Philips 32PFL5322D/37
  • joshthefisher
    • Nov 2014
    • 13
    • Bahamas
    Good day all,
    I have a 32PFL5322D/37 lcd tv not turning on just the little blue led lights once when you push power then cycles red 6 flashes break for 3 sec than repeats.
    I am not too familiar with this design TV, I have only worked on led tvs so far. So not to sure on how to trouble shoot. Based on a thread here it leads me to believe main board but from some research on Google found many others pointing to power supply. All with the same led sequence. Any help on how to determine troublesome component greatly appreciated.
    Thanks in advance,
    Josh
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Philips 32PFL5322D/37
    I actually just repaired one of these recently with the same symptom. Ended up being the audio / standby board. That would be my first guess based on my experience.
    • joshthefisher
      • Nov 2014
      • 13
      • Bahamas
      Thanks for the info. But I really need a guide to troubleshooting the exact part. How did you come to find out it was audio / standby board?
      • joshthefisher
        • Nov 2014
        • 13
        • Bahamas
        Originally posted by joshthefisher
        Good day all,
        Thanks in advance,
        Josh
        Update:
        I have 5vdc at standby pin on psu. Unpluged t con board and got 2 green leds on main board and 1 green led on the audio standby board(board with cable going to tcon) .
        Any suggestions?
          What is the chassis number as shown on the model number sticker on the back of the TV?
          For example:
          http://elektrotanya.com/?q=showresul...oria=&kat2=all
          • joshthefisher
            • Nov 2014
            • 13
            • Bahamas
            Originally posted by budm
            what is the chassis number as shown on the model number sticker on the back of the tv?
            For example:
            ej3.ou la
              OK, I not sure if these will mach your TV or not, download them and see:
              • joshthefisher
                • Nov 2014
                • 13
                • Bahamas
                Got 1 downloaded but is not it. Says ive exceeded my limit but only downloaded 1. The other looks similar but is 32PFL5332 not 32PFL5322D/37
                  OK, please upload good clear pictures of the back side of the TV so we can see how all the boards are connected together, and then the pictures of each board.
                  I was hoping the service manual will be close enough to use to see if it has any error codes listing to tell us what the problem is.
                  • joshthefisher
                    • Nov 2014
                    • 13
                    • Bahamas
                    https://www.badcaps.net/forum/attach...1&d=1327720780
                    From the pic above Where would I need to jump to turn on psu? Im quite sure my problem is main board would like to make sure i have backlight.
                    • joshthefisher
                      • Nov 2014
                      • 13
                      • Bahamas
                      http://www.scribd.com/doc/46693741/32PFL5322D
                      Found this manual
                        Right now I cannot tell if this TV uses ACTIVE I or ACTIVE LO to activate the function.
                        You need to look at pin 11 (The STBY (PS_ON) pin 11,), and pin 12 (BL_ON) when power TV is OFF and when TV power switch is activated, report the readings.
                        To find out if the inverter for backlghts is OK not, you will need to find out if this power supply has 24V power supply for the backlights inverter or if this is power supply-inverter board combo type, I cannot tell since I do not have the pictures of the boards.
                          I cannot do free download I do not have SCRIPD account, $8.99 for One-day access?
                          Did you download it? It is for chassis EJ3.0U-LA.
                          https://www.scribd.com/archive/plans?doc=46693741&escape=false&metadata={%22context%22%3A%22archive_view_restricted%22%2C%22page%22%3A%22read%22%2C%22action%22%3A%22download_promo%22%2C%22logged_in%22%3Afalse%2C%22platform%22%3A%22web%22}
                          Beside, it is the same one from ELEKTROTANYA that you said it is not the same as your TV:
                          EJ3.0U-LA which is what you have.
                          Look at the one in your link, it is the same EJ3.0U-LA which is for 32pfl5332.
                          Did you look at the manual to see if the boards are the same as yours?
                          • joshthefisher
                            • Nov 2014
                            • 13
                            • Bahamas
                            No i looked at the first three pages posted it, went to continue and figured out it was pay. Sorry
                            ET wont let me dl more till tomoro.
                              So which one did you download?
                              This one?
                              Which is for the chassis EJ3.0U-LA.
                              • joshthefisher
                                • Nov 2014
                                • 13
                                • Bahamas
                                This one?
