Andersson TV + 17PW26-4 psu won't turn on?!
  • Eriksson
    • Oct 2014
    • 10
    • Sweden
    Hi guys..
    Got an Andersson Tv 40" model A401FD.
    So my problem is,
    The TV won't turn on from standby and goes automatically back to standby after trying to turn it on. NOTICE that I got no picture what so ever. Only that the standby led disappears when I'm trying to turn it on.
    The sound from the control panel on the tv works fine when I'm trying power/channel/volume buttons.
    So I started doing some checks on the PSU
    Can't find any caps damages.
    The transistor/diod at the back side D879 is missing the middle pin?(3pins in total) tried to cold measure these outer two in diod mode which gave me just *beep*
    My readings on the connector to Mainboard is
    Pin 6 Standby 3v approx when turned off otherwise around 0.2
    Pin 12 12v
    Pin 16 3.3v
    Pin 20 3.3v
    Pin 24 0v
    Pin 26 24v
    These reading were measured when the TV was "on"
    Would be really grateful for any help.
    Thanks a lot in advance guys.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Andersson TV + 17PW26-4 psu won't turn on?!
    Check the PFC Voltage Across the main smoothing electrolytic, Should be around 400V
    If its only 350 ish, the PFC Isnt working and the PSU will either Not start up, Or start Intermittently, but then run OK....
    However--reading through your symptoms, It doesnt look like the PSU is actually at fault, as its starting and running, just that you have Sound but No Picture....
    Check Backlights coming on or not and also the fuse on the T-Con board....
    TELEFIX
      https://www.badcaps.net/forum/showthread.php?t=39740
      • Eriksson
        • Oct 2014
        • 10
        • Sweden
        Psu
        • Eriksson
          • Oct 2014
          • 10
          • Sweden
          Motherboard
          • Eriksson
            • Oct 2014
            • 10
            • Sweden
            T-con board.
            Sorry about reposting, didn't manage to upload multiple pictures in one reply for some reason..
            Did test the fuse on the T-con board, it was ok. Not sure how to test the "PFC voltage" though.
            However, why I do suspect the PSU is because when I try to turn the tv on, it goes automatically back to standby mode after about 10 seconds. I do not hear any audio at all besides from the clicks when I'm pressing the control panel. Don't think any backlights work either.
            I also discovered that the same problem is still there when I remove the T-con board and try to turn the TV on.
            Thanks in advance
            • Eriksson
              • Oct 2014
              • 10
              • Sweden
              Tried disconnecting backlighting today - still got the same problem. Is it possible that the control panel on the tv could be the problem?
              When I disconnect the control panel, the led lamp just keep blinking slowly and in the same slow speed. Is it possible to "jump" the control panel? Doesn't care If it works or not. Still got the remote and I just want the tv to work.
              • arizanotlari
                • Nov 2014
                • 158
                • Turkiye
                Hi.
                unplug tcon and inverter board and start tv. if standby led working normal check tcon board, if still blink change r818 r819 r819 resistors to 620 kilohm (original 320K)
                • arizanotlari
                  • Nov 2014
                  • 158
                  • Turkiye
                  Edit : r817 r818 r819 on pw26 board
                  • Eriksson
                    • Oct 2014
                    • 10
                    • Sweden
                    Some update...
                    I've replaced following PSU components...
                    Fuse F800
                    Q803
                    Ic802
                    R829
                    R830
                    R817
                    R818
                    R819
                    C840
                    C801
                    C814
                    C892
                    Still no difference at all.. Not sure if it's the PSU or something else that's the problem. Please help!
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Unplug the motherboard from the psu, and jumper the ps on pins then test and see if the psu starts any of the voltage rails, you may need a 100ohm + resistor.
                      • selldoor
                        Slow Learner
                        • 7870
                        Need to establish if the screen flashes at all ? try in a dark room.
                        Also need a picture of the inverter board there are often fuses on it.
                        Did you try and look for a picture using a flashlight at angles on the screen.
                        Reeceyburger - dont know if you spotted it but early on he said he has sound
                        so at least some of the power supply is working.
                        • Eriksson
                          • Oct 2014
                          • 10
                          • Sweden
                          As written before, when trying to start the TV, I have 3.3v, 5v, 12v and 24v. When the TV goes automatically back to standby mode, that is, after about 10 seconds, all voltage disappears.
                          Or did I misunderstand what you meant reeceyburger123?
                          Thanks for answer
                          • Eriksson
                            • Oct 2014
                            • 10
                            • Sweden
                            Thanks for quick answer selleoor,
                            No picture at all, no backlighting what so ever,
                            I'll try to fix a picture of the inverter board. However,
                            When I have inverter board and Tcon board both removed, I've still got the same problem, that said, the only components connected is PSU, motherboard, standby led, speakers and side control panel (touch)....
                            • selldoor
                              Slow Learner
                              • 7870
                              Sometimes when it is not all connected up the protection circuits kick in and close the power supply down. I will let Reeceyburger speak for himself but I think he is trying to test
                              just the power supply to see if it stays on. The jumper he mentions is to keep it on, in place of the signal from the mainboard
                                Or check the DC Voltage on the PS_ON pin to see if it goes away.
                                Good clear pictures of the power supply board, both sides?
                                • Eriksson
                                  • Oct 2014
                                  • 10
                                  • Sweden
                                  Thanks Guys,
                                  Fuses on inverter ok.
                                  I'll fix pictures in a couple of minutes and check things. What pin is ps_on?
                                  And I did find a exactly similar problem which I'm having on YouTube, also with same PSU. Please give it a look. It is exactly similar situation for me.
                                  http://m.youtube.com/watch?v=izJnFWLnzR0
                                  I haven't replaced any of these caps because they all look ok, maybe I'll have to have a closer look.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Thanks for answer
                                    What I was saying is you should test the psu with nothing hooked up to see if the voltages remain, if they do then the psu is likely not faulty.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      In usual vestel fashion the caps may be different values and/or in different positions - there are more caps on your board than in the video. The big one of the group may look slightly rounded but cant tell from the camera angle.
                                      It is the one in the video with a hole in the top!!
                                      They should be replaced with low esr good quality caps.
                                      Are there no markings on either boards to say what the pins are.
                                      Being a vestel - probably not!! PSon is likely to be one with 2-3 volts on it initially.
                                      • PNI E.
                                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                        by PNI E.
                                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                        03-17-2025, 04:23 AM
                                      • madsox
                                        Harman Kardon AVR 171S - standby led lights up, does not turn on
                                        by madsox
                                        Greetings!
                                        Thank you in advance for your understanding, I am writing to you through a translator.
                                        A Harman Kardon AVR171S amplifier was given.
                                        The history of the machine is as follows:
                                        It was faulty when I bought it, I want to fix it.
                                        I replaced the HDMI switch and one of the DAC ICs in it.
                                        After that it worked without a problem.
                                        I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                        The cooling was faulty, I will fix this later.
                                        I switched it to standby mode, waited for...
                                        09-24-2022, 10:46 AM
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • Doodle43
                                        Samsung LN32B540 - won’t turn on but gets standby power
                                        by Doodle43
                                        My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                        It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                        05-26-2020, 12:02 PM
                                      • Adenitz
                                        Troubleshooting Vestel TV, has standby, but cannot turn ON
                                        by Adenitz
                                        I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                        Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                        Both boards are shown in the attached photos.
                                        What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                        12-27-2023, 03:43 AM
