Insignia ns-42pdp (lg pdp42x30000)
  • DaveL
    • Sep 2014
    • 90
    Re: Insignia ns-42pdp (lg pdp42x30000)
    I removed the Y board and performed the test on the IPM as they showed..
    I got no readings or audible from my meter...
    I done the test with the IPM still on the board.
      Ok, along the vertical heatsink on the Y-sustain can you try testing all the transistors mounted to it? From memory there are five.
      • DaveL
        • Sep 2014
        • 90
        Do you test those on the "ohms" field of the meter?
          You can use diode test or 2000 ohm range. Diode test is preferred. Just measure across all three pin combinations looking for shorts. (1-2, 2-3, 3-1) number the pins mentally, no need to have a specific order but be consistent from device to device.
          • DaveL
            • Sep 2014
            • 90
            Ok...using the diode test on the meter..
            There is a total of 5 mosfets..
            The first 2 are labelled W9NK70Z
            The remaining 3 are labelled FDA 59N25
            On the first 2 I get no reading or audible sound..
            On the remaining 3 I get readings and a audible sound from the meter..
              Ok using this diagram in this datasheet
              https://cdn.badcaps-static.com/pdfs/...6772f172bc.pdf
              Can you indicate what pins you measure shorts (beep) -- G,D,S?
              • DaveL
                • Sep 2014
                • 90
                1st FDA 59N25..mounts in the center of heat sink...
                G: NO D: + S: - Audible w/reading of .005
                G: + D: NO S: - Reading of .089 No audible
                G: - D: NO S:+ Reading of .089 No audible
                G: - D: + S: NO Reading of .089
                2nd FDA 59N25
                G:NO D:+ S:- Audible w/reading of .005
                G:+ D:NO S:- Reading of .089 No audible
                G:- D:NO S:+ Reading of .089 No audible
                G:- D:+ S:NO Reading of .089 No audible
                3rd FDA 59N25
                G:NO D:+ S:- Audible w/reading .006
                G:+ D:NO S:-Audible w/reading of .010
                G:- D:NO S:+ Audible w/reading of .009
                G:- D:+ S:NO Audible w/reading of .009
                  Ok I'm a little confused by what you mean by "G: NO D: + S:" and others... can you please explain. Is that D-S measurement, or G-S measurement, or G-D measurement?
                  Either way those FETs look failed to me.
                  • DaveL
                    • Sep 2014
                    • 90
                    G is GATE
                    D is DRAIN
                    S is SOURCE
                    + is positive lead
                    - is negative lead
                    • DaveL
                      • Sep 2014
                      • 90
                      Here is the readings from the first 2 marked W9NK70Z
                      G:NO D:+ S:- NO READING
                      G:+ D:NO S:- .715
                      G:- D:NO S:+ .219
                      G:- D:+ S:NO NO READING
                      G:+ D:NO S:- .753
                      G:- D:NO S:+ .222
                        Originally posted by DaveL
                        G is GATE
                        D is DRAIN
                        S is SOURCE
                        + is positive lead
                        - is negative lead
                        Ok, so by
                        G: NO D: + S: -
                        you mean
                        Nothing on gate (G)
                        Positive lead on drain (D)
                        Negative lead on source (S)
                        right?
                        • DaveL
                          • Sep 2014
                          • 90
                          Right
                            OK, looks like you've found the failed devices. Do you think you can remove them from the circuit, without damaging the board? Since it is a two layer board, you need to be careful not to overheat it. I would recommend a min 50W temperature regulated soldering iron.
                            • DaveL
                              • Sep 2014
                              • 90
                              Yes sir...I have a 80w iron and a 140w gun..
                              Do the numbers sound right on the first 2 (W9NK70Z)?
                                Yes the first two look OK. Primarily I'm looking at short circuits between drain and source.
                                • DaveL
                                  • Sep 2014
                                  • 90
                                  I guess I will have to order these...the local supply house doesn't have them.
                                    Yes, but first I think it's best to remove them from the circuit and do some more tests, just to make sure they are actually bad.
                                    • DaveL
                                      • Sep 2014
                                      • 90
                                      ohhhh ok...I'm getting ahead of myself. lol!
                                      • DaveL
                                        • Sep 2014
                                        • 90
                                        I got them out..
                                        I get and audible tone across all pins in every directions..on all 3 mosfets..
                                        Reading of 10 and less...
                                          Yep, they are bad then.
                                          Can you install the board with those devices removed then check if -Vy is restored to its nominal rating. No image (or only a very faint one) is expected to appear on the display.
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 (third and final post, hopefully!)
                                            by valvashon
                                            I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                            Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                            10-22-2025, 12:33 PM
                                          • oneduane
                                            Samsung Plazma Blues Model PN59D550C1F
                                            by oneduane
                                            I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                                            09-07-2023, 08:17 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 no standby LED; (new problem)
                                            by valvashon
                                            Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                            Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                            Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                            08-30-2023, 10:41 AM
                                          • tbsmith
                                            Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                                            by tbsmith
                                            There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                                            08-11-2025, 06:15 PM
