Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
  • Geeker007
    • Jan 2025
    • 20
    I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
    To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
    However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
    I am using below components:
    • Buck Converter: TPS562201 (12V → 5V regulated)
    • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
    • LED Strip: WS2815 (12V digital LED strip)
    • Switching MOSFET: Logic-level N-MOSFET (IRLZ44N)
    • Level Shifter: BSS138 MOSFET-based (3.3V to 5V data line)
    • Status LED: Green LED
Name:	Screenshot 2025-06-29 161310.png
    I've attached the schematic—could you please review it and let me know if I've missed anything or if there are areas for improvement?
    I designed it with limited experience, so I’d really appreciate your feedback on whether the setup is correct and functional.
  • Geeker007
    • Jan 2025
    • 20
    I have updated TPS562201 with TPS62840DLCR as per search online. Better option?
    Adding updated schematic
Name:	Screenshot 2025-06-29 165245.png
    • Geeker007
      • Jan 2025
      • 20
      Click image for larger version  Name:	Screenshot 2025-06-29 165245.png Views:	0 Size:	47.1 KB ID:	3671071
      Ignore this change. I think I made a mistake by adding lower input voltage buck converter? So TPS562201 is fine or there is better option?
        • 31246
        if thats eaglecad then use the SMASH button to seperate the symbols from the labels
        • truclacicr
          • Apr 2019
          • 352
          • australia
          The feedback makes no sense (VFB and VOS). There should be potential dividers.
          • Geeker007
            • Jan 2025
            • 20
            Here is the updated one.
Name:	Screenshot 2025-07-03 144917.png
            Can you please explain a bit more may be through change in schematic? Sorry new to circuits but ready to learn.
            • truclacicr
              • Apr 2019
              • 352
              • australia
              See the "Reference Design" on page 12 of the datasheet:
              https://www.ti.com/lit/ds/symlink/tps562201.pdf
              There is a potential divider between Vout and Vfb.
              Vout = Vfb x (1 + R1/R2) = 0.768 x 1.309 = 1.005V
              • Geeker007
                • Jan 2025
                • 20
                Made some changes. Can you guys please review now and provide me the feedback. Any other suggestions here?
                  • 31246
                  whats that ttl chip about?
                  is it intended as a buffer for the esp output?
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • DXseekerMO
                    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                    by DXseekerMO
                    Hello everyone!
                    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                    Yes
                    0%
                    1
                    All backlight strips are the same quality
                    0%
                    1
                    No
                    0%
                    0
                    12-16-2021, 03:58 PM
                  • adelage
                    220v Led strip flickering
                    by adelage
                    Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                    I know that the best solution would be to get a voltage...
                    11-03-2024, 09:49 AM
                  • benareeno
                    Adjustable dc power supply and tcl led strip
                    by benareeno
                    I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                    I have an adjustable dc power supply and was trying around 9 volts.
                    I have a pic of a single diode...where to put pos and neg terminals to light it up?
                    Pic of middle of strip..is this where i light the entire strip?
                    And pic of end...or does this light the entire strip?
                    Where to put pos and neg for single diode..multiple diodes and the entire...
                    07-11-2021, 02:31 PM
                  • eccerr0r
                    What to do with bad LED strips?
                    by eccerr0r
                    I suspect a lot of you have done a lot of repairs and end up with a lot of bad LED strips...what do you do with them?
                    Wonder if I should get a pile of LED chips and try to replace the bad units for the heck of it, but I don't really need the strips at the moment because I bought the strips...
                    Oh... and I think I got my TV working again, though not 100% I don't think, on a white screen I can see a bit of the ghost of the LED strips, must have done something wrong or the LED strips aren't quite the same as the original...
                    10-22-2022, 12:27 AM
