Lg 47lm860v 3d tv- no picture
  • Longon
    • Jul 2025
    • 46
    • United Kingdom
    Re: LG 47 LM8600 - No Video Hi all.....
    I probably need putting against a wall and deserve a stoning for my stupidity.............. I have a LG which after following information with problems with T-con and lines on screen covered the pins which affected the display and had it sorted...until!!! Lets get it over and done with, I managed to get a little sidetracked and forgot that the tv remained powered up and I replaced the LVDS which to my horror then left me with no picture whatsoever. The backlight remains ok but as mentioned no picture and probably managed to fry the T-con or have I? Perhaps there may be something a little more simple or not so. Where do I go from here? Can you assist in any way? or as suspected into my pocket to find a replacement which is not where I want to go as not the most inexpensive board to say the least.
    OK so now its out there let the stoning begin.....
    Many thanks guys and stay safe(safer than me anyhow)
    Look forward to your assistance
    Regards
    Long
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4498
    • Italy - Milan
    Ok, i read in the other topic that the owner of topic has another problem, so you have or had lines on screen, it depends on how lines are on what type of issue you have, now, have you still some lines or no image at all? if no image at all then probably you have the same as the other topic, thus bad cpu or RAM soldering..
    aside from the light reflow (half reflow) i suggest you the panel test..
    disconnect main board from tcon, place a jumper wire from PSB 12v out to tcon input fuse , to directly feed power to the lcd,
    then switch on current, if the screen makes an BWRGB test (full screen colours) without issue then.main board is at fault, otherwise it can be a fault of soldering of one BGA of tcon..
    • lotas
      • Jan 2016
      • 4786
      • Russia
      If there was an image and when connecting the LVDS cable under voltage and installing the cable with a skew, then the fuse could have burned out, but I do not see it at the T-CON input, it may be at the LVDS output of the motherboard, check the voltage on this capacitor, it should be 12v.
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Regards
        Long
        HELLO SOME PICTURES DON'T HURT
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4498
          • Italy - Milan
          PICS
          https://www.badcaps.net/forum/troubl...m8600-no-video
          • Longon
            • Jul 2025
            • 46
            • United Kingdom
            Sorry guys for not replying only i'm not back to the TV until tomorrow or Tuesday so will return our conversations then.
            Appreciate everyone's input.
            long
            • Diah
              • Feb 2013
              • 6460
              LG , LM series T-CON integrated at MB, no 12 V to Panel.. panel VCC walk arounr the panel self under the bezel side, any glass broken at Panel will damage the VCC rail and this i have 3 time found at LM series, one things more he didn't said any about the edge LED BG, they are with age of TV now time they will be over working time limited
              • lotas
                • Jan 2016
                • 4786
                • Russia
                Again, you didn’t guess, and in your opinion, this isn’t a separate T-CON?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4498
                  • Italy - Milan
                  I think it's a 3D ultrasonic mosquito disturber.+ sound blaster..
                  • Longon
                    • Jul 2025
                    • 46
                    • United Kingdom
                    Hey there L....
                    Just quickly checked I'm getting 11.6v........that close enough or should it be more 12v?
                    • lotas
                      • Jan 2016
                      • 4786
                      • Russia
                      Hey there L....
                      It will do, disconnect the LVDS cable from both sides (from the motherboard and from the t-con) and carefully inspect the contact pads under a magnifying glass for damage... (All this is done on a de-energized TV).
                      • Longon
                        • Jul 2025
                        • 46
                        • United Kingdom
                        Checked for damage....none that I can see...I taped up and secured the loose bezel.
                        LED BG?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4498
                          • Italy - Milan
                          Ok now i understood the first post, i would bet more on a damage of main board than the tcon board, if you do the panel test then you can find better the fault, now i wonder why you changed cables and which one you mean, the tcon output side or input? The worst scenario is the output one as you probably fried a Cof, in the best of cases you burned one small cap on screen strip boards
                          • lotas
                            • Jan 2016
                            • 4786
                            • Russia
                            LED BG?
                            What did you tape over? There is no need to tape anything on the LVDS cable.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4498
                              • Italy - Milan
                              i received your personal message, thanks, i deleed it to keep free the space.. consider to leave one output ribbon removed at a time and test the whole tv, but often in LG this is not allowable or it gives one side with bars only and the other with image, this on a working set..
                              • Diah
                                • Feb 2013
                                • 6460
                                LED BG?
                                the SoC had GPU circuit. LM series as i said no external T-CON... the one Lotas upload photo of it aren't T-CON we do know.. if you have issue at edge LED backlight.. the GPU at MB will shutdown.
                                • lotas
                                  • Jan 2016
                                  • 4786
                                  • Russia
                                  It's a nightmare, I won't even argue! https://www.tvparts.co.uk/lcd-tv-spa...60v-zb-bekwljg
                                  • Diah
                                    • Feb 2013
                                    • 6460
                                    nothings nightmare.. this is early version of LM, later this GPU was included at MB. goes direct to Panel. point stop.
                                    • Longon
                                      • Jul 2025
                                      • 46
                                      • United Kingdom
ID:	3715458 Click image for larger version
ID:	3715457 Click image for larger version
                                      pic 1-3
                                      Hi all......
                                      To save any confusion I've attached pics of my particular TV including PSU, Motherboard and T-con. I was in the process of removing the output ribbon 1 at a time...and this time i made sure that the power was off before moving anything. Attached is also where I originally taped over the ribbon to the left side off T-con output to remove slight vertical lines (little difficult to see on pic) which worked fine. Whilst viewing a little closer just in case of any damage which I hadn't noticed and then came across (pic 5) the right side input of CoF a couple of pins look strange!! I compared it to the other side which I presume would be identical and this is not the case.....Am not sure what to make of it..is this corrector or could it be part of the problem?
                                      Any ideas anyone?
                                      Cheers matey's
                                      Long
                                      (pic 4-5)
ID:	3715460 Click image for larger version
                                      • lotas
                                        • Jan 2016
                                        • 4786
                                        • Russia
                                        Yes, it could be a bad contact between the connector and the cable, insert the cable back from both sides, take a multimeter with thin needles on the probes and ring each line from the motherboard to T-CON.
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
