Samsung LN32D403E4D. Sound, No Backlight
  • ikeoyou
    • Oct 2014
    • 22
    Re: Samsung LN32D403E4D. Sound, No Backlight
    I see. I tested the voltage on the inverter board and it would cycle from 0V to ~200mV. Is this normal or a sign that the inverter is not receiving enough voltage from the power supply?
      The inverter circuit is fed by that 391V to that fuse that check out fine, some how that inverter section is not running.
      • selldoor
        Slow Learner
        • 7870
        Originally posted by budm
        I will have to do lots of circuit tracing using the pictures to see how they are connected using pictures from SJ:
        http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
        It will be quite time consuming since we do not have the circuit diagram for this power supply board.
        Does this help at all ( Its only a diagram for the SEM2106)
        https://www.badcaps.net/forum/attach...7&d=1405181144
        • selldoor
          Slow Learner
          • 7870
          @ikeoyou.
          When you have 391vDC on the BIG cap can you carefully test the voltage on each side of the fuse - Black lead on neg leg of BIG cap probe each side of fuse with
          red lead. Then do the same on the Diode to the right of the fuse and then to the
          fat red cap at the end. All high voltage so care required.
          I read on another post on a similar board the diode next to the fuse failed.
          @andariego
          Are you working on the same/similar board, if so perhaps you can chip in with any info you have?
          • andariego
            • Mar 2011
            • 20
            Originally posted by selldoor
            @ikeoyou.
            @andariego
            I was working on a Samsung power supply BN44-00440B, and had the same problem. Fix by changing an IC "FAN7930B". I think that is different to that which Ikeoyu has.
            • ikeoyou
              • Oct 2014
              • 22
              On each side of the fuse is 392V.
              On each side of diode is 392V.
              Red cap climbs from 150mV to 200mV and drops and repeats.
              • ikeoyou
                • Oct 2014
                • 22
                how did you arrive at the conclusion that the ic was the culprit?
                • andariego
                  • Mar 2011
                  • 20
                  #28
                  to be honest I found the fix solution from another web
                  site
                    FAN7930B is the PFC Controller IC:
                    But you do have 391VDC on the main filter cap so the IC is working.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      #30
                      I've had two of these sets already with backlight problems (and they aren't very old). Both had one bad ccfl. I sacrificed one to fix the other. Both would flash for a seconds at startup before the inverter shut down. I wasted a ton of time on them before figuring it out. Just a thought.
                      • ikeoyou
                        • Oct 2014
                        • 22
                        thanks for the input fellas. I grew tired of trying to diagnose this half-working board and instead ordered a new power supply board from eBay for $28.
                        It arrived today and fixed the issue. TV now works fine. Now i must figure out what to do with this power supply as well as the inverter board i ordered.
                          Thanks for the follow-up, can't be $28.
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Max514
                            Samsung UN55H8000 sound but no backlight no video
                            by Max514
                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                            • Unplugging the main board cable at the power supply >>> backlights came on.
                            • BLU_ON signal from the
                            04-14-2022, 10:34 AM
                          • arctor
                            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                            by arctor
                            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                            04-26-2025, 05:22 AM
