Vizio E371VL Fixed!
  • Paul Revere
    • Oct 2014
    • 11
    Vizio E371VL Fixed!
    I was working on this TV and found the problem after replacing the EEPROM.
    Symptoms were would turn on and display dim vizio symbol on the screen. The vizio label would change from amber to white and it would stay running. No display after the initial one on the screen went dark. No menu, sound or picture. Found shorted diode on power supply location D602. Part was labled
    MUR460ax.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio E371VL Fixed!
    I think, that I had this problem with another Vizio and it was the same model, but it would not turn on at all.
    I have a VA model now and even by replacing the EEPROM, it still won't turn on.
    Backlight comes on, if I force the PS.
      I am curious as to where D602 is in which part of the power supply board.
      • tibimakai
        • Jan 2012
        • 3680
        On mine, it was the upper left diode in a 45 degree position, next to that red transformer(?).
        https://www.badcaps.net/forum/attach...3&d=1383452706
        • jscifi
          • Oct 2012
          Thank you for posting this it fixed my vizio tv. My vizio logo on screen display was dim too and it would flash for a second and go dark.
          • crxguy89
            • Mar 2014
            • 12
            MUR460ax.
            Mine is doing something similar. I tried to test this diode. I have a meter with a diode test setting. It has been a while since I have done anything board level. This diode was reading .4 volts something is that bad? I thought a good one should read between .5 and .8 volts. It was showing 'open' in reverse. Like I said... I am rusty. Thanks in advance.
              The diode is Shottky diode so the Vf is less than typical Diode.
              Can you show us the pictures of where this D602 is? I would think if the power supply has shorted diode the power supply will be in the shutdown protection mode.
              • vinceroger69
                • Mar 2012
                • 6714
                thats probaly ok if it reads in one direction only whats the fault with uour set?
                  BTW, there are more than one version of this TV model.
                  http://www.shopjimmy.com/catalogsear...q=Vizio+E371VL
                  If I look at the correct board, the D602 is in the PFC Voltage booster section.
                  So are you getting the boosted Voltage from the main power supply?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Same issue with Vestel power supplies too, MUR460 pfc diode blows causes low standby voltage and makes the set look dead.
                    • crxguy89
                      • Mar 2014
                      • 12
                      They symptoms are:
                      I plug in the TV. The Vizio light is amber. I turn on the power button and the Vizio light goes white and nothing else happens. No screen, no sound, etc... No buttons are responsive. Power button will NOT turn the set off. I included pics of the boards. Their board numbers. And the diode in question.
                        OK, that diode is part of the PFC Voltage booster circuit, if the circuit is ok then when you turn on the TV the Voltage between the two legs of the main filter cap should be close to 400VDC.
                        • crxguy89
                          • Mar 2014
                          • 12
                          Thanks Budm. Do you know if there are test points for it on the front of board?
                          Thanks again.
                            Thanks again.
                            OK, I trace out the connections on the bottom side of the board, the Cathode of diode D602 and D606 are connected to the + leg of the main cap, the jumper wire JW10 and JW14 are connected to the - leg of the main filter cap so you can easily measured the dcv on the main filter cap from the top side of the board.
                            So Red probe on the Cathode (banded side), Black probe on JW14.
                            • crxguy89
                              • Mar 2014
                              • 12
                              I have 393 VDC in this circuit. I have no idea where to go from here. Can you tell me what I should be looking for from here.
                                The PFC is OK.
                                From your post 'No buttons are responsive. Power button will NOT turn the set off. I included pics of the boards.' It points to the problem on the main board or something is locking out the main board, but at this point we need to know what DCV you have on the connector of the power supply board that goes to the main board first.
                                As you can see that there are labels for each pin of the connector, we need to know what the Voltages are, make sure to report the pin name follow by the Voltage reading for each pin.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  if all of the voltages test ok it maybe another vizio eeprom issue
                                  • crxguy89
                                    • Mar 2014
                                    • 12
                                    The PFC is OK.
                                    Here are the results.
                                    (Some of these names may be wrong. They were hard to read)
                                    VBR_R = 3.3VDC
                                    Status = .25VDC
                                    on/off = .3VDC
                                    on/off = 3.3VDC
                                    12V = 12VDC
                                    12V = 12VDC
                                    12V = 12VDC
                                    GND = Closed circuit to Chasis Ground
                                    5VSB = 5VDC
                                    5VSB = 5VDC
                                    5VSB = 5VDC
                                    Let me know what you make of all this. Thank
                                      From the look of it, the two ON/OFF pins, one of them has to be for the PS-ON for turning on the rest of the power supply and it is working (the one with 3.3VDC) otherwise you will not have that PFC Boosted Voltage on the main cap, the other ON/OFF (0.3VDC) is probably for the BL-ON for turning on the backlights and it is not working because it is <1VDC.
                                      So the main board is the problem at this point.
                                      There are fuses and Voltage regulator ICs on the main board that you should check.
                                      • crxguy89
                                        • Mar 2014
                                        • 12
                                        Thanks Bud.
                                        The fuses I can check. The ICs. I do not know how nor would I know what is a good range for them to be in.
                                        Should I just replace the main board? I would rather try to repair....
                                        Any suggestions?
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • otaku_nut
                                          Vizio E701i-A3 fixed but now has red vertical line
                                          by otaku_nut
                                          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                          08-19-2025, 06:11 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • tmhobadcap
                                          VIZIO M60-C3 Can the vertical line be fixed?
                                          by tmhobadcap
                                          I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
                                          02-05-2023, 03:37 AM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