                                no the other 1. Im currently trying to get some voltages. Every time I pull the connector off of the mainboard for about 30 seconds the set will try to power up when I put it back on and ive got a few voltages so far trying to get the rest. Pin 12 was 3v though when it attempted to power up.
                                • joshthefisher
                                  • Nov 2014
                                  • 13
                                  • Bahamas
                                  Here are the powered up readings:
                                  pin
                                  1: -18v
                                  2: 18v
                                  3: 5mv
                                  4: 5v
                                  5: 5v
                                  6: 2mv
                                  7: 1.5mv
                                  8: 1.5mv
                                  9: 12v
                                  10: 12v
                                  11: 260mv
                                  12: 3v
                                  13: 230mv
                                    It would have been much easier to read the result if you put the labels (https://www.badcaps.net/forum/attach...1&d=1327720780) next to each pin and the state of when they are measured
                                    I need to know the Voltages when TV is OFF and when TV is on so I can see if any of the Voltages have changed state.
                                    1: -12~16-NF = -18v
                                    2: +12~16-NF= 18v
                                    3: GND-D = 5mv
                                    4: +5V2-STBY = 5v
                                    5: +5V2-STBY = 5v
                                    6: GND = 2mv
                                    7: GND = 1.5mv
                                    8: GND = 1.5mv
                                    9: +12VS = 12v
                                    10: +12VS = 12v
                                    11: STANDBY = 260mv
                                    12: BACKLIGHT-CNTRL-OUT = 3v
                                    13: LAMP-ON-OUT = 230mv
                                    So those Voltage readings above are when the power switched is activated? How about when the TV is OFF?
                                    • joshthefisher
                                      • Nov 2014
                                      • 13
                                      • Bahamas
                                      1: -12~16-NF = -18v
                                      2: +12~16-NF= 18v
                                      3: GND-D = 5mv
                                      4: +5V2-STBY = 5v
                                      5: +5V2-STBY = 5v
                                      6: GND = 2mv
                                      7: GND = 1.5mv
                                      8: GND = 1.5mv
                                      9: +12VS = 12v
                                      10: +12VS = 12v
                                      11: STANDBY = 260mv
                                      Yes.
                                      Here are the readings whrn tv is just giving the 6 red flashes:
                                      pin
                                      1: -12~16-NF = 0
                                      2: +12~16-NF= 0
                                      3: GND-D = 0
                                      4: +5V2-STBY = 5.14v
                                      5: +5V2-STBY = 5.14v
                                      6: GND = 0
                                      7: GND = 0
                                      8: GND = 0
                                      9: +12VS = 6.6mv
                                      10: +12VS = 6.5mv
                                      11: STANDBY = 5.14v
                                      12: BACKLIGHT-CNTRL-OUT = 0
                                      13: LAMP-ON-OUT = 225.5mv
                                      • Geeker007
                                        Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                                        by Geeker007
                                        I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                                        To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                                        However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                                        I am using below components:
                                        • Buck Converter: TPS562201 (12V → 5V regulated)
                                        • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                                        • LED Strip: WS2815 (12V digital LED strip)
                                        • Switching
                                        06-29-2025, 05:20 PM
                                      • aidanmo
                                        Philips 43PUS7506/12 - Loud blown out sound
                                        by aidanmo
                                        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                        I thought maybe the speakers got damaged, so I replaced them - no dice.
                                        • Using the internal speakers, it always happens.
                                        • Using the headphone jack, it never happens.
                                        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                        02-28-2025, 03:13 PM
                                      • Cornito
                                        Philips 50PUH6400 bad color and gosting / slow motion on one side
                                        by Cornito
                                        Hello Team,
                                        New issue on LCD panel where I need to find out the cause and the potential solution.
                                        This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                        I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                        When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                        I've checked voltages, no issue found comparing right and left side of the panel driver.
                                        VHG VGL CKV... are the sames on...
                                        03-08-2024, 06:41 AM
                                      • spantor
                                        Activate power board Philips 40PFH40009/88 tv
                                        by spantor
                                        Hello partners.
                                        Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                        The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                        02-11-2024, 05:07 PM
                                      • lanada
                                        philips 55pus7909/12
                                        by lanada
                                        i have a philips for repair 55pus7909/12
                                        fault is no display but the white logo philips lit below of the screen
                                        No display
                                        No backlight
                                        no sound
                                        power supply the standby voltages are ok
                                        Any Help regarding this problem?
                                        11-07-2023, 02:31 AM
