There is a -Vy and Vsc module. The -Vy module should be marked. Yes it's one of those stand-up board things which has lots of other parts on it.
Ok, worth checking a few things:
- D22/D23 for shorts
- C20 solder joints look dodgy
- Q20 for shorts
- VR20, between outer two terminals, what do you measure on 200kohm range?
Sorry for missing your post.
Nothing obvious there, I'm afraid. Nothing shorted.
Perhaps try replacing the IC "U20"...
Yeah, the 8 pin part.
No easy way to test it, I'm afraid.
Ok...I finally got this little chip off the board...It has 200D6 PYIC printed on it.
That was a royal pain to get off so I can imagine what it will be like putting it back on..
May be worthwhile to replace the output capacitors (200V/400V ones) as they may also be suspect. What values are they?
For future reference, to remove:
- I remove these types of surface mount chips by flooding both sides with solder, then alternating the soldering iron between sides.
- I lift the device off with tweezers.
Putting it on is pretty easy...
- Line up the pin 1 marker with the chip
- Solder one pin to tack it to the board. Apply a little heat to the pin and move the chip until it is aligned.
- Solder the opposite corner, check all is aligned, then solder each pin individually.
- Flux can help. Check afterwards for bridges then remove with flux and soldering iron, or solder wick and a soldering iron.
Those capacitors are them, yeah. What is the diameter and height of them, approximately?
There's usually an indent or a small dot sunk into the packaging of the device. The closest pin to this is pin 1. If there is no indent, then pin 1 faces the bottom left of the device when the half-moon shape is on the left hand side of the device and it's facing up. Also you can usually read the part number this way around.
Also maybe worth replacing the 35V cap too... it won't be expensive.
