Lg 47lm860v 3d tv- no picture
  • Longon
    • Jul 2025
    • 46
    • United Kingdom
    Hey there L....
    Not quite sure what you mean matey?
    See attached confirming where the issue is..
    • lotas
      • Jan 2016
      • 4787
      • Russia
      Each connector has contacts on the other side (which are soldered to the board) and there is a numbering of each output, insert the cable and use a multimeter (on the continuity tester) to check each line, that is, one probe on the T-CON connector, the second probe on the connector (on the soldering side) of the buffer bar, and you continuity test each line with a multimeter, moving the probes to each contact (1pin.- 1pin., 2pin.- 2pin., 3pin.- 3pin.,..........) and do the same between the motherboard and T-CON.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4500
        • Italy - Milan
        For shure it has not to be like so, therefore simply try to pry those pins back to the original position using a needle , it's very kindly not touching well the cable side..
        • Longon
          • Jul 2025
          • 46
          • United Kingdom
          Put pins back, checked lvds and ribbons for continuity all ok-replaced and still no change. led's still working ok, tried other inputs hdmi nothing changed!
          I began checking generally again in and around IC 302 and various caps associated seems that there maybe a problem with.....does this IC and buck converter have any affect or is this totally seperate. I compared to other power supplies and IC 300/3 are simular resistance and V but totally different to 302!!!
          Also I'm only getting 0.3 v caps 604/6/8 and 5/7 1.8 v...are these correct?
          • Longon
            • Jul 2025
            • 46
            • United Kingdom
            IC 302
            pin 1-0v
            2-11.5
            3-0
            4-0.8
            5-0.75
            6-3.3
            7-1.04
            8-1.04
            and caps 139/154/332/329/131 just around 1 v.........Do these sound OK as am unsure but doesn't seem right...
            • lotas
              • Jan 2016
              • 4787
              • Russia
              #26
              If T-CON sees any faults (low resistance or short circuit) on the output voltages for the panel, it blocks them, disconnect one cable from T-CON and the panel (from the T-CON side) and turn on the TV and see what's wrong with the image, then reconnect the cable and disconnect the second one and also check the image (the image will appear on at least half of the screen).
              • Longon
                • Jul 2025
                • 46
                • United Kingdom
                #27
                Hi L....Pic 1 is after removing left ribbon from T-con and pic 2, the right! This supposed to happen?
                Long Click image for larger version
ID:	3717916 Click image for larger version
                • Longon
                  • Jul 2025
                  • 46
                  • United Kingdom
                  #28
                  Originally posted by Davi.p
                  Ok now i understood the first post, i would bet more on a damage of main board than the tcon board, if you do the panel test then you can find better the fault, now i wonder why you changed cables and which one you mean, the tcon output side or input? The worst scenario is the output one as you probably fried a Cof, in the best of cases you burned one small cap on screen strip boards
                  Hi D......Sorry for delay in responding.
                  If I need to check the Cof or caps I've never delved that far into checking these components. They are taped down quite well and is there anything I should be aware of whilst removing and inspecting except for being extra careful as don't want to cause any further damage anywhere!
                  Where should I also test on the main board as you mentioned doing a panel test..to be honest I can't quite remember with any certainty which of the cables I changed at the time whilst the TV was still powered but I suspect it was the ribbon on the T-con side!
                  Long
                  Click image for larger version  Name:	20250903_205426.jpg Views:	0 Size:	2.22 MB ID:	3717931
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4500
                    • Italy - Milan
                    #29
                    Sorry, it's quite difficult to follow these threads on this forum at so long delays, and also to bear with unexperienced users.. give me time.. today is TENNIS day...!
                    • Longon
                      • Jul 2025
                      • 46
                      • United Kingdom
                      #30
                      #Davi & all....I understand, can imagine following up various threads/forums as well as our day to day lives...must be a little brain draining especially with relatively newbies like myself hounding your knowledge.
                      Apologies for in and out with questions and queries to all who have taken time to assist, I expect time differences are a factor also, but still, much appreciated.
                      Regards
                      Long
                      (P.S have a great game)
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4500
                        • Italy - Milan
                        #31
                        Let's make things easier, what you do not understand?
                        • Longon
                          • Jul 2025
                          • 46
                          • United Kingdom
                          #32
                          Hey D......
                          Referring to earlier posts #24-27 are the low V and Resistance a factor?...
                          Apologies for my ignorance but you mentioned a panel test, could you clarify what you meant?
                          When investigating the possibility of damage to the Cof and apart from testing Caps is there anything else that I should be aware of? do's and don'ts!!
                          Long
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4500
                            • Italy - Milan
                            #33
                            The panel test in the more simple words: run a wire from power board 12v out directly to the tcon 12v input, there are 4-5 pins tied toghether at side that is that input, refer to lotas image, remove connection on tcon by main board, feed AC in, it the panel shows a cycling of colors then.screen is 100% sane.. the rest later..
                            • Diah
                              • Feb 2013
                              • 6468
                              GPU could not tested panel in stand alone... yours issue at MB. if the panel buffer boards didn't suffer from liquid damage at buffer boardsb
                              Last edited by SMDFlea; 09-06-2025, 05:38 AM. Reason: rubbish remarks edited out of post...........
                              • Longon
                                • Jul 2025
                                • 46
                                • United Kingdom
                                #35
                                Need to check if correct!!! You say feed AC in...not DC?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4500
                                  • Italy - Milan
                                  #36
                                  sorry it came IT instead of IF..the panel shows cycling...
                                  Feed AC in the power board input...
                                  • Longon
                                    • Jul 2025
                                    • 46
                                    • United Kingdom
                                    #37
                                    Rather than make a mistake and feeding in AC I put in a DC 12v and nothing happened!!
                                    Can you advise where I should jump 12v from and to on attached photo...so confident I'm doing correctly..
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4500
                                      • Italy - Milan
                                      #38
                                      the board has an output connector to the main board, it surely has a contact for 12v, you can solder a wire under
                                      • Longon
                                        • Jul 2025
                                        • 46
                                        • United Kingdom
                                        #39
                                        Hey there sorry for delay in responding....I finally found the time to action your advice. I used the jumper as my 12v and attached to the T-con and nothing!
                                        Was this correct as you asked?
                                        Long
                                        • Longon
                                          • Jul 2025
                                          • 46
                                          • United Kingdom
                                          #40
                                          Hi all......
                                          I have managed to locate another replacement T-con although this is from a 55" model. The EAX module number is exactly the same...would this work correctly in the 47lm860v??
                                          This would be just in case of the T-con being beyond repair....but without actually locating where the issue lies then for me I haven't gained enough valuable knowledge which is why I began these fault finding exercises. The knowledge and insight could then be passed on to others in the same predicament.
                                          Any ideas whether the exchange will work?
                                          Long
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
                                          • noisykid
                                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                            by noisykid
                                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                            12-30-2024, 07:15 PM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
