bought new Power Board, can't test Main Board - need help using MultiMeters
  • GR3Y5H3ART
    • Jan 2011
    • 146
    TV Model is Vizio GV42L and replaced the Power Board w/one working on eBay, VIZIO logo turns orange like before
    my Dad was in electronics for 30+ years and brought me 3 Multi Meters and i want to test the voltage regulators but searched extensively and still can't figure them out
    can someone please tell me how to use any one of these to measure this Main board
    Re: bought new Power Board, can't test Main Board - need help using MultiMeters
    I'd use the middle one...
    Keep probes like they are.
    Set meter to 20V DC (the symbol with one solid line, one dashed line.)
    Place the black probe on the TV chassis, this is your ground reference for now.
    Place the red probe on each pin going to the main board in succession. Note the readings (post them here) and compare to the label.
    • GR3Y5H3ART
      • Jan 2011
      • 146
      tried that and that was the one i was using...will try again today and thanks
        Please read this:
        https://www.badcaps.net/forum/showth...999#post300999
        • Ltank
          • Jun 2013
          • 776
          There are a bunch of videos on u tube
          • GR3Y5H3ART
            • Jan 2011
            • 146
            i looked at some of those w/one of the most helpful being NorCal but even then after searching about exactly how to use these multimeters, i did not find a video
            besides, the 4 22 Inch Samsung Monitors i had, i came on here back in 2011 and BadCaps was to say the least a god send
            a BadCaps Member from Europe was even kind enough to send me CCFLs Bulbs, for free...from Europe!
            thats why i wanted to wait w/these noob type questions but TVs are vastly different from Monitors yet similar in many ways that talking w/members is again, proving to be the best solution
            • GR3Y5H3ART
              • Jan 2011
              • 146
              k got the numbers but the mutli meter was -0.04?
              1.
              pin 1 = 1.56
              pin 2 = 0.00
              pin 3 = 1.05
              2
              pin 1 = 1.25
              pin 2 = 0.00
              pin 3 = 1.38
              3
              pin 1 = 1.44
              pin 2 = 0.00
              pin 3 = 1.05
              4
              pin 1 = 1.45
              pin 2 = 0.00
              pin 3 = 1.04
              5
              pin 1 = 2.25
              pin 2 = 0.00
              pin 3 = 0.74
              6 question, this one has 3 pins but the middle one is not solder?
              • GR3Y5H3ART
                • Jan 2011
                • 146
                not 100% sure if i did the readings correct 1st time so put ground on chassis and measured:
                1.
                pin = 2.58
                pin = 0.98
                pin = 0.00
                2.
                pin = 2.58
                pin = 1.16
                pin = 0.00
                3.
                pin = 4.07
                pin = 2.58
                pin = 0.00
                4.
                pin = 4.08
                pin = 2.58
                pin = 1.58
                5.
                pin = 4.07
                pin = 1.77
                pin = 1.07
                6.
                pin = 0.00
                pin = 0.00
                pin = 0.00
                so 6 is blown for sure?
                  Please write down the P/N of each one of those regulators so we will know what they are, for example 1117-1.8, or 1117.
                  There also two SMD fuses on the board that you should check also, one is for 5V, another one is for the switched 12V.
                  Those 4.07/8 reading are not normal, I expect 5V reading. Is the meter good?
                  • GR3Y5H3ART
                    • Jan 2011
                    • 146
                    All 4 say:
                    AMC1117
                    F0719J
                    except 2:
                    K1117S15
                    726
                    • anmol
                      • Mar 2012
                      • 73
                      • India
                      This may help you?
                      VIZIO GV42L HDTV & L42HDTV10A LCD TV Service Manual
                      Regards,
                        Originally posted by GR3Y5H3ART
                        All 4 say:
                        AMC1117
                        F0719J
                        except 2:
                        K1117S15
                        726
                        OK, the one with 1117s15 is the 1.5V fixed output voltage regulator, the other are Adjustable output regulators.
                        But which two are the 1117s15?
                          1.
                          pin = 2.58
                          pin = 0.98
                          pin = 0.00
                          2.
                          pin = 2.58
                          pin = 1.16
                          pin = 0.00
                          3.
                          pin = 4.07
                          pin = 2.58
                          pin = 0.00
                          4.
                          pin = 4.08
                          pin = 2.58
                          pin = 1.58
                          5.
                          pin = 4.07
                          pin = 1.77
                          pin = 1.07
                          6.
                          pin = 0.00
                          pin = 0.00
                          pin = 0.00
                          So which two are 1117s15.
                          Did you do as I requested on checking the voltages on the fuses?
                          The 4V input voltage is not right, it is too low.
                          Check the voltage of the both SMD fuses at both ends against the chassis ground, if one of them shows 4V then you will have to fix the 5VSTBY power supply first.
                          • GR3Y5H3ART
                            • Jan 2011
                            • 146
                            i meant #2...1,3,4,5 all AMC
                            • GR3Y5H3ART
                              • Jan 2011
                              • 146
                              1.
                              pin = 2.58
                              pin = 0.98
                              pin = 0.00
                              2.
                              pin = 2.58
                              pin = 1.16
                              pin = 0.00
                              3.
                              pin = 4.07
                              pin = 2.58
                              pin = 0.00
                              4.
                              pin = 4.08
                              pin = 2.58
                              pin = 1.58
                              5.
                              pin = 4.07
                              pin = 1.77
                              pin = 1.07
                              6.
                              pin = 0.00
                              pin = 0.00
                              pin = 0.00
                              sry for being a noob but can you point out in the pic where the fuses are? i've seen norcals vid a number of times but wanna make sure n thanks for being so helpful
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                They are just below the connector circled in red. They are labelled F1, F2, etc. I can only see 2, but the flash on the camera might be obscuring another one? A good fuse should measure less than 1.0 ohms.
                                --- begin sig file ---
                                --- end sig file ---
                                • GR3Y5H3ART
                                  • Jan 2011
                                  • 146
                                  whats the part number for the 1117s? should i just replace them all or just the ones w/lower readings?
                                    Well, did you check the voltages at the fuses? the reading of 4V feeding voltage to the regulator is too low for the 5V Standby Voltage.
                                    • GR3Y5H3ART
                                      • Jan 2011
                                      • 146
                                      not yet, i'd rather just buy all the parts and have them in hand just in case
                                      can someone please help me w/correct part numbers from digikey
                                        These are what I stock for repair:
                                        https://www.badcaps.net/forum/showpo...91&postcount=7
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          Today, 08:34 AM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
