Vizio XVT553SV Powers on and has sound but no picture
  • 1997eclipsegst
    • Feb 2013
    • 99
    • US
    Hey everyone,
    I am working on a Vizio XVT553SV 55" LED tv and not sure what else to check.
    When I received the set it would power on with backlight and sound but would not display any picture.
    Voltages to the mainboard:
    Fuse
    F1-12.14 vdc
    F3-5.07 vdc
    F8-18.34 vdc
    Tcon:
    TF1-12.03 vdc
    F4-5.12 vdc
    After reading many posts about these and mainboard issues that they have I purchased a replacement mainboard from a "refurbished tv broke in transit" on ebay.
    After swapping the mainboard out I have the exact same symptoms as above.
    Does this possibly sound like a bad Tcon or panel? or another defective mainboard.
    Any help would be great on anything else to check.
    Thanks in advance,
    Ryan
  • MisterD
    • Oct 2012
    • 668
    Re: Vizio XVT553SV Powers on and has sound but no picture
    I can't say for sure but it could be a bad T-Con board, I suggest checking all connectors/cables at the T-con board to ensure the ribbon cables are fully seated.
    • 1997eclipsegst
      • Feb 2013
      • 99
      • US
      Thanks for the reply MisterD.
      I reseated the ribbons and connectors with no change.
      I had the set on for a couple of hours (with no change to the picture) and noticed the large black heatsink was cool to the touch (room temperature) I would have assumed it would be a little warm?
      The heatsink is held on with 4 spring loaded clips so I decided to take it off and have a peek underneath.
      It appears that the gpu underneath is simmilar to a laptop gpu. I have had a few laptops that have had the gpu fail from the lead free solder joints breaking under the gpu.
      I am thinking of trying a reflow (heatgun) and see if anything changes.
      Any thoughts before I try?
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Did you successfully reflowed a gpu from a laptop before? That chip looks alot like the Ati chips in laptops but i don't know if its soldered the same way.
        • 1997eclipsegst
          • Feb 2013
          • 99
          • US
          I have been able to get a couple laptops working with a reflow but have only lasted a couple moths before failing again. A full reball of the gpu is recommended.
          But if this would at least show me that it would work I would know that everything else is good before ordering a replacement Tcon.
          • MisterD
            • Oct 2012
            • 668
            Did you try the reflow?
            • 1997eclipsegst
              • Feb 2013
              • 99
              • US
              After looking at the T-con a little closer I noticed one side of the gpu was pulled up and the board was a little warped in that area. I decided to not even try a reflow and just ordered a replacement board.
              I will update when the replacement board arrives.
              • 1997eclipsegst
                • Feb 2013
                • 99
                • US
                Wanted to update this.
                I received the replacement T-con and the TV works perfect now.
                Thanks for everyone's help.
                • MisterD
                  • Oct 2012
                  • 668
                  Good to hear you fixed it.
                  • ringking97
                    • Jul 2015
                    thanks for the info but What is a T-CON board??
                      Timing Control board.
                      The board on the top middle of the LCD panel, it is connected between the LCD panel and the main board.
                      • csmith
                        Vizio D50u-D1 Powers up no picture
                        by csmith
                        I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                        Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                        supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                        issue. Set will power up with remote but not power off....
                        07-11-2025, 11:52 AM
                      • ggil44
                        Vizio M65-E0 No Picture, No Sound
                        by ggil44
                        Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                        09-03-2024, 08:30 PM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                        I ordered a supposedly β€˜new' Tcon board this time, and
                        06-09-2024, 10:28 AM
