Lg 47lm860v 3d tv- no picture
  • Longon
    Longon
    • Jul 2025
    • 12
    • United Kingdom
    Hey there L....
    Not quite sure what you mean matey?
    See attached confirming where the issue is..
    • lotas
      • Jan 2016
      • 4671
      • Russia
      Each connector has contacts on the other side (which are soldered to the board) and there is a numbering of each output, insert the cable and use a multimeter (on the continuity tester) to check each line, that is, one probe on the T-CON connector, the second probe on the connector (on the soldering side) of the buffer bar, and you continuity test each line with a multimeter, moving the probes to each contact (1pin.- 1pin., 2pin.- 2pin., 3pin.- 3pin.,..........) and do the same between the motherboard and T-CON.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4377
        • Italy - Milan
        For shure it has not to be like so, therefore simply try to pry those pins back to the original position using a needle , it's very kindly not touching well the cable side..
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • srs
          Insignia NS-50DR620NA18 w/ large vertical lines & no picture
          by srs
          I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
          A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
          I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
          04-22-2023, 02:40 PM
