Samsung Model LN40B530P7F White Screen, washed out pic
  • PDMAN
    • Aug 2014
    • 37
    I got this from someone who worked on it for a while then gave up about a year ago. He told me He got it to work for about 10 minutes then it reverted to the washed out white screen.
    Any idea where to start on this? I'm thinking TCON PCB measure the voltages to it, etc. Any help and guidance is appreciated.
    Posting a bunch of pics. Actually the image of the screen looks better in the pic than in reality.
    If any more info is needed, let me know.
  • PDMAN
    • Aug 2014
    • 37
    Re: Samsung Model LN40B530P7F White Screen, washed out pic
    More Pics
    BTW, is there a Service Manual available for this set as well as schematics.
    A link would be helpful.
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      Service manual can be found here
      Looks like it could be the as15 chip on the tcon, but the red and blue lines could be indicative of panel failure, not sure if that is supposed to be a test photo
      Liberating magic smoke one part at a time
      • PDMAN
        • Aug 2014
        • 37
        Can't download the file. Need to be recommended or take a test.
        Took test got one wrong. Could not enlarge images of the test so couldn't see the circuit well. Can you recommend me? Don't know how that is done but whatever info is needed I will provide
        • PDMAN
          • Aug 2014
          • 37
          Yes that is the test photo produced by the TV. Not sure what you mean by red and blue lines.
            Take the DC voltage reading at the GAMMA Voltage test points pad 1~18 on the T-CON board and report those reading, chassis as the GND ref for the meter.
            • PDMAN
              • Aug 2014
              • 37
              budm
              will do but may take a couple of days due to my schedule. I did google my symptoms and found a very similar case where replacing the TCON PCB fixed the problem. Anyone here local to Boston with a spare TCON PCB for sale?
                Replacing the T-con will fix the issue in most cases but to confirm, if you report the GAMMA voltages, then we can tell you if there is a problem with them and therefore if replacing the T-con will fix it.
                • PDMAN
                  • Aug 2014
                  • 37
                  tom66
                  yes i will take the measurements as soon as I can. \
                  Will post the findings here. I am assuming to measure ALL points from 1 to 18 to chassis ground. Is this correct?
                  So I should have 18 readings all at DC Volts?
                  Thanks for all the Help
                    Yes and tell us what each point measures - for example:
                    Gamma 1 - 0.01V
                    Gamma 2 - 0.38V
                    Gamma 18 - 15.82V
                    etc.
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      try this link instead, I didnt notice I gave you the direct download link when I was logged in, i would go for the center file as it looks to have the most data. and get tom that gamma data
                      • PDMAN
                        • Aug 2014
                        • 37
                        Caleb, no good with that link either. For all 3 files i get this:
                        There is no preview for this item!
                        • PDMAN
                          • Aug 2014
                          • 37
                          Caleb can you recommend me to ElektroTanya!
                          This is what the site says"
                          Download and registration is free.
                          Registration by only invitation (you can obtain invitation from friendship, colleagues...).
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4959
                            • New Zealand
                            Under the box where it says "There is no preview" You should find text that says "This file is downloadable free of charge. ...processing"
                            After a short time this should change to "This file is downloadable free of charge: Get Manual" and "Get Manual" is a link to download the file.
                            If the link never shows, try a different browser or disable your Adblock etc.
                            -David VanHorn
                            • PDMAN
                              • Aug 2014
                              • 37
                              Agent24, that worked perfectly. Thanks!
                              • Caleb
                                Smokin IC's
                                • Feb 2013
                                • 645
                                Glad you got the file, Sorry, I have no invites available to send out. The site is a little hard to navigate as it is primarily in Hungarian, but it is an absolute treasure trove of information. It will allow you to retake the test in about a month, keep trying.
                                • PDMAN
                                  • Aug 2014
                                  • 37
                                  Do you think I should make a post and see if anyone can refer me?
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    You suould be able to get 2 downloads per day even if not a member- what browser are you using - doesnt work with them all.
                                    • PDMAN
                                      • Aug 2014
                                      • 37
                                      selldoor
                                      I usually use Firefox. I'll try IE
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Firefox works for me.
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
