E-series too. And now F-series? What future holds for Samsung's H series panels?
    My brother's UE46ES8000 has a suspected intermittent panel fault... 18 months old, out of warranty.
    If it ain't the panel... it's the LEDs in it!!!
      "If it ain't the panel... it's the LEDs in it!!!" Very sad indeed.
      • sordids999
        • May 2013
        • 2152
        im slightly confused tom so if my ue46c6530 that i tried to fix the other day but found that if i pressed on the BGA on the main board fixed my picture,but my picture fault is exactly the same as most of people pictures there posting but finding out its there panel that is faulty so could my tv be the panel still ?
          It's a Samsung. Panels going bad seems to be their game and name. The BGA on yours has failed. But who knows if the panel would last? The C series sets like yours aren't well known for bad panels, but some have been seen. By far the worst are the A series and D series panels.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Update. They eventually took it to a local service center where they explained they would have to "disconnect" the affected area for the TV to work properly.
            Most likely they'll just cut off that tab entirely. Oh well... if they'll have a TV with a couple inches-wide black strip on the right side, AND other issues will continue, at least it won't be me getting blamed for it.
              They can try that, but many panels drive the gate signals through the left and right drivers... disconnect that, and it isn't going to work correctly...
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Not like i care. It isn't my TV.
                I have zero tolerance for those who tell me that they're going to employ me to do a repair for them, and then go someplace else. I'm not here to fix someone else's failed experiments.
                • learnmore
                  Samsung UE70TU7020K Which lines to tape on a bad panel
                  by learnmore
                  Hello Community,
                  I'm working on a Samsung UE70TU7020K.
                  It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
                  I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
                  03-15-2024, 03:01 PM
                • Anonmis
                  Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                  by Anonmis
                  Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                  The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                  12-01-2023, 04:31 PM
                  09-07-2024, 05:50 AM
                • NWArkGuy
                  Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                  by NWArkGuy
                  Well, I will be the first to admit that I screwed up...
                  In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                  I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                  I have 2 that I have found and have in my possession. ...
                  10-12-2023, 10:13 PM
                • KYBOSH
                  Samsung UN50TU8000 - Dead Panel Forensic Questions
                  by KYBOSH
                  I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                  When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                  When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                  Later I checked for shorts on the panel PCB boards but could not find anything.
                  When I took a look with the FLIR i noticed the 2 resistors...
                  08-10-2024, 08:39 AM
